Have some hands that needs a  be refinished with an nicer looking black stripe in the middle . Have tried to mask it and paint . Didn't look good and wasn't straight  . So do you have any tips to finish this of the strip and making it look like new again . Besides finding new hands .Which would be almost impossible . The watch is an old citizen crystron quartz .
Hi Rog!
Just my feverish mind at work here but what about getting a short length of windscreen wiper rubber and using the edge, dipped in black paint, as a sort of tampon?
If the rubber is new and the edge nice and straight, maybe under tension from either end, I reckon you'd get a passable result.
Edited by clockwatcher
There is a slit on the upper part that is going to be relumed in a white lume . Above that and on the other parts there should be a black straight black line . I tried to tape a line with masking tape .But when i removed it .It was way to uneven in the edge . I don't now where to find it ?But do you think i could use water slide paper ?
That's a really tricky one Roger.
Why not have another go at masking them, but instead of using masking tape try use sellotape as it is thinner and should have a sharper edge than masking tape. Use an acrylic matt black paint and apply the absolute minimum to the hands. Leave overnight to make sure the paint is well set then remove the tape. The thinner the coating, the less likely hood of the paint peeling when you remove the tape.
If you can't get the black line absolutely perfect, you would be better just polishing and re-luming them.
hi roger, bit difficult to see exactly from your pics so i'll have a guess, if the black line is recessed paint it with black paint then rub back with 1200 paper or finer, if not get some decal paper from amazon or the like also get bonding liquid like sol, measure up and you will be able to print it up really easy in any desktop publisher program, this is an easy project any probs get back
I will try to take some better pictures in the morning . I have a macro lens but the hand is so small it's hard to come really close . I tried the sellotape but it didn't work so good . The only sellotape i had at home was the one you can see thru . I will order some decal paper from Ebay tomorrow .Good to have anyway .
Clear tape i mean .Hard to find the right word sometimes when it's not my native language .
Should i order clear decal paper or white ?
Edited by rogart63
Hi Rog!
Missed to read your tips at first  . Nice one shall certainly try that .
you could follow Mark's video about relume hands and polish front side and applay paint to back side same way as lume is done on the video.
This might work.
When I re-gild the inlays of French clocks before proceeding I always first polish the main case with black shoe polish which is a wax.When applying the gold gild paint to the inlay any over spill just wipes off leaving nice clean lines. My thinking being if the hand is inlayed first remove any old paint then clean the hands with a degreaser including the inlayed area then try polishing the hands without touching the inlayed area with a wax based polish. Apply a black enamel paint with a very fine horsehair brush and any over spill should just wipe off.
Fail :growl:  . Tried to polish the hands with some polish . The brass came trought . It's brass with chrome over not stainless steel . Will try to find some replacement hands or a donor watch . Lesson learn . Never ever think that a citizen quartz has stainless steel hands .
I sympathise Rogart  I have had lots of disasters over the years I just make sure I learn from them.
The secret with painting whether it is a wall,wood, or metal is preparation. You know when you have prepped correctly when the paint attaches with a single stroke of the brush.
If you know the dimensions of the hands you should have no problem getting new hands to fit.
Spray the entire hand in dayglo orange...!
Old architect (and surgeon) principle: if you can't hide or disguise it, make a feature of it...! ;)
Pete, Brisbane
This is the result i came up with .Some old hands i had laying around . Relumed them in white and put them back on.More original then original .
Since them this has happen . Found a donor watch on Ebay . So some oldnew hands has found it's way to a new watch .Looking original again .
I like the look of the previous pic. I feel the substitutes look better.
The way I would go about this sort of thing.
1, Clean out the old.
2, I had an old watch oiler a thick one.
3, Airfix paint.
Turn the  hand upside down fix the hand to a piece of peg wood dip the oiler into paint and work out from the center to tip by means of a spreading motion and leave to dry.
 They did but i like it as original as possible .
There's a lot to be said for that. Be it for nostalgia, personal achievement in the restoration process, sharing with a purist, or just personal enjoyment, there can be no greater satisfaction.
    • How do the timegrapher readings look after the watch has been running for 24 hours? Are you using a phone app or a dedicated timegrapher to take your measurements? Best Regards, Mark
    • From what I see, the crystal is made of mineral glass and is secured to the bezel with a sealing ring. If you might want to replace the crystal without removing the bezel or the movement, I think it's possible, but risky. You have to suck out the old crystal without breaking it into tiny particles. I would not do that. If you remove the movement first you can press the crystal out and press a new one in without removing the bezel.
    • Hello Everyone, A short message to introduce myself. I'm Sebastiaan (50) from the Netherlands and have always been interested in watches. My two kids are at the end of their teens years and so I have more time to start a hobby.  Working on watches was something I always wanted to learn. So I recently started the watchfix repair course. Currently watching level 3. My short term goal is to be able to service the watches we (Myself, my wife and kids) own. I own a manual Omega Geneve from 1974, a small microbrand watch with a NH35 and a wittnauer bumper from 1940's. My wife owns an Oris, Seiko 5 with 7s26c and my son a seiko alpinist sarb017 and sports 5 with 4R36. So enough to learn on the short term..  Looking forward to talking to all of you and enjoying the watch hobby together. Greetings Sebastiaan
    • It works quite well. The only strange thing is that it loses 2/3 mn per day whereas the measurements indicate that it is fast by 1/2 mn. Maybe something wrong with the gear mechanism ...
    • Unfortunate…but you clearly have a Longines branded movement with a year 1936 serial consistent with the caliber. I checked the case maker of the last few Longines I worked on… …same as your watch, so certainly you have grounds to honestly describe your watch as a Longines cal 25.17 tank with unbranded dial…and given the modesty of the watch IMO the Longines authentication wouldn’t dramatically alter the value, if that’s what you are hoping…as nucejoe suggests the value will mostly be determined by how well it runs…
