Help with chiming mechanism on Seth Thomas quarter hour!!!
LittleWatchShop
OK, once assembled, there is not enough power to drive the chime side.  These electric clocks wind a mainspring, kinda like an autowind on a watch I suppose. The springs slips when it gets to some amount of tension.
I did not open these barrels up because it does not look like these wheels/barrels are designed for maintenance.  Thus I did not clean the mainsprings or even inspect them.  Here are a couple of pictures from the previous repair.
This clock is gonna kill me.
Well, once I learned how the autocorrect works, I opened up the other clock that I had fixed to make a slight adjustment.
Bad news.  The wire on the motor was so frail that they broke off.  Motor is dead.
These Sangamo motors are long since gone.
I could retrofit it with a modern motor using PWM control to get the right speed.  I will ponder this.  A long term project.
Yesterday I discovered that the chime spring just could not drive the hammers.  Ugh!!  The hour chime seemed robust.  Lacking any other strategy, this morning I switched the springs.  This is only about the sixth time to tear down and rebuild!!  With the springs switched, the chimes seem to be working now.  It is in testing now...we shall see how it goes.
I wish I had a dozen more of these to work on now that I understand everything about assembly and calibration.
In yesterday's search I found a guy in the US who repairs these things.  He charges $1200.  I can understand why!!!
Hi LWS  the chine spring is always the stronger of the two , It has more work to do. when dismantling three train clocks always label the barrels, and if removing  springs for cleaning do them one at a time and put them back in the barrel before moving on tho the nex one to avoid mixing springs and barrels.  You will be the expert now.
With a strike or chime always have the correct number of tubs to put the parts in, that way you won't muddle things up. The chime spring is always stronger and you will find the barrel bigger and so will the arbor, on the strike and going sides quite often the complete barrels are the same size. Always best to mark them with something that doesn't leave a permanent mark.
Most of the time the clocks I see the barrels, lids, and train wheels are already marked by a previous repairman... usually with HUGE deep scratch marks 😅. If I need to mark them I do it as you say, in a non permanent way, or just keeping them separate during cleaning.
I am still having fits with this. Yes, with the springs in the correct places, the chimes do have more power...but not enough. These springs are designed to slip since they are constantly being wound be the electric motor. There is an auxiliary winding mechanism using a key.
last night, I disabled the chimes which takes the load off of the chime train which allows each quarter hour to cycle properly. My theory here is that the spring will find its natural equilibrium. May be just hocus locus thinking...dunno. It may simply be that the spring is old and weak. I see no way to service it, as it appears to be a sealed unit.
this morning I will see if my abracadabra worked.
Well...not there yet.  I noticed that the chime has trouble starting, but once started, it goes fine.  I noticed that one of the wheels in the train was "bumpy" in that I could do an end shake test and it would kind of lock in two positions is if there were a bump the pivot was riding over.  Here are some microscope pictures.  The pivot hole is not a great picture, but it definitely has some discontinuity.
I can polish the wheel pivot easily enough on the lathe.  What is the best approach for the hole.  Broach it???  I do not want to re bush it because I have not done this before and dont want to practice on this clock.
While I am at it, I am going to polish all of the pivots in this train.
  • 2 years later...
Following up on this old thread.
I bought another one of these clocks on ebay (I just love these old electrics with Westminster chimes).  Did a full disassemble and clean and had the same issue with the chime not having enough strength.  Well, since the last one I serviced, I learned how to disassemble the MS barrels.  I guy on the NAWCC forum had done it.  The picture I am attaching is from him (I did not take pictures).  So, I took this clock apart again and disassembled the chime barrel.  Oiled the spring, and reinstalled.  Wow, it made a world of difference.
I would say this is the most complicated horological unit I have ever worked on.  Complicated, because there are five different things that must be calibrated...one of which must occur while assembling the plates.  While I have worked on more complex watches (alarm watches), there is no calibration beyond setting the hands.
2023-04-01 10_09_44-My First Seth Thomas Electric _ NAWCC Forums — Mozilla Firefox.png
2023-04-01 10_09_52-My First Seth Thomas Electric _ NAWCC Forums — Mozilla Firefox.png
    • HWGIKE#57 Valex FEF 190 15 jewels Swiss lever full service and repair This one was waiting for a balance staff replacement in my cabinet parts and case cleaned up with a new balance staff and a 4th wheel as the original 4th wheel had a broken pivot for the off center second hand. I never attempted a balance staff replacement before however I received a Bergeon Molfres (i was hunting it for about 2 years) and with the help of it I managed to remove the old staff and riveted the new one in. It also received a new MS, crystal and the hole for the MS arbor was also tightened. With the new MS now it has an acceptable performance meaning that the amplitude goes up to 280 fully wound, has an acceptable beat error and I have the two nice lines but only dial up, dial down is not as nice and I could not figure out as why. I have the two lines but the amplitude is dropping to around 230 and the lines are a bit hairy. Both dial up and dial down the lines just go up and down without seemingly any pattern. I cleaned the movement two times, and then a 3rd time pegged out the main plate and train bridge holes but made no change. Both the HS collet and the roller table was too lose on the new staff... I did not count how many times I took the balance cock off to sort out the HS collet, the roller table and the beat error, somebody before me also shortened the HS by pushing it out a bit and it seems every time somebody is messing with the end of the HS the protruding bit is most of the time twisted bent etc. This one was probably one of the most challenging repair and service. I might take the new MS out and clean it lubricate it as I just pushed the new one in to the barrel from the retaining ring. Plus started to re-read the theory of the escapement and how to analyse the graph on the timing machine: Greiner Chronografic Record manual. I am also thinking to put the watch on a 24 hour long run with the eTimer SW it once helped me to figure out what was wrong with a watch. There is an interesting part of the Greiner record manual talking about the pallets and the end shake of the balance and pallet staff. Maybe this is my issue? Who could that possibly identify? After a few years now I am still without a clue how could watchmakers make parts I can only see with my microscope or how could/can they carry out complicated services impossible to do.. real magic..... .... ..... before I sent this post while the pics were uploading I had an idea, i was browsing the possible outcomes on the timing machine I had one for magnetism..... so I demagnetized the movement and it is not hairy now.... two really nice lines 0.2 ms beat error still a bit wavy, but a lot lot better..... argh....
