Today's great deals
Sometimes we all come across some equipment for the workshop which can be a really good offer. But sometimes we already have it, or there may be plenty for sale. Therefore, share a great deal in this thread. In this way we reach out to all parts of the world and can help each other.
Bergeon 2802 for about 80,- euro + 18,- euro for shipping in most EU.
Sorry, I had not zoomed in enough to see that it had damage at first glance. But still the opportunity for savings if you are considering a new one!
BUT it needs new Ruby Jaws cast about 250,- euro 😞
Total 348,- Euro
New from Cousins 630,- euro
https://www.tradera.com/da/item/1922/526091183/bergeon-2802-balansvag
Edited by maclerche
On 2/22/2022 at 2:35 PM, jdm said:
Seems like a case of "too good to be true"
I bagged this deal about a two weeks ago.  Two were marked Bergeon others marked "Jurgensen" or no markings but all Bergeon quality...steel arbors, crank handles, dowel pins and plungers in the winding drum.
Auction was only active for 15 mins when I saw the insanely low BIN price.
    • HWGIKE#57 Valex FEF 190 15 jewels Swiss lever full service and repair This one was waiting for a balance staff replacement in my cabinet parts and case cleaned up with a new balance staff and a 4th wheel as the original 4th wheel had a broken pivot for the off center second hand. I never attempted a balance staff replacement before however I received a Bergeon Molfres (i was hunting it for about 2 years) and with the help of it I managed to remove the old staff and riveted the new one in. It also received a new MS, crystal and the hole for the MS arbor was also tightened. With the new MS now it has an acceptable performance meaning that the amplitude goes up to 280 fully wound, has an acceptable beat error and I have the two nice lines but only dial up, dial down is not as nice and I could not figure out as why. I have the two lines but the amplitude is dropping to around 230 and the lines are a bit hairy. Both dial up and dial down the lines just go up and down without seemingly any pattern. I cleaned the movement two times, and then a 3rd time pegged out the main plate and train bridge holes but made no change. Both the HS collet and the roller table was too lose on the new staff... I did not count how many times I took the balance cock off to sort out the HS collet, the roller table and the beat error, somebody before me also shortened the HS by pushing it out a bit and it seems every time somebody is messing with the end of the HS the protruding bit is most of the time twisted bent etc. This one was probably one of the most challenging repair and service. I might take the new MS out and clean it lubricate it as I just pushed the new one in to the barrel from the retaining ring. Plus started to re-read the theory of the escapement and how to analyse the graph on the timing machine: Greiner Chronografic Record manual. I am also thinking to put the watch on a 24 hour long run with the eTimer SW it once helped me to figure out what was wrong with a watch. There is an interesting part of the Greiner record manual talking about the pallets and the end shake of the balance and pallet staff. Maybe this is my issue? Who could that possibly identify? After a few years now I am still without a clue how could watchmakers make parts I can only see with my microscope or how could/can they carry out complicated services impossible to do.. real magic..... .... ..... before I sent this post while the pics were uploading I had an idea, i was browsing the possible outcomes on the timing machine I had one for magnetism..... so I demagnetized the movement and it is not hairy now.... two really nice lines 0.2 ms beat error still a bit wavy, but a lot lot better..... argh....
