I have got my hands on a Vulcain Wall World clock, which is to be hung up in the workshop. However, there are some challenges. More second hand are missing, so i have
to find someone who can fit?  I think the easiest thing is to change them all.  Since the watch is from the USA it is 110v so I also have to convert from 230v to 110v!  An alternative is to switch all drives to Quartz.  What would you do?
Edited by maclerche
Show us an image of the back.
Converting from 110 to 220 is a transformer...pretty simple.
No, do not convert to quartz.  By staying with the current movements, all of the second hands can be synchronized.
Lastly.  This is a whole lot of trouble to go through and there are better ways to spend your time.  Just send the clock to me and work on more important projects 😉
I am uploading some pictures of the back, but right now the clock is on its way from the USA to Denmark. Yes, the easiest is probably to find 5 new second hands or possibly just 4. The volt reduction is as you write quite simple and I do not think such a watch has much power consumption?
I'm not sure what kind of movement the clocks are using. But if they use AC synchronous motors, then it will not be as simple as using a step down transformer because the mains voltage in Denmark is 230V 50Hz. American voltage is 110V 60Hz.
That's the reason why I can't buy AC clocks from the US. But I was told that there is a step down power supply with a frequency converter. I'll try to find the name of the company that sells it.
You could purchase a US UPS battery backup (APC makes a purse sine wave version).  Power it from a transformer that drops 220 to 110.  Maybe APC makes one with 220 input...dunno.
A lot of money to make it go.
Perhaps something like this will do. Instead of the shown power supply a supply for Alarm can do it and then a 12VDC bly battery can be added. But still a lot of money.
Can't wait to see how this turns out.  I was looking at a vintage clock motor on ebay this morning.  It was rated at 3W, so if this is close to these clocks, you might need 15W to power the whole thing.
