Hi everyone can someon tell Me if a can lubricate miyota quartz watch movement have cleaned it but not sure if a can lubri?
Expand
Expand
  On 3/11/2022 at 1:44 AM, HectorLooi said:
Can you post some photos of the movement, as Miyota makes many models.
How did you clean your movement?
Expand
With a watch cleaning machine a left out the rota,coil, crystal.
I would use Moebius 9000 Quartz oil on all the pivots. For the keyless, motion works and calendar works, lubricate as you normally would for a mechanical watch.
Expand
Personally for me any quartz watch this is the oil of choice. Otherwise worst-case use the lightest oil you have. For instance ETA recommends Moebius 9014 Which has a viscosity of 100 which is lighter than 9010. The problem with heavier oils are worst-case the watch won't run or usually just bumps the current up because there's too much drag.
