Hi everyone , I told you it wouldnt be long before i started pestering you with my stoopid newbie questions , so apologies in advance and let it begin 🙂
I was rumaging around in a box of some old watches of my fathers looking for something to take apart and try to rebuild … most of them are in various states of disassembly with who knows what missing , but i found this Rotary 2824 in a tub on its own , it has been partially disassembled but it looks like most of its there and complete, i have the rotor and most of the winding system… i think.
The stem came out ok and the two small screws which i thought secured the movement , there were no small tabs under them.
But the movement will not come out … It will quite freely turn inside the case , but it wont lift out …
There is a “movement ring” i think may be the name , but i cant get it out … I dont know if it needs to come out or if the movement should just lift out now. I have tried to persuade it but it wont budge or turn … In a couple of the pics it looks like its maybe jammed at an angle, but it isnt …. its evenly protruding from the case back.
I have tried to search for info here and on you tube … but no joy … removing the movement ring seems to be a step that just happens before the real work begins …..
Am i missing something extremely basic here ?
Sorry, i seem to have failed at the first hurdle 😞
Ian
I think what you have there is a "front loader".
Could you post some photos of the front and side view so we can advise you on how to remove the crystal to get the movement out from the front?
 Hi there HectorLooi , Thanks for the quick reply , I hadnt thought of a "front loading option" ... why didnt i start with something simple !!!
 Ive attached some quick phone snaps of the front , and there does seem to be a groove .....
I guess it would make sense ... maybe a good job i didnt get too rough with it 🙂
cheers
Ian
From photo 2, 3 and 4, I can see a gap under the bezel ring. But that is a very high dome crystal, so I'm not sure if this is the type where you remove the bezel and the crystal comes off or the type where you need a "claw tool" crystal lift to remove the crystal.
I think it's better to wait for other more experienced members to chime in.
Pop off the bezel by prying a knife in the gap as mentioned by Hector.
The two screws that retain the movement will give you the biggest clue as to how the movement comes out. If they are just two screws braced against the case it is more than likely the watch movement will come out the front. If the two screws hold a little plate which is trapped under a lip in the case then the movement will probably come out the back. There are other methods to retain the movement but observing the screws and what they are doing will help.
Eg if the two screws just screw out, you need to ask yourself what good are they if the movement comes out the back?
HTH
Anilv
Thank you everyone who replied.
It was indeed a " front loader ".
The bezel and crystal popped off quite easily and out it came... my first watch strip begins...
Now i can start the disassembly. watchweasol, your pdf is much appreciated. Between that, VWatchies pics and some i will take myself .... hopefully i can get it cleaned and rebuilt.
I'll keep y'all posted.
Thanks again
Ian
Hi everyone
An update , and another plea for help here 🙂
I stripped the movement keeping as many of the small assys together as possible ... there may be one or two screws who pinged out into another part of the dish and got mixed up ... but i think all is now good.
I have since cleaned all the parts in a small ultrasonic cleaner using zippo fluid and an IPA wash to remove residue... so all is now clean. The barrel and spring were cleaned by removing the top of the barrel and putting it in the cleaner complete with the spring still in the barrel ... Its definitely cleaner than it was ... I will think about manually unwinding / winding the spring another day.
Reassembly has been going well so far ... thoroughly enjoying myself.
But now to my first issue ... The click spring ... When i put it back in its slot ... it seems to stick up a lot higher than the top of the groove and the crown wheel i think its called dosent sit flat ... it just seems wrong to me.
the click spring is 0.54mm tall ... which is much taller than its slot.
It must have been like that when i took it apart , i think, I havent been messing with any other watches  yet.
Any suggestions to what im doing wrong from the attached pics ... surely the crown wheel dosent sit at an angle on top of the click spring ?
I dont have a "build manual" for the older 2824 , just the 2824-2 from watchweasol ... and i didnt take any detail photos of the dissasembly as i thought the dissasembly / assembly pics from VWatchies thread would have been awesome enough ... they are great pics  ... but obviously there do seem to be a few differences on the -2 version.... oops.
