Smiths Astral advice sought please
Davey57
You are both right, it should go back. You wouldn't believe how long it was in the shop for repair, on both occasions. Also I agree he should have informed his customer of the manner of the "repair" that was carried out. Could you possibly estimate the cost of the work to be done?
Hi Dave  Thats  like asking how long a piece of string is.  Cost depends on who is doing the job, I would estimate about 4hrs to set up and re bush the cock, depending on the state of the pivot, stripping and cleaning the clock, regulating. so i would guess a days work may be a day and a half.  Again it depends on the rate,  A freind of mine was quoted  £360 and the work would take at least a month, Infact he declined and it still took them a month to return the clock. I ended up doing it and its still running well three years later  (A Hermle 340-020) and that was just a cleaning job.       cheers
I was thinking more along the lines of just having the platform repaired.  I was thinking if I put it back together, it's all cleaned now, lube where necessary and see if it runs ok. If not, it's just a matter of taking the platform off again.
Edited by Davey57
You can tell that terrible work is resent, the filing is still shiny it hasn't even begun to tarnish. I'd take it back and complain like hell. No harm in testing the waters, see what the useless bugger says.
You might also like to ask him why is the movement covered in oil and why is there oil where there isn't supposed to be any.
I've got the clock back together and it's running. I'll keep an eye on it for a while. I have explained everything to my friend who owns the clock and shown him the pictures. He says he is not going back to that bloke under any circumstances, he's had enough of him, and if he did the clock would be away for many more months again. There is another clock repairer that we know of in our area, might get him to take look. Now it's cleaned and back together the wear in the top pivot hole is clear to see. In fact, when it runs I can see the light from my work lamp glinting on the escape wheel and then when the wheel tips slightly the reflection goes away until the wheel turns a bit more. Oh, and it looks to me as if the pallet bridge might be slightly bent too. Photo included, not sure if you can tell from it though.
OH. According to my friend the guy said it had not needed any repairs, just cleaning. He might possibly have done as you say, and is not aware himself of what has been done with it.
WW.  I thought that too.
It's ticking away quite happily, not sure if letting it run for prolonged periods might escalate the damage to other parts of the escapement?
He must have been blind as a bat if he didn't see that the escape wheel needed re-bushing. Why did it take so long if it just needed cleaning, I could re bush and have it cleaned and back on the shelf for testing in less then one day. I would get the bushing of the escape wheel sorted A S A P
    • HWGIKE#57 Valex FEF 190 15 jewels Swiss lever full service and repair This one was waiting for a balance staff replacement in my cabinet parts and case cleaned up with a new balance staff and a 4th wheel as the original 4th wheel had a broken pivot for the off center second hand. I never attempted a balance staff replacement before however I received a Bergeon Molfres (i was hunting it for about 2 years) and with the help of it I managed to remove the old staff and riveted the new one in. It also received a new MS, crystal and the hole for the MS arbor was also tightened. With the new MS now it has an acceptable performance meaning that the amplitude goes up to 280 fully wound, has an acceptable beat error and I have the two nice lines but only dial up, dial down is not as nice and I could not figure out as why. I have the two lines but the amplitude is dropping to around 230 and the lines are a bit hairy. Both dial up and dial down the lines just go up and down without seemingly any pattern. I cleaned the movement two times, and then a 3rd time pegged out the main plate and train bridge holes but made no change. Both the HS collet and the roller table was too lose on the new staff... I did not count how many times I took the balance cock off to sort out the HS collet, the roller table and the beat error, somebody before me also shortened the HS by pushing it out a bit and it seems every time somebody is messing with the end of the HS the protruding bit is most of the time twisted bent etc. This one was probably one of the most challenging repair and service. I might take the new MS out and clean it lubricate it as I just pushed the new one in to the barrel from the retaining ring. Plus started to re-read the theory of the escapement and how to analyse the graph on the timing machine: Greiner Chronografic Record manual. I am also thinking to put the watch on a 24 hour long run with the eTimer SW it once helped me to figure out what was wrong with a watch. There is an interesting part of the Greiner record manual talking about the pallets and the end shake of the balance and pallet staff. Maybe this is my issue? Who could that possibly identify? After a few years now I am still without a clue how could watchmakers make parts I can only see with my microscope or how could/can they carry out complicated services impossible to do.. real magic..... .... ..... before I sent this post while the pics were uploading I had an idea, i was browsing the possible outcomes on the timing machine I had one for magnetism..... so I demagnetized the movement and it is not hairy now.... two really nice lines 0.2 ms beat error still a bit wavy, but a lot lot better..... argh....
