Iv'e always separated the balance wheel assembly away from the mainplate when using in my old elma machine
I always been worried that it will get damaged/balance spring will get distorted due to the speed of the fluid.
Whats best practice, also do the jewels get removed first to stop it breaking the pivots??
Thanks in advance.
Edited by jnash
I have always cleaned the balance mounted to the plate, with the jewels in place. That's how I was taught when I was an apprentice and I have been doing it ever since. Never once damaged a hair spring, never once broke a pivot this way.
I have broken pivots in other ways but that's another story :)
Hi jnash,
I don't have an Elma or similar machine. I have an ultrasonic (generic type). Although I've put the balance wheel assembly in the ultrasonic, all by itself, I'm adopting another system: Balance wheel assembly without jewels in the plate and jewels washed separate by hand. The reason behind it is that with the gentle movement of the fluid in the ultrasonic and the extra space between the pivots and the frame, I might get a better cleaning and even a little rubbing (I'm still in the testing phase and might be completely wrong on this one). It simply takes some time to do it all by hand (which is my preferred method for this part) i.e. cleaning the balance assembly by hand, jewels by itself. I'm just still trying a way that works for me. Notice that I always clean the jewels manually regardless of the method I use.
Given the speed of the Elma I would assume that the balance wheel will be better protected mounted in the frame probably with the jewels on to avoid knocking on the pivots, IMHO. Nevertheless, given it is a very sensitive part I would either use an ultrasonic or better: clean it by hand. One Dip does pretty good and there is an equivalent from L&R that doesn't cause harm to the user...the original is very inexpensive.
In any case, maybe other more experienced users here may have a different and better way,
Cheers,
Bob
Balance always on plate,jewels out and separated for better cleaning.
I believe its safer for the balance to be on plate than to swung freely inside the basket propelled by the fluid
br
emso
p.s sent from my sh**y phone, so sorry for typing mistakes
Thanks all for the quick responses!
well some have just said mounted with the jewels and some have said mounted without the jewels.
for the last few years i remove the balance from the bridge and clean it separately in one dip (or a cheaper alternative)
Mark, do you then remove the jewels after, give them a clean just before you oil them if they stay in for the wash cycles.
Edited by jnash
Absolutely. The jewels must then be washed to remove old oil residue and lubricated.
I leave the jewels in place as this provides the maximum stability for the balance whilst it's in the cleaner.
I hope this helps.
+1 Emso
For balances with shock protection I remove all the jewels from the settings and reinstall the balance and cock to the main plate. The jewels go into a separate basket.
Non shock protected balances the cap jewels come off and the balance replaced on the main plate, again cap jewels in a separate basket.
I use an Elma machine and have never had any problems.
Well, the vote is 50 - 50...I go with the jewels on and then separate jewel cleaning just as (our) Mark said. In any case, our other Mark and Emso have good results too... Maybe the solution depends on the machine and how powerful it is (variations due to model, age, etc?).
i guess i have to be careful what else goes in with it, its usually the mainplage and the mainspring that i put in so that shouldnt do too much damage if it hits, still can see the balance spring being warped , but ill try it out...
This has been bugging me for ages but never bothered to get some validation!
I open the main spring and do the actual spring manually since it is too big for my setup. I do clean the barrel proper with the rest of the gears and whatnot. I never put anything with the hairspring itself.
indeed it is important not to have any other loose item in the same compartment as the plate and balance. If anything gets bound up in the hairspring, it will open up a whole new set of problems.
I always put the main plate with balance and balance cock in a compartment on its own, nothing else goes in there so the risk of anything coming into contact with the hair spring is eliminated.
In fact when I think about it I have a bit of a set routine.
Three baskets go into the cage.
The bottom basket is not compartmentalised so that is where the main spring goes if I intend to reuse it.
The middle and top baskets are both subdivided into 7 compartments of different sizes and the main plate, balance, and cock go into on of these in the middle basket.
The other bridges go into the middle basket as do the barrel and lid and the train wheels, all distributed so as to keep the whole thing in balance when it is spinning.
Everything else goes into the top basket with the smallest parts, including the balance jewels and the pallet fork in a couple of 15mm baskets.
I don't actually know why I arrived at this distribution other than a need to keep the balance assy separate, and to prevent the heavier parts knocking against each other but I do it every time without fail, and without thinking about it.
My Elma I think is an early Super Elite. It looks to be identical to a Super Elite in every respect except that it is cream coloured, not crackle blue. I've no idea how old it is as I got it second hand (total bargain at 99p plus £15 postage) but it spins up to a very healthy speed.