Thanks in advance
Ian
PS as you can see from the blue tray , there is another small spring with a rounded end ... I have no idea at the moment where it came from, it also just pinged out ... so if anyone has an idea ....... 🙂
Edited by wolfmanjack
Your 2824 looks strange. It doesn't seem to have the usual combination yoke and setting lever spring. Perhaps that thick spring you are using as the click spring is the setting lever spring. The other finer spring with the rounded end also doesn't appear to come from a 2824.
If you have a guitar lying around the house, you can make a click spring yourself quite easily. Just cut about 15mm of the thinnest string and bend it into shape and cut the ends to the correct length. 5 minute job.
Thanks for the suggestion Hectorlooi , I dont have a geeetar , wish i could play tho ... but the local model shop say they have some 0.35mm piano wire , marginally thicker than a 0.28mm guitar string ... but defo thinner than the 0.54mm spring thats in there now ... I shall pop in and get some in the next day or so and bend one up... i can do that 🙂
Thats definitely the spring i took out of there, but ... i guess i am now going to find out the downsides to starting with an old movement from a scrap box .... I thought all i needed to do was order a new balance complete , clean , lube and reassemble it ... first build , job done .... maybe not !!!
The other rounded spring i'm not sure about , though it definitely came out of the movement somewhere ... i guess i shall have to just carry on reassembling it sub assy by sub assy and see how much works and what dosent ... i did note on strip down that there wasnt a "stop lever " fitted as well ... tho i am assuming this just wasnt a part of the older movement build.
I have now reassembled the "keyless works" parts and they seem to be working so far ... i guess i now need to get the click and crown wheel parts back in next .... i hope my terminology isnt too far off... i sometimes i think i spend too much time researching / surfing and not enough time actually producing results !!!
Anyway , thanks again for the advice and suggestions ... and my ramble is over for tonite  🙂
cheers
Ian
Expand
Lol...finally a use for spent strings. I have been playing since 1965...so many strings to the landfill.
Hi LWS , thanks for dropping by ... and i think i may have saved this ole spring from landfill 🙂
Just as i was thinking of heading out for the 45 min drive to the modelshop today i had an idea ... if i can just "make a new spring" ... then why cant i just fix the old one ..... so in about the same time as it would have taken me to drive there ... i had sanded two fingertips almost through to blood ,oh aye , and also sanded the spring down to about 0.3 ish mm thick  ... job done ... and saved me 75p in the process .... typical Jock living in Yorkshire, what else would you expect 🙂
Anyway , it seems to work fine .... So i crashed on with the rebuild ... and am now down to the last couple of pieces ....
And .... my next question.... " That other spring "
Everything else seems to have gone back together fairly straightforwadly , and i am now at the last bit, around the datewheel clicker area, and this is where my old original 2824 seems to differ a bit from a modern 2824-2 according to my pics.
I think i have the little hooked actuating arm in the right place to check / advance the datewheel .... the date jumper maintaining plate and its wee wheel are straightforward enough .... but that little arm that seems to be the date jumper ... needs to be sprung, and im sure this keyhole shaped spring item is it .... BUT i cant figure out how it goes in there to work against that wee arm .... sorry for my iffy descriptions.
I have attached a couple of pics showing the pieces i have and where i roughly think the spring could go but i just cant see how it fits in .... does anyone have a suggestion , or a pic / document showing how it should be assembled ?
Apart from that my movement is all back together and just waiting for its new balance complete to be fitted and then i'll see if it runs .... although if i cant get this date jumper springy bit finished its going to be the first item in my new junk / spares box 🙂
cheers
Ian
Aye, that it is,  but the tech sheet watchweasol attached is for a 2824-2 .... obviously ETA have made changes from when they released the original 2824 just over 50 years ago , then modified it to become the 2824-1 and finally modified to the current 2824-2
I havent been able to find a tech sheet or parts diagram etc for the original 2824 anywhere on tinternet ... which probably isnt much of a surprise given my limited search abilities 🙂
Everything just seems to refer to the -2 version.
hopefully someone out there may remember this old dinosaur movement ....
cheers
Ian
Good job so far. You're almost there. Don't go crazy with the dial. Just blow off any dust and dab off any smudges with Rodico.
