I need some help. I have an Elgin 18s pocket watch with screw on bezel and back. The back will unscrew nicely but the bezel and crystal will not move. I've tried all I can think of with no luck. HELP THANK YOU>>>
I've had success with stiff bezels by using 3 finger cots - one on the thumb and the others on the index and middle fingers. The thin rubber grips well and doesn't mark the metal. A sticky ball is great for the case back, but I wouldn't care to put much pressure on the crystal - particularly if the watch is old..
Use three on each hand if need be - one hand gripping the case side and the other turning the bezel.
Thanks, I'll try the cots.  I've thought of putting the whole watch in the ultrasonic cleaner with a detergent to see if that would loosen it up. Any thoughts?
NO!!! Do not put watch in cleaner.
Try putting it in the freezer and then try with the cots as WillFly suggested or a rubber case opening ring.
Excellent idea! :)
Try using hot glue stick, and a bottle top (gator aid) is larger.
Worked great for me
Ken
    • From what I see, the crystal is made of mineral glass and is secured to the bezel with a sealing ring. If you might want to replace the crystal without removing the bezel or the movement, I think it's possible, but risky. You have to suck out the old crystal without breaking it into tiny particles. I would not do that. If you remove the movement first you can press the crystal out and press a new one in without removing the bezel.
    • Hello Everyone, A short message to introduce myself. I'm Sebastiaan (50) from the Netherlands and have always been interested in watches. My two kids are at the end of their teens years and so I have more time to start a hobby.  Working on watches was something I always wanted to learn. So I recently started the watchfix repair course. Currently watching level 3. My short term goal is to be able to service the watches we (Myself, my wife and kids) own. I own a manual Omega Geneve from 1974, a small microbrand watch with a NH35 and a wittnauer bumper from 1940's. My wife owns an Oris, Seiko 5 with 7s26c and my son a seiko alpinist sarb017 and sports 5 with 4R36. So enough to learn on the short term..  Looking forward to talking to all of you and enjoying the watch hobby together. Greetings Sebastiaan
    • It works quite well. The only strange thing is that it loses 2/3 mn per day whereas the measurements indicate that it is fast by 1/2 mn. Maybe something wrong with the gear mechanism ...
    • Unfortunate…but you clearly have a Longines branded movement with a year 1936 serial consistent with the caliber. I checked the case maker of the last few Longines I worked on… …same as your watch, so certainly you have grounds to honestly describe your watch as a Longines cal 25.17 tank with unbranded dial…and given the modesty of the watch IMO the Longines authentication wouldn’t dramatically alter the value, if that’s what you are hoping…as nucejoe suggests the value will mostly be determined by how well it runs…
    • It's difficult to tell, but my guess is it just looks like it has a bezel. Once you have removed the movement, you should be able to tell. Either way, I think you should be able to press out the old crystal from the inside as long as you have a die that properly supports the area around the crystal. So, take it a part first and then assess if any additional tools or actions are needed. Let us know how you do!
