Connecting Chinese Weishi microphone to computer
If you use my newer version of tg, you can use the spectrogram function to see if there is a specific noise that is causing a problem.  Then it might be possible to use an audio filter to eliminate it or at least discover its source.  It's quite possible for the microphone to pick up noise you can't hear, or for something like a USB device to create electrical noise that shows up in the audio signal.
I recently added a BS.1770 style true peak meter to help adjust gain.  That's not released yet.
had the right mix of gumption and boredom.
I'm sure there are different board revisions, but on mine the test point "A" is directly connected to the audio signal from the mic input.
It has a DC bias of 4v, so i installed an HPF of a 10uf cap and a 10k resistor. In retrospect, this cap could have been 1uf or even 0.1uf and we'd be fine.
Used one of the numerous ground stitching vias on the board for the other end of the circuit. Threw on some ferrite beads because they were within arms reach.
Ironically it turns out that the front panel mic jack on this computer may not be connected. I recently upgraded the motherboard. oops?
It has enough oomph to power an earbud. line-in type inputs should work too. fwiw, when listening to it with earbuds, I heard some 120hz or so power supply noise. this is with no other electronics connected. Perhaps it just has noisy power and they just filter it out either before or during signal processing?
Some time later i will maybe dig up the right adapters to plug it into my e-mu 1616m and see if that will work with tg. Or run a wire to the line-in for the motherboard sound on the back of the pc, I dunno.
Possible other option would be installing an audio coupling transformer to prevent ground loops when connected to the computer. Would replace the resistor possibly. I'll have to see what i have in the parts bins.
Edited by TimpanogosSlim
I did eventually find the right combination of adapters to connect to my e-mu system but then i couldn't recall how to map the asio channels to wdm channels and didn't want to look it up, so i connected to the rear panel line-in which works fine.  I'd attach a recording made in audacity but those aren't accepted here. So here's a screen shot.
The buzz I was hearing through the earbud may have been LED lights or it may have been due to overloading the preamp with such a low impedance. I hear no such power supply noise when it is connected (correctly) to other input devices.
TG is working just fine connected to the Weishi 1000 this way
  • 1 year later...
Thank to TimpanogosSlim idea I slightly move forward his/her. From the test point A you can get quite weak and unfiltered signal...about 40mV. But from pin no.9 IO 074 you can get nicer, stronger and filtered. As sensor is used RC combination 10K x 2u2. TimpanogosSlim thank you once again!
Another way I think is very plausible is just tap into the microphone cable. Because the microphone is a built-in preamp it should be easy enough to tap off of that and you do have a power supply on the cable say of power and a single.
  • 5 months later...
I bought the Weishi stand alone from China and made this converter box to be able to use the stand with both my PC/laptop and smartphone. It worked exceptionally well! I couldn't be happier for had gone all out for this mod. Definitely recommend this mod if you already have a PC and can effort just the stand alone on Aliexpress. I made a little video showing my result Weishi 1000/1900 Stand plugs into PC
375195580_201819966240821_3681855231767616953_n.thumb.jpg.9414f50a369f16eecc357fb8b295a092.jpg
Edited by ColdWind
Missing image
  • 4 months later...
Hi,
I'm too lazy to disassemble mine and take a picture for you all. But don't worry, I've got you something even better. This Youtube video covers everything you need, the internal and the circuit diagram. The adapter was used with an Iphone in the video but it works for PC as well. I made mine based off this video. Have fun.
Timegrapher Microphone Adapter for iPhone (DIY)
  • 7 months later...
1 hour ago, MikeEll said:
Is it viable to make up a clip microphone to allow use of the Weishi timegrapher for clock regulation?
Interesting idea - I'll try and do some tests with a contact mic over the weekend.
I'd not seen this thread before; the mic connections in that video are a bit messed up! While it would work, it's likely to pick up noise an hum, as shown.
The battery and signal at the three pin plug are correct as shown - but the signal ground to the phone or PC should be directly from pin 3; that's the metalwork ground connection.
The video also has signal and ground swapped at the TRRS plug; on any modern modern mobile phone, the top sleeve is the mic input and the second ring (TRRS) is ground. The tip and first ring are headphone or aux stereo out.
For a normal PC that uses stereo plugs, the mic input would be tip and the ground on the sleeve.
(Or use both tip & ring for mic, for a stereo input).
as long as your clock is running at the same frequency as a watch. In other words if it's a balance wheel clock of relatively modern design it's probably 18,000 beats per hour. But if it's a pendulum is not going to probably operate at any of the frequencies of a watch timing machine.
clip microphone
then as far as clip one microphones go they make a clip on microphone for guitars which works quite well for DIY timing machines. But you'll still have to have some circuitry to connect with timing machine.
    • HWGIKE#57 Valex FEF 190 15 jewels Swiss lever full service and repair This one was waiting for a balance staff replacement in my cabinet parts and case cleaned up with a new balance staff and a 4th wheel as the original 4th wheel had a broken pivot for the off center second hand. I never attempted a balance staff replacement before however I received a Bergeon Molfres (i was hunting it for about 2 years) and with the help of it I managed to remove the old staff and riveted the new one in. It also received a new MS, crystal and the hole for the MS arbor was also tightened. With the new MS now it has an acceptable performance meaning that the amplitude goes up to 280 fully wound, has an acceptable beat error and I have the two nice lines but only dial up, dial down is not as nice and I could not figure out as why. I have the two lines but the amplitude is dropping to around 230 and the lines are a bit hairy. Both dial up and dial down the lines just go up and down without seemingly any pattern. I cleaned the movement two times, and then a 3rd time pegged out the main plate and train bridge holes but made no change. Both the HS collet and the roller table was too lose on the new staff... I did not count how many times I took the balance cock off to sort out the HS collet, the roller table and the beat error, somebody before me also shortened the HS by pushing it out a bit and it seems every time somebody is messing with the end of the HS the protruding bit is most of the time twisted bent etc. This one was probably one of the most challenging repair and service. I might take the new MS out and clean it lubricate it as I just pushed the new one in to the barrel from the retaining ring. Plus started to re-read the theory of the escapement and how to analyse the graph on the timing machine: Greiner Chronografic Record manual. I am also thinking to put the watch on a 24 hour long run with the eTimer SW it once helped me to figure out what was wrong with a watch. There is an interesting part of the Greiner record manual talking about the pallets and the end shake of the balance and pallet staff. Maybe this is my issue? Who could that possibly identify? After a few years now I am still without a clue how could watchmakers make parts I can only see with my microscope or how could/can they carry out complicated services impossible to do.. real magic..... .... ..... before I sent this post while the pics were uploading I had an idea, i was browsing the possible outcomes on the timing machine I had one for magnetism..... so I demagnetized the movement and it is not hairy now.... two really nice lines 0.2 ms beat error still a bit wavy, but a lot lot better..... argh....
