How about a basic ultrasonic jewelry cleaner with store bought jewelry cleaner solution?
Is it effective enough?
I really can't afford a professional cleaner at this time.
Sorry for the double posting.
Edited by mlfloyd1
Hi Geo, I didn't see your post about the new cleaning machine. How did it go?
@mlfloyd: The information is intermixed since we all use different systems of both professional and non-professional cleaning. Just do a search, there is plenty in here. I must add that if you use ultrasonic "jewelry" cleaners, you may get away removing the jewels from the cock and plate when cleaning the scape wheel since there is no cyclone action. Also, jewelry cleaner chemicals are not exactly healthy for watch parts considering some of them might have agents that might harm different materials used in those parts (example: shellac, etc). I would use those for bracelets, and such.
Hi Bob, if you are asking about the the old Brenray machine, I have been way too busy and lazy to look at it over the Christmas/New year period. Don't worry, I'll post a few lines when it's up and running.
Hi floyd,
jewelry cleaners are best for bracelets/bands but should be better than nothing.
Use smaller jars with cleaning solution and place it in the cleaners, (the ultrasonic transducer will usually be central)..I would imagine a thin plastic connector would transmit the ultrasonic waves better but I may be wrong.
Anil
  • 3 years later...
Hi All
I'm a beginner.  I've run the balance jewels from an AS 1700 thru the ultrasonic.  The jewel didn't come out of the setting as it did the last and only time I've done this before.  Should it?  Otherwise, I can image that a bubble can form under the setting preventing any cleaning fluid from getting in.
Thank you
Charlie
15 minutes ago, Lc130 said:
Hi All
Thank you
Charlie
Hi Charlie
Do you mean that the cap jewel didn't come off - are they Incabloc ?
Unless really stuck with old oil, they usually come off in the ultrasonic.
If not, try prodding them with some pegwood (under fluid so they don't ping off),  or press the cap jewel in to some Rodico.
Mike
2 minutes ago, mikepilk said:
Hi Charlie
Mike
Yes, Incabloc cap jewels.  Almost microscopic.
Interestingly, it immediately came apart when I reran it with naptha instead of the cleaning solution that I mixed up from a recipe on this site.  That recipe is distilled water, murphy's soap, ammonia, and cascade.  Certainly safer to have in the house but now I'm wondering if it's optimal??
Another question:  is it common for the top and bottom incabloc cap jewels to be different?
The idea of prodding the jewel under fluid is very helpful and non-intuitive.  I've lost count of all my pinged off parts.  Maybe I should take this hobby into the pool:)
Charlie
If they are different diameters then it will be clear which goes where. If there is a difference of thickness the thick one always goes on top- in the balance cock. Remember the sound a clock makes- tick tock: thick top. You won't forget!
Very helpful!  Are cap jewels symmetrically shaped or do they have an upside and downside.  Almost impossible to tell with the loupe.
I've just cleaned a couple myself - I use an old contact lens storage case to keep the jewels separate.
A drop of lighter fluid, and float in hot water in the ultrasonic. Then rinse in isopropanol
  • 3 months later...
Hello,
I have a question about cleaning. In the course I saw that if I don't have a cleaning machine I can clean parts by hand using benzine.
I wondered if it could be a problem to put parts that have jewels fitted with shellac in benzine. As the benzine could melt the shellac. Is it ok to do it if doesn't stay to long in the solvent? How would you clean these parts if you don't have a dedicated watch cleaner?
Thank for your help!
Tony1212
For balance assemblies I find automotive brake cleaner, or electrical contact cleaner sprayed in a small bowl works very nicely.I tend to leave pallets alone unless they are dirty. I too am worried about the effects of solvents on the shellac, I have had stones fall out. If need be they get a dip in hot soapy water..for the shortest possible time.
I use naphtha and in my experience, the shellac will basically stay unaffected. However, I wouldn't leave those parts in naphtha for a week, but for a day or two I haven't had any problems, and I always check the integrity of the pallets and impulse pin after cleaning. However, be very careful with alcohol-based solvents such as isopropanol (aka IPA). I ordinarily rinse in IPA, but the pallets and the balance only for a few seconds and then I immediately blow them dry. The idea is to remove any remaining naphtha.
An ultrasonic cleaner and warm/hot water will do a decent job (I use 60 ml glass jars with naphtha that I place the parts in and then the jars go in the ultrasonic cleaner). However, the ultrasonic cleaner will not be able to remove rust, corrosion, and some other stubborn dirt, so after cleaning I always inspect the parts and use fibreglass scratch brushes (my no.1 favourite cleaning tool)  as needed and rinse in IPA again.
