5 hours ago, LittleWatchShop said:
Title says it all.  How do I remove the cap jewels?  Same issue on the dial side.  Seems to be some split ring scheme.
You will need to punch out the cap jewel with the upper balance jewel from the back, I think.
Unless that little notch is for a screwdriver blade to loosed the rim
Hmmm  I think you will need to remove the balance and have a look from the underside, It may be friction fit or as JD said the split ring but it needs further investigation at this point.
I did remove the balance and HS. No screws...all friction fit.
48 minutes ago, watchweasol said:
There may be a case of using a jeweling press or staking tool to remove the complete setting .
Not gonna do it!  Not that brave.  I have looked through both jewels with high power microscope and backlighting.  They are are in pretty good shape.  Taking the Hypocratic oath on this one.  It is for a friend.  He will watch it tick a couple of days and put it back in a drawer.