@marc
An almost identical method and setup to me.
But my super elite cost £40.
Good 'ol eBay :D
I have read these posts with great interest as I have tried all the various methods + stripping down & cleaning by hand. But I now use Mark,s method cleaning with the balance mounted to the plate in my L&R. No problems and really good results so I will stick to this method.
Edited by clockboy
Looking forward to my next clean (always the boring bit in my opinion)  and ill try it out.  ive been doing this for a while and i sometimes just forget to ask about other ways. An old watchmaker told me that there are 100 different ways and tools to do everything, not to mention the fact that incredible timepieces were created and maintained way before all the more modern tools we have now, your only restricted by your imagination.
Really appreciate the quick response and wealth of information around here, I'm a long term member on other forums where the watch repair is a sub forum, this place really appeals to me so much more as i honestly feel that i've found my place full of like minded people.  thanks guys...
Elma rm-90 as machine
Elma WF in first jar
Elma Suprol 2&3 jar
Speed is set up so when rotation begins fluids go over the basket (more than 50% on the scale)
Very dirty movement get an extra time in first jar of 5-10 minutes
As i have sen positive posts regarding the L&R fluids i have ordered them and i await their arrival,will write again after i test them.
br
emso
I've enjoyed reading this thread guys as I've just purchased a second hand cleaning machine. Tomorrow I'll be checking out the wiring before putting it into service.
I was taught to remove the balance and jewels from the cock before cleaning.
I clean the balance in one-dip and dry it in some boxwood sawdust. I clean the jewels in one-dip as well (I replace the one-dip after every few watches and use two different containers for jewels and springs).
I screw in the stud screw (if there is one) before cleaning as well. Having to screw that back in after it fell out more than once is annoying :P
Well I had a go, looks like it survived the tornado clean ;)
Thanks again
Edited by jnash
I have been looking for comments on the web for this info. I have only used Elma in my L&R cleaning machine and due soon for a change and don,t know whether to try L&R or stick with the Elma.
Personally I throw the Balance into a glass, put it in the dishwasher, and run a full "Pots and Pans" cycle ... but only use dishwasher tablets with the powerball in them or you can risk damage to the hairspring :cool:
Seriously though, we're pretty much Mark's little apprentices here, so I'd be surprised if many do it differently on this forum ... Balance on the Main Plate with the Jewels in place for me!!
Edited by Lawson
    • HWGIKE#57 Valex FEF 190 15 jewels Swiss lever full service and repair This one was waiting for a balance staff replacement in my cabinet parts and case cleaned up with a new balance staff and a 4th wheel as the original 4th wheel had a broken pivot for the off center second hand. I never attempted a balance staff replacement before however I received a Bergeon Molfres (i was hunting it for about 2 years) and with the help of it I managed to remove the old staff and riveted the new one in. It also received a new MS, crystal and the hole for the MS arbor was also tightened. With the new MS now it has an acceptable performance meaning that the amplitude goes up to 280 fully wound, has an acceptable beat error and I have the two nice lines but only dial up, dial down is not as nice and I could not figure out as why. I have the two lines but the amplitude is dropping to around 230 and the lines are a bit hairy. Both dial up and dial down the lines just go up and down without seemingly any pattern. I cleaned the movement two times, and then a 3rd time pegged out the main plate and train bridge holes but made no change. Both the HS collet and the roller table was too lose on the new staff... I did not count how many times I took the balance cock off to sort out the HS collet, the roller table and the beat error, somebody before me also shortened the HS by pushing it out a bit and it seems every time somebody is messing with the end of the HS the protruding bit is most of the time twisted bent etc. This one was probably one of the most challenging repair and service. I might take the new MS out and clean it lubricate it as I just pushed the new one in to the barrel from the retaining ring. Plus started to re-read the theory of the escapement and how to analyse the graph on the timing machine: Greiner Chronografic Record manual. I am also thinking to put the watch on a 24 hour long run with the eTimer SW it once helped me to figure out what was wrong with a watch. There is an interesting part of the Greiner record manual talking about the pallets and the end shake of the balance and pallet staff. Maybe this is my issue? Who could that possibly identify? After a few years now I am still without a clue how could watchmakers make parts I can only see with my microscope or how could/can they carry out complicated services impossible to do.. real magic..... .... ..... before I sent this post while the pics were uploading I had an idea, i was browsing the possible outcomes on the timing machine I had one for magnetism..... so I demagnetized the movement and it is not hairy now.... two really nice lines 0.2 ms beat error still a bit wavy, but a lot lot better..... argh....
