Hello again.
I am new to the hobby. I have an ETA 2789-1 movement. The stem has snapped near to the movement body. I have attached photographs. My question is:-
Do I have to disassemble the whole movement to achieve a removal? As can be seen, the stem release pin seems to be solid. Can I get to it without have to remove all?  I am worried that as I have a lack of expertise I will not be able to get the movement back together. I have purchase a replacement crown and stem.
Any advice, positive or negative, would be appreciated.
Thank you
Ross
You can get to the stem and nudge it out by removing a few parts and the calendar ring on the dial side.  Here is an image of a 2778 in the same family.  As shown in this picture, you can probably lift up the detent while nudging out the broken stem.
Hi Ross.
ETA 2789-1 has a date ring so you will encounter fiddly springs if you attack from dial side, but not much can go wrong when you approach from the rotor side.
So take pix as you go.
 Remove the two screws( gun metal colour)  to the auto device,   the module with rotor attached will come off.
Release barrel power by pushing the crown wheel ring aside.
Remove ratchet wheel screw
 Remove barrel bridge.
You have access to the stem.
Good luck
Yeah, @Nucejoeis giving the more conservative route.  Here are some pictures that might help.
In my disassembly, I took the balance out after removing the AW assembly, but you do not have to.
Edited by LittleWatchShop
  • Thanks 2
Hi Ross I see the members have come to your assistance, have you tried a little releasing agent   ie WD40 on the release to soften any gunk before taking it apart as suggested, Although If you are stripping it to cleanand lube no problem, do as the chaps have suggested.    good luck
Safer is to remove the balance as you did, but I am not sure if Ross has practiced pulling out  balance and cock.
Regs
Many thanks. So good to have help like yourselves.
I am at the stage where I have the items (tools) to do. basic tool kit. Cleaning tools, ultrasonic, oil and oilers. I can as suggested, remove a balance. I can see what 'LittleWatchShop' is suggesting. I'll try that way first. Crown wheel screw removal.  Job for tomorrow. I will keep you all posted.
Regards
Ross
Update. Got as far as crown wheel removal. Bottled out doing more. Put it all back together. Will do the same and more again tomorrow. Ratchet wheel and barrel. The bridge over the keyless works (probably got all the names wrong). As suggested, I've also used a cotton swab with WD40 and applied it to the broken stem and release.
Ross
Well, here I am. I have removed the keyless bridge. The stem is slightly moveable. However I cannot pull it out. The peg?, cannot be depressed to obtain a release. What is my next step. Do I need to remove the calendar? Photographs attached.
Ross
Tricky.  I have been in similar situations before...some far worse than this.  I think there is some rust and/or corrosion that has occurred.  At this stage, I would drop some penetrating oil on the keyless works and let it set for awhile...maybe a day.
Then, using a small screwdriver, wedge where I have shown and twist, applying outward radial force on the stem.  You will probably have to re-dress your screwdriver after this.
Alternatively, I would remove EVERYTHING else from the main plate and immerse it in penetrating oil...again...for a day or so.  The try again.
A possible, yet more dangerous next step would be to construct a jig so that the plate can be mounted orthogonal on a staking tool and tape down (an inward radial force) because there appears to be some room for it to move in that direction.  This is a last resort solution IMHO.
  • Thanks 2
 So the stem could be stuck either to the crown pinion or sliding pinion or both,  as said penetrating oil helps.
Stem release button looks pushed down enough to release the stem, in addition to what littlewatchshop shows you got access to more point to grab the stem, for instance the big groove on the winding crown side.
If no joy, I often loosen bridge screws on the gear bridge, half a turn the screw close to the balance , one and half turn the other screw, this will let you raise the gear bridge a little and  slide the barrel out, there will then be enough space to press the stem out by pressing on the stem end with a pair of thin long nose pliers as pliers press on the stem end strong enough to break it loose of anywhere its stuck.
So far you have had no spring to jump out and get lost. if no tool slips you have done just fine.
Is the stem release button stuck?    Appears ( refer to image) pressed all the way in.
Usually a part rusted or stuck due to rust means a clean and lube is long overdue.
The stem release button will not move when being pressed. The stem, using tweezer can rotate and appears to move linear. The sliding pinion does slide. The winding pinion winds with the stem but does appear lose.  What is the stem release button attached to? I can't seem to find that detail in the parts listing.
