I have been asked to “get it going” this small Smiths floating balance clock.  The customer had no key as he inherited it. I have given it a wind and it is up and running in test.
5B275D82-0E28-4E58-9ECB-8C902BF150F6.thumb.jpeg.0e1daa66d5fd1c1fc09ac19baebf3c4d.jpeg09F996CE-32C2-423D-8B95-826CC0A2A6C1.thumb.jpeg.20b209c6be2c041f4149ab3122b0a65b.jpeg
1 hour ago, watchweasol said:
Nice clocks  nd good runners  The floating balance can be a bit of a bother to regulate.  It was licensed to Smiths from Hermle.  I have attached a document on the balance     ,( probably teaching Granny to suck eggs ),        hope its use full
Thanks for the attachment.. Looking the movement is a later model and it looks very clean. It’s still running great so it might be just a clean up the case and return.
Wear is often found around the escape wheel on these so you might need to remove that small plate. I always used to put a very tiny drop of pocket watch oil on the top part of the floating balance then move the balance up and down so it has a little lubrication.
clockboy you should know better it isn't a chime. You should stand in the corner and go to bed without having any tea. 🤣
😔😔OK OK, it strikes the hours and half hours. 😊
