Today's project.  Two questions:
1) Cleaning with amoniated solution OK?  (I know this is discouraged for French clocks)
2) What is the rational for putting a plate screw UNDER the escape wheel???  I guess I use needle nose to remove???
Cleaning with amoniated solution OK, Yes I would have used Horolene clock cleaner. The escape wheel bridge is as you can see riveted to the main plate, do not bend it. When you take the plates apart that is when you can remove the wheel, don't for get when putting it all back to include the escape wheel. Nice to see its all complete including both stop works so many go missing.
Hi LWS   they work like the stackfred, Maltese cross work in pocket watches. the spring is tensioned about two/three winds then the stopwork is fitted . The idea being that the clock uses the center of the spring and not the ends so there is a constant torque on the movement and no top end power or low end loss
19 minutes ago, KarlvonKoln said:
That is a beautiful movement.
And it is in really good shape.  The plates are in good shape and no issues that I can find.  I believe that it is vintage late 1800s.
13 minutes ago, oldhippy said:
It sure looks good. American clock movement are always rough and ready compared to French.
From my little bit of research, it appears to be from the late 1800s...maybe 1890 or so.  Is this consistent with what you know?
The alarm unit is missing.  I can see where it was mounted in the case, and the bell is still intact.
34 minutes ago, oldhippy said:
What is the name on the clock plate. Is there a label on the case as depending the type can also pin point it to an exact date.
  Here is a video that gave insight as to the age.
According to the guy doing the video, this clock was made May 1885
