Hi All
I got a great monty python clock from the wife for xmas.  There's no second hand but the movement has that wheel and the annoying tick tick.  I hope replace it with a silent continuous sweep or one without a second hand wheel.  It's a TP516 and is 55mm square.  The overall shaft length is 11mm using my not-too-accurate chinese caliper.  The threaded stem length is 5mm.  There's no clock face cover.  The hand pipe diameter is 5.5 mm and 3.9mm for the minute hand.
I've looked at parts websites where they ask about shaft length but not the size of the movement case or hand diameter.
Can someone point me in the right direction.
Thank you
Charlie
  • 4 weeks later...
