I bought these tool from China, Red Epilame bottle for 24$USD, Epilame solution 28.406-020 20ml for 17$(I'm not sure it's true?). Simple Epilame bottle for 5$, I purchased it a year ago,It's really good tool.
Your red bottle is a bit different than the one I got.  Mine has a metal mesh basket and also has a glass marble to block off the neck when the bottle is upright.  I'll be using mine for cleaning jewels, pallet forks and balance wheels.  I wonder if the plastic basket will hold up to solvents.
Edited by gpraceman
This red bottle have a glass ball, only basket is different, I think produced by the same company. I haven't used it yet.
This 28.406-020 was counterfeit HOROTEC Epilame solution, hard to clean burn marks, don't buy it from China. The correct one is MSA28.405.
Edited by fosr
I have been reading through this thread and for some reason now when I click on the aliexpress links, I am getting a not found message as well as everything is in French.
I tried a few links and had no problem. Do you have a problem with a link in particular or all links?
All of the early ones. Seems to default to some weird place. First 4 pages at least.
First link from the start of the thread.
I have a few Timelab tools coming from the US. Made in Korea, but I can only get them from the US. Go figure.
I'll post an update once I get them and use them.
Edited by Michael1962
Well I have worked out the language thing on the Aliexpress pages. For some stupid reason when I was not logged in to Aliexpress the settings all came up weird. Only able to fix it by registering and logging in.
Pages still don't load any pictures though. Even the most recent links.
Not sure why though?
I am going to go and get all my cookies now and clean them out and see if that helps at all.
There are days I just hate computers.
21 hours ago, spectre6000 said:
@Michael1962 Clear your cookies. Your cookie thinks you're in some French speaking territory with some weird import/export settings on the seller side.
For a while, AliExpress convinced itself to present one of my browsers only with Arabic, and I could not change the language on any page until nuking cookies.
Is everyone able to see the photos when they open an Aliexpress link? I get the page loading in English now so that bit is sorted, but I just keep getting the little blue square with a ? for every image. Does not seem to matter which link I select.
I’m not having a problem Michael, try this fresh link.
https://www.aliexpress.com/store/1102893212?spm=a2g0o.detail.1000061.1.2bfd48f83Uzwbl
im starting to wonder if you are having a DNS problem or if it might be the crappy super NAT engine your ISP is using or if there is a stuck cache server in an ISP along the path.
Tom
Well I just tried it in a private window, Safari on a Mac, same issue.
Just went to the AppStore to find another browser. Worse than useless. Could not find a darn thing.
Ended up having to go to the individual websites.
Just opened the page in Opera and got all the pictures. I have no idea what I would need to do to be able to see them in Safari. Oh well.
I ended up getting a Chinese Horia clone that has the hand setting ability.  It's a few bucks more expensive than the regular set.  I was hoping that the watch hand setting feature would be nice to have.  It works for that, but I would not say that it is convenient.  Tips screw in/out, not just a simple push in/pull out, and there's not much clearance between the movement and the tip.  I'll likely end up getting the Bergeon 8935 clone eventually.  But other than that, it is a pretty nice set.
New-Watchmaker-Jewelling-Tool-With-Micrometric-Screw-4mm-4mm-Watch-Hand-Installing-and-Fitting-Tools-Watch.jpg
I got a Bergeon 8935 clone and it is good, mine came a little off center and I could fix it, but to be honest I can always find other stuff to do, so that job keeps getting bumped down my list, you will also need the anvil that fits the clone as the ones supplied are caliber specific.
See page 10 of this thread where there are a few pictures and discussion.
I do have a generic holder.  I thought it would fit the Horia clone that I have, which it does, but doesn't give enough clearance for a movement.
With the Chinese tools, I'm not afraid of having to do some tweaks to them, if needed.  I've had to do that with a couple tools that I have gotten.
I love my Horia clone. Have used it twice already. I have two Seitz but now prefer the clone
    • HWGIKE#57 Valex FEF 190 15 jewels Swiss lever full service and repair This one was waiting for a balance staff replacement in my cabinet parts and case cleaned up with a new balance staff and a 4th wheel as the original 4th wheel had a broken pivot for the off center second hand. I never attempted a balance staff replacement before however I received a Bergeon Molfres (i was hunting it for about 2 years) and with the help of it I managed to remove the old staff and riveted the new one in. It also received a new MS, crystal and the hole for the MS arbor was also tightened. With the new MS now it has an acceptable performance meaning that the amplitude goes up to 280 fully wound, has an acceptable beat error and I have the two nice lines but only dial up, dial down is not as nice and I could not figure out as why. I have the two lines but the amplitude is dropping to around 230 and the lines are a bit hairy. Both dial up and dial down the lines just go up and down without seemingly any pattern. I cleaned the movement two times, and then a 3rd time pegged out the main plate and train bridge holes but made no change. Both the HS collet and the roller table was too lose on the new staff... I did not count how many times I took the balance cock off to sort out the HS collet, the roller table and the beat error, somebody before me also shortened the HS by pushing it out a bit and it seems every time somebody is messing with the end of the HS the protruding bit is most of the time twisted bent etc. This one was probably one of the most challenging repair and service. I might take the new MS out and clean it lubricate it as I just pushed the new one in to the barrel from the retaining ring. Plus started to re-read the theory of the escapement and how to analyse the graph on the timing machine: Greiner Chronografic Record manual. I am also thinking to put the watch on a 24 hour long run with the eTimer SW it once helped me to figure out what was wrong with a watch. There is an interesting part of the Greiner record manual talking about the pallets and the end shake of the balance and pallet staff. Maybe this is my issue? Who could that possibly identify? After a few years now I am still without a clue how could watchmakers make parts I can only see with my microscope or how could/can they carry out complicated services impossible to do.. real magic..... .... ..... before I sent this post while the pics were uploading I had an idea, i was browsing the possible outcomes on the timing machine I had one for magnetism..... so I demagnetized the movement and it is not hairy now.... two really nice lines 0.2 ms beat error still a bit wavy, but a lot lot better..... argh....
