Just the same as most watch movement : 9010 on the fast moving bits - balance, escape wheel, center seconds pinion (tiny bit), and D5/HP1300 for the slower bits, gear train.
Here's part of the Moebius Lubrication chart (full thing attached)
2_Oil_Chart (1).pdf
Edited by mikepilk
Thank you for your quick answer and for your help!
Would you please check this list for peace of my mind?
- second wheel: D5
- third wheel: D5
- fourth wheel: D5
- escape wheel: 9010
- center seconds pinion: a tiny bit of 9010
What do you think about the friction pinion of the second wheel? Should I apply some grease or not?
That's how I would lube it.
It looks like that's the cannon pinion on the second wheel. It's usual to put a little D5 (or grease) on the shaft before you press the cannon pinion on.
Thank you both very much!
If you do not mind I will share my experiences with you when I finished the service.
Have a nice weekend!
Please do. Good luck