I tried the hard pressure by screwdriver. No joy.
Good fun though. Loving learning.
Ross
A spring ( keyless bridge) pushes on the stem release, which keeps it in place.
You are close to a full tear down, a clean and lube is seems inevitable.  When you get to tearing the date complication, do so inside a ziplpc bag, no part can flies out of the bag.
I don't see howelse you can clean the keyless.
Nucejoe
What a really good idea 'do so inside a ziplpc bag, no part can flies out of the bag'. I'll do that.
Why, you may ask? My bride found two gears I did not know I had lost She wanted to hoover our floor. But, before she did, she spent time using a large magnet over the floor. I said 'No need'. She said, 'Just in case'.
Ross
49 minutes ago, rossjackson01 said:
Nucejoe
Ross
  I also spread a large white plastic sheet on carpet at home, the type of sheet  used for big table mats  and sit in the middle of it to dismantle movements, parts that fly will often land on it and can be easily spotted. One obviously wouldn't do so in a watch shop and become a laughing stock to others.
If it works, it works!
Aha! I was thinking something different, as in you were disassembling the movement in a big see-through bag.
'A picture paints a thousand words'!
More like when Mr. Lovick uses a plastic sheet to protect hands when being levered off.
You beautiful people. Done it. 95% of it anyway. Last piece is rusted solid. Don't know the name of it. Letting it soak overnight as suggested. Was able to move it which released the broken stem.
Feel so chuffed. Thank you
Ross
 I let all discoloured pieces soak in Coca-Cola for 48hrs, then rinse under tap, use powder laundry detergent as abrasive and a used tooth brush to scrub the parts with,  you be surprised with the result,   its then ready for a bath in ultrasonic.
Thank you LittleWatchShop. Did not realise that the part was the setting Lever, or that is was in two pieces.
Nucejoe. Coca-cola? Trip to the Supermarket for me tomorrow. I've not drunk Coca-Cola for over 40 years. My Ultrasonic bath arrived today. cheap one. I need to watch a few videos on how to use the thing. All the directions are in Chinese.
Regards
Ross
    • HWGIKE#57 Valex FEF 190 15 jewels Swiss lever full service and repair This one was waiting for a balance staff replacement in my cabinet parts and case cleaned up with a new balance staff and a 4th wheel as the original 4th wheel had a broken pivot for the off center second hand. I never attempted a balance staff replacement before however I received a Bergeon Molfres (i was hunting it for about 2 years) and with the help of it I managed to remove the old staff and riveted the new one in. It also received a new MS, crystal and the hole for the MS arbor was also tightened. With the new MS now it has an acceptable performance meaning that the amplitude goes up to 280 fully wound, has an acceptable beat error and I have the two nice lines but only dial up, dial down is not as nice and I could not figure out as why. I have the two lines but the amplitude is dropping to around 230 and the lines are a bit hairy. Both dial up and dial down the lines just go up and down without seemingly any pattern. I cleaned the movement two times, and then a 3rd time pegged out the main plate and train bridge holes but made no change. Both the HS collet and the roller table was too lose on the new staff... I did not count how many times I took the balance cock off to sort out the HS collet, the roller table and the beat error, somebody before me also shortened the HS by pushing it out a bit and it seems every time somebody is messing with the end of the HS the protruding bit is most of the time twisted bent etc. This one was probably one of the most challenging repair and service. I might take the new MS out and clean it lubricate it as I just pushed the new one in to the barrel from the retaining ring. Plus started to re-read the theory of the escapement and how to analyse the graph on the timing machine: Greiner Chronografic Record manual. I am also thinking to put the watch on a 24 hour long run with the eTimer SW it once helped me to figure out what was wrong with a watch. There is an interesting part of the Greiner record manual talking about the pallets and the end shake of the balance and pallet staff. Maybe this is my issue? Who could that possibly identify? After a few years now I am still without a clue how could watchmakers make parts I can only see with my microscope or how could/can they carry out complicated services impossible to do.. real magic..... .... ..... before I sent this post while the pics were uploading I had an idea, i was browsing the possible outcomes on the timing machine I had one for magnetism..... so I demagnetized the movement and it is not hairy now.... two really nice lines 0.2 ms beat error still a bit wavy, but a lot lot better..... argh....
