Hello fine watch fellows! It’s been a while since I’ve posted mostly because school is giving me a thorough thrashing and I simply don’t have time to do much of anything else. Well, recently I overhauled a Girard-Perregaux manual winder with caliber 03B. I was impressed by the quality of the watch and I have not been able to date it with certainty except that it has sub seconds, and to me that means late 50’s but I’m not sure.
The watch had been roughly treated in past as evidenced by the scars on the movement, but it is well made, and is now at least being better cared for.
In any case, the overhaul was performed carefully and everything went back together without incident. The timegrapher helped me get it within a few + seconds a day and all seemed well…After letting it sit overnight I noticed it was running 20 minutes slow, and so I thought I must have set it wrong (which has happened after a long night!) so I set it again and checked it after an hour—20 minutes slow! I found it strange that it would run so consistently slow, so if course I put it back on the timegrapher and tweaked it to run about 20 seconds fast a day and again reset the time. When I checked it again one hour later it was 20 minutes slow.
OK, so I knew something was wrong, but what? It was not the balance or the drive gears because the timegrapher readings are good, but I noticed the hands were very easy to set—almost no resistance. I remember reading about certain cannon pinion problems and so I suspected that. After some research I knew it had to be the cannon pinion because the time loss was too consistent and rapid to be something in the gear train. Also the timegrapher readings were good—but that loose action upon setting was a hallmark of a loose cannon pinion.  I didn’t want to try a nail clipper (yes, I guess some people have used these) because this is not my watch and replacement parts for this GP caliber are non-existent—I checked everywhere.
So I went ahead and bought a cannon pinion tightener from Dash To and nervously went about it.
It took two taps and…. Success! cannon pinion tight! The Girard Perregaux keeping time beautifully again (after readjusting, of course).
I posted just in case anyone unfamiliar with old[er] watches comes across one losing big chunks of time, especially after an overhaul--check the cannon pinion!
J
Lovely watch you have there Joe, and a good write up that will help someone down the line! :)
Congratulations on a very fine restoration and great sleuthing re. the slipping cannon pinion. I have used the same cannon pinion tool with disastrous results. I think that you had just the right touch. A too-hard tap with the hammer and I was left with two half-cannon-pinions!
I have since learned that it is advisable to insert a taper pin before tightening
Also, a safer tool is the inexpensive Bergeon 31001.
I am now awaiting delivery from Cousins before tightening the cannon pinion in the photo.
Definitely a good idea to insert a mandrel for support. The one Joe has just tightened looks like it is blanked at the hand end.
Yes, Geo, on looking closely I an see the blind end. The only reference that I have found to dealing with this type of cannon pinion is in the beginner's book by Harold. C. Kelley. He suggests the obvious which is to shorten a tapered broach or pin so that it fits into the Cannon pinion with some friction.
I also like the treatise by Jeff Elgin who goes into this business in some detail.
http://elgintime.blogspot.ch/2012/01/mechanics-of-canon-pinion-friction.html
Hello,
Thanks for the feedback.  One of my big fears was damaging or crushing the cannon pinion, and I do have some cutting broaches that are tapered. This cannon pinion was very a small diameter and closed off on one end so I could not pass a broach through it. I took my chances, yes, and also used a gentle tap. The first one didn't do much, so I turned the cannon pinion around and also tapped the other side and that did the trick. The watch works beautifully but I still can't find any references to earlier GP watches by year, caliber or anything substantive (beyond the SeaHawk model). Does anyone know of some write-up or link on older GP watches? Thanks again!
P.S. That Jeff Elgin write up was what I read as a reference!
J
Edited by noirrac1j
I use a modified set of end cutters to tighten cannon pinions. The screw allows you to increase the compression a little at a time until the correct amount of friction is achieved.
Just ordered the Bergeon tool from cousinsuk as recommended by Colin! Thanks, Colin!
On the other hand, that is a beautiful quality watch Joe! Great job.
Cheers,
Bob
    • Very interesting! I answered the mail from Longines, explaining that I was a bit disappointed and that I wouldn't ask for a costly confirmation for a watch which isn't a high-end one ... and I received another email explaining that they couldn't not certify the authenticity of the watch, but they could specify that, according to the serial number on the caliber and to their handwritten records, the watch was produced in 1938. Great! @Mercurial I will take the measurements and will keep you informed. Thank you all. This forum is incredible 👍
    • Good stuff, thanks!!!  I'm going to save it and re-read your post and watch the video again.  I have a few follow-up question:  My understanding is that the spring vibrates or breathes between the the two regulator pins. When the pins are fully open the effective spring length is from the stud and theoretically no rate adjustment can be made by moving the regulator arm. As the pins are closed the spring gets closer to one side of the regulator block but doesn't touch a pin. You can still move the regulator carrier the entire terminal curve without upsetting the coils.  The rate can now be adjusted using the regulator because the effective spring length can be modified.  My question is: Does the hairspring bounce off and touch one of the pins as it breathes? Is that why the effective hairspring length is adjusted by moving the regulator?  And follow-up: How is amplitude affected by the spring between the pins? Does fully open pins, dial up position = max amplitude?  When spring adjusted to 1/2 width still = max amplitude? When I have crown down gravity is pulling the spring against one of the pins and I would expect rate to go up and amplitude to go down. Is that correct?
    • A quick Google for Longines 25.17 found several similar watches - like this one with writing on the case back similar to yours https://benjaminmarcello.nl/product/longines-cal-25-17-tank-from-1938/
    • Apps like Watch Accuracy Meter can be inaccurate, and will read some watches better than others.  What daily rate does Watch Accuracy Meter give you if you check the Longines once it’s been running for 24 hours? Best Regards, Mark
