So I'm working my way through a box of old watches I've bought to tinker with/restore, and the next up on my desk is this Wolbrook/Douglas Skindiver Worldtimer.  Wolbrook was a French company that started in the 40s and didn't make it out of the quartz crisis.  This particular watch actually has a connection to the astronaut Neil Armstrong, because he owned one as a personal watch before being issued his Omega for the moon mission.  That watch was auctioned off in 2019 by Neil's brother, and spawned a rebirth of the Wolbrook Company as a result.  Because of that, I'm having a tough time finding information on the vintage version, since all my search results are crowded with stories of the reissue.
https://wolbrook.com/pages/douglas-watches
So if anyone can recognize this movement, it would help me out.  The movement is signed Wolbrook watch company, and the appears to be French.  It is a 1 jewel pin pallet movement and seems to be in OK condition, but at minimum I'm going to need a stem/crown, a new crystal, and I suspect a balance staff.  The dial is perfect, the plated case is very good, and the worldtimer bezel is in tact but missing a chunk.  But until I figure out what this is, I'm stuck.
So one more question; it appears that the stem is listed as W3119 but I can't seem to find any mention of what the thread pitch is for that stem.  Is there a resource that I can use to look up what thread this stem has so that I can order a crown at the same time I order the stem?
Some alternatives I can think of that might save you some £.
WRT member @AndyHull  is  familiar with this types of watches , he is likely to be real helpful.
There is also  http://www.obsoletewatchandclockparts.com    based in UK.
A scrap movement is actually yoir best bet.
Good luck
I'm not familiar with that particular movement, it does appear to be a relative rarity. If you do find a source for the stem, then ask the supplier to check the thread, as I'm sure they would be able to offer a crown to fit at the same time.
I have a large box of random stems (several thousand) that I scored on ebay a while back, so when I'm stuck with a stem I cannot source, I typically painstakingly work my way through likely looking candidates until I find something that works.
What's interesting is that doing a bit of research, the movement isn't super rare, but the non-jeweled version of this watch was a cheap watch that probably got thrown away rather than serviced/fixed.  At one point they were making 10,000 per day!  I've yet to locate a parts movement, but I'll keep looking.  I appreciate the resource you listed; they don't have this movement but they do have quite a few others that might come in handy.  I'll set an eBay automated search and maybe I'll get lucky.
