Custom Desktop Bench
Yes, the t-rest hight is not critical when using this method.
Just received today: For only ~60$ * (*) ~140$ with shipping and custom fees. 3.80 Kg The pressure should be able to reach up to 6 bars. The glass is thick The closing system seems to be sturdy. I'll submersible locking system (I will make a notch on top to note the opening position): I put 3 bars at let it for 20 minutes, the pressure didn't leaked at all. Next steps: Quick wash, maybe put some silicone grease on the seal of the lid ? First test I'll do: Put deionized water til the red line Put a diver case in the tank, keep it outside the water Pump (10 ~ 20 times?) to reach 3 bars (0.3MPa) Wait at least 1 minute Dip the case into the water Gently release the pressure and observe To be continued... All comments are welcome
Hi all - I was just watching Clickspring's series making a custom faceplate and he demonstrates the "wobble stick" technique for centering. I was already familiar with this and it is all straightforward. But how does one set the height of the T rest so that it acts as a truly level fulcrum? Or does it actually matter if the fulcrum is perfectly level with the hole you're trying to center? As I type this I'm realizing there should not be any motion at the other end of the stick even if it is at an angle relative to the work, and isn't pointing even with the tailstock center. Do I have that right?
