Gotham Eta 1080
Pick up this from the flea market for 7 quid, it not working.
Its a bubble back, held by 4 grub screws, some  of the screw are missing and that one on the left was something else.
Take some doing to get the case split.
I was not sure how to get the stem out so I carefully remove the dial to see if there any screws,to turn or lever to press.
But there is none, under the dial... what I can see is the Setting Lever Spring broken, that one reason why this watch didn't work.
Finally I brave myself to pull the crown, well it detached.. so its this type of fitting.
Here the movement.. ETA 1080.. the Setting Lever Spring available from Cousin, and I'll strip this movement to check what else needed. For sure I need those grub screws to hold the case, but that not part of ETA but Gotham..
Will update, as I strip it further... and will source the parts once I know what else needs replacing. The main spring may not be in a good shape.. :(
Affnan
Edited by Affnan
Hi Affnan,
To release the stem, loosen the screw circled about 1/2 to 3/4 of a turn.  You should then be able to extract the stem.
Hi Lawson
Thanks for the tips, manage to strip all the parts. I was unsure how to get the movement out since the case back prevent me from getting to that screw. Until I pull off the crown then it is as what you suggest.
Update
The main spring broke need replacement, so only 2 items needed the setting lever spring and the main spring. Not too difficult to get for this movement.
Strip clean will assemble after I got the spare.
BTW, what cleaning fluid can I use with ultrasonic cleaner. Currently I use alcohol, but not on all parts.
Affnan
Edited by Affnan
I've been away and now I see this excellent thread. Good job Affnan! Keep it up.
As an aside, rust is inhibited with tea. Just put the parts in tea, then you can use a fiberglass rust bruch. In the case of the winding wheel you can sand the surface with the grain using ever fines sand paper until the rust is gone...but careful since when it is pitted I would order a new one...if the price is right.
I hope this helps,
Cheers,
Bob
Thanks Bob, this a new one to me, previously I use coke for bike and engine parts to stop rust. I must try tea for watches now, wonder what would happen if I put tea in the ultrasonic cleaner. Underside of the winding wheel is good, no rust. It is good to replace if the price is right. However I'm in a bit of a pinch right now, see my Avatar I'm the certified instructor on that plane and the missing 370, we are really in bad shape. This watch repair exercise has help me to calm my nerve due to heavy stress.
Most of the watches I'm doing now are from the flea market where I can pick it up for less than 10 quid, it a safe way to practice but I will make sure it's having a Swiss or a least a good Japanese movement inside.
Affnan
Edited by Affnan
    • HWGIKE#57 Valex FEF 190 15 jewels Swiss lever full service and repair This one was waiting for a balance staff replacement in my cabinet parts and case cleaned up with a new balance staff and a 4th wheel as the original 4th wheel had a broken pivot for the off center second hand. I never attempted a balance staff replacement before however I received a Bergeon Molfres (i was hunting it for about 2 years) and with the help of it I managed to remove the old staff and riveted the new one in. It also received a new MS, crystal and the hole for the MS arbor was also tightened. With the new MS now it has an acceptable performance meaning that the amplitude goes up to 280 fully wound, has an acceptable beat error and I have the two nice lines but only dial up, dial down is not as nice and I could not figure out as why. I have the two lines but the amplitude is dropping to around 230 and the lines are a bit hairy. Both dial up and dial down the lines just go up and down without seemingly any pattern. I cleaned the movement two times, and then a 3rd time pegged out the main plate and train bridge holes but made no change. Both the HS collet and the roller table was too lose on the new staff... I did not count how many times I took the balance cock off to sort out the HS collet, the roller table and the beat error, somebody before me also shortened the HS by pushing it out a bit and it seems every time somebody is messing with the end of the HS the protruding bit is most of the time twisted bent etc. This one was probably one of the most challenging repair and service. I might take the new MS out and clean it lubricate it as I just pushed the new one in to the barrel from the retaining ring. Plus started to re-read the theory of the escapement and how to analyse the graph on the timing machine: Greiner Chronografic Record manual. I am also thinking to put the watch on a 24 hour long run with the eTimer SW it once helped me to figure out what was wrong with a watch. There is an interesting part of the Greiner record manual talking about the pallets and the end shake of the balance and pallet staff. Maybe this is my issue? Who could that possibly identify? After a few years now I am still without a clue how could watchmakers make parts I can only see with my microscope or how could/can they carry out complicated services impossible to do.. real magic..... .... ..... before I sent this post while the pics were uploading I had an idea, i was browsing the possible outcomes on the timing machine I had one for magnetism..... so I demagnetized the movement and it is not hairy now.... two really nice lines 0.2 ms beat error still a bit wavy, but a lot lot better..... argh....
    • Wie ging die Sache weiter?   please use English for your posts    Tom