The crystal looks ok. A good polish with some of the new type of foam backed nail buffs will have it looking like new in no time.
Hi guys
Sorry WW , i'm not seeing anything with a similar assembly in your docs , there is a spring which looks similar but it seems to be used in a different place ... the 70s 2824 remains a mystery to me.
Hi Hector , I'm not going to go crazy with the dial ... In fact i think the whole thing is about to go back in the box ... the original idea was to see if i could strip n build and work with the small sizes involved  .... I think its been a reasonable success ... the size dosent bother me and i think ive learned a few things from this first attempt ... the main thing ive learned is i need to take pics and make notes of the movement that i am working on and not rely on others pics of their movements and docs which may be the same , similar or something in between.
I will return to this one another time , but for now i need another movement ... i think i need to start this time with one which works and see if i can take it apart and make it work again... and maybe not quite so vintage this time.
cheers
Ian
    • Did you just swear at me matey?? I’m sorry, I’m not divulging personal information but there’s always personal reasons. There’s not much more than I can do other than plod along as best I can. However, my health is good now and I’m regularly getting plenty of exercise to keep it that way 👍
    • Same question that was asked last time Hakan, and emphasis was placed on it. It was ignored. The thread should still be there, if not I have a copy of his reply.
    • This is probably the single most important point. One of my best friends, 48 years old at the time, suffered a massive stroke about 15 years ago. He barely survived, but his life was never the same after that. If you had asked me back then to guess which of my friends might have a stroke and nearly die, he would have been the very last one I'd have picked. He was perfectly healthy, played tennis three times a week, ran a successful business, was full of life, and had a wonderful wife and well-behaved teenage kids. The harsh truth is, we never know when it’s "game over." @Mark, I truly wish you a long, happy, and successful life. But have you given any thought to some kind of backup plan for WRT in case the worst should happen? Is there anyone who could keep the site going? If you can reassure us in some way, it would mean more than a lot to us!
    • Update: The demagnetization only helped temporarily, maybe it pulled the wheels into a position where they liked each other. I have to adjust the sub second hand as it is a bit angled upwards and catching the minute hand stopping the whole movement but before this happened there were some wild deviations. HWGIKE#58 Alarm clock, cooked in hot cleaning fluid and oiled gently. This is a movement so I count it. 🙂 A while ago it tried to fly away one day, it was on my windows sill, we had strong wind the curtain flew like a flag and doing so encouraged my clock to do the same...  went out and ended up on the roof above the entrance door, its door in pieces but the clock itself suffered no damage otherwise. The original glass was already broken when I received it I still have the bottom part in two pieces. The new "glass" is acrylic. It also had a paper in the back in the case inside but it disintegrated, I still have a little bit of  piece of that too.     HWGIKE#59 Durowe 870 / Times M84 This particular instance is a D870, when I saw its worn out contact pin I thought that it must be a design flaw, and here we go: https://17jewels.info/movements/d/durowe/durowe-870/ An incredible movement again where the balance wheel drives the train and has two magnets one for the balance wheel/coil and one for the pallet. The magnet for the pallet is basically the "draw" one direction. The coil is about 1.8kOhm and one end is in contact with the main plate and the other end is soldered to a contact pin which is insulated by the means of putting it into a jewel and this contact pin is rubbing against a wire getting the energy/impulse as it is passing. Behind the contact pin there is an "impulse jewel" not sure why is it there... the wire seems to hit the impulse jewel first then the contact pin but maybe it is there only for insulation purposes? I was almost certain that the screw holding down the battery - (minus) clamp had no insulation washer.. i only noticed the green stuff around it coming from battery leakage... anyway the + and - had a shortcut which took me a while to realize.. had to fabricate one insulating washer on my own. The jewel settings were dirty but not it is all cleaned and oiled. The contact pin might work for a while but I am sure it has a short life. It is a front loader the whole thing is held together by the case so it is not possible to regulate it without putting it all together and taking the movement out of the case again, very inconvenient. A wonderful movement but not made for eternity only for the consumer market.