Good luck!
Edited by VWatchie
typo
For you guys doing hand cleaning with naphtha or any solvent it's important to dry in warm air, a hair dryer is fine. The evaporation drops the temperature and there's a real risk of condensation and rust on the newly cleaned steel. This is why the old books are always talking about drying in warm sawdust.
Oh, forgot to mention!
Big parts (main plate, bridges, and even some medium sized parts such as the ratchet wheel, etc.) I clean using warm/hot water, detergent (Yes!), and variously sized toothbrushes! It's super efficient and after this treatment, the parts look all shiny and new! Haven't found anything that beats it, and I even doubt a watch cleaning machine would do a better job. However, be careful to blow everything perfectly dry as soon as possible to avoid the possibility of any rust building up. And, I never use this method for the train wheels as they rust very easily.
you can get yourself a jar of one dip for pallet and balance, 2oz bottle will cost you $9. and a bottle of ronsonol lighter fluid for the rest. or use the lighter fluid for everything. you can manually clean after a soak with pegwood, rodico, and fiber brushes. some guys make their own water based concoctions but was never really a fan of water based cleaners, i prefer solvents. they work better at removing old oil if you are not using an ultrasonic.
Mineral spirits on everything but hairspring and pallet..let the parts soak.All the crud gets dissolved or falls off.you might want to change it once or twice on a really filthy movement.I put the parts in a small dish inside a biscuit tin so it doesn't evaporate.
Edited by yankeedog
Thank you all for all your tips.
This forum is pleasingly active. You guys helped me get years of experience in just 24hrs!
I can see that like in every trade, everybody experiments and sticks to what work for a specific person, his liking and environment. Thank to your help I'll have the opportunity to make my own experiments.
I already tried to put a flake of shellac in benzine for 3 hours. It came out unchanged. I don't have to do the experiment in IPA or ethanol. I know the answer. These are the solvents that I use when I prepare my wood finishes. (@nickelsilver : thank you for pointing it out. I didn't suspect that)
Please allow me a few more questions :
Is there a risk that the glass fiber brushes leave marks on the metal parts? How to you use them? Liberally or with specific care?
For those who use One Dip, how do you use it? Do you transfer it to a more practical jar to use it and then back to original container?
Glass fiber brushes won't really mark steel, and are effective for removing rust spots. They will mark non steel parts. I only use them on steel and as seldom as possible as the little broken fibers get EVERYWHERE.
    • HWGIKE#57 Valex FEF 190 15 jewels Swiss lever full service and repair This one was waiting for a balance staff replacement in my cabinet parts and case cleaned up with a new balance staff and a 4th wheel as the original 4th wheel had a broken pivot for the off center second hand. I never attempted a balance staff replacement before however I received a Bergeon Molfres (i was hunting it for about 2 years) and with the help of it I managed to remove the old staff and riveted the new one in. It also received a new MS, crystal and the hole for the MS arbor was also tightened. With the new MS now it has an acceptable performance meaning that the amplitude goes up to 280 fully wound, has an acceptable beat error and I have the two nice lines but only dial up, dial down is not as nice and I could not figure out as why. I have the two lines but the amplitude is dropping to around 230 and the lines are a bit hairy. Both dial up and dial down the lines just go up and down without seemingly any pattern. I cleaned the movement two times, and then a 3rd time pegged out the main plate and train bridge holes but made no change. Both the HS collet and the roller table was too lose on the new staff... I did not count how many times I took the balance cock off to sort out the HS collet, the roller table and the beat error, somebody before me also shortened the HS by pushing it out a bit and it seems every time somebody is messing with the end of the HS the protruding bit is most of the time twisted bent etc. This one was probably one of the most challenging repair and service. I might take the new MS out and clean it lubricate it as I just pushed the new one in to the barrel from the retaining ring. Plus started to re-read the theory of the escapement and how to analyse the graph on the timing machine: Greiner Chronografic Record manual. I am also thinking to put the watch on a 24 hour long run with the eTimer SW it once helped me to figure out what was wrong with a watch. There is an interesting part of the Greiner record manual talking about the pallets and the end shake of the balance and pallet staff. Maybe this is my issue? Who could that possibly identify? After a few years now I am still without a clue how could watchmakers make parts I can only see with my microscope or how could/can they carry out complicated services impossible to do.. real magic..... .... ..... before I sent this post while the pics were uploading I had an idea, i was browsing the possible outcomes on the timing machine I had one for magnetism..... so I demagnetized the movement and it is not hairy now.... two really nice lines 0.2 ms beat error still a bit wavy, but a lot lot better..... argh....
