Well here's my two penneth worth, Bench mats, now I have used a hobby cutting mate and then rectangular foam squares bought from Hobbycraft for years, but i thought I would treat myself to a Bergeon Plastic mat from cousins, well I'm dissapointed to say the least, I have moved it to my machining bench where it will live out its days.
Onto Aliexpress and i find a dealer selling Horotec bench mats for £8,95 plus postage ( bit cheeky ) but for £20 all in I thought i'd take punt and see what comes,  Well I wasn't disappointed, even beat a part I'd ordered from the states via UPS first class. Anyway, its exactly the same as a genuine one, I know this as my mentor has one and I had to do a comparison.
the seller name is Shop1102893212 Store and they currently have a 4.8 rating so not bad.
After trying different types of mat, I found the best (and cheapest) is a piece of vinyl flooring. It's quite firm with just the right amount of flex in the surface.
(BTW I think the chance of those mats on Ali being genuine Horotec as being about 0.01%)
Edited by mikepilk
Just had a bit of a bizarre incident buying from China, as you all know I do like my Chinese watch tools and a week ago I placed about 10 orders from different sellers on Aliexpress whom I have been buying from gor years.
Included in that order was the bench mat mentioned above from the same seller.
All packages were marked as shipped and tracking started, then a few days later the trackers cancelled the delivery and sent all ten parcels back to Aliexpress who promptly refunded me, all it said on line was that there was a problem in the delivery country so they could not send them to UK.
Very odd and annoying as most of the things I ordered have now gone up in price should I wish to try again.
Anyone else have any issues
Yes, I had a few packages cancelled and refunded. No reason was given, so I can't tell which items can't be sent to me. And was it stopped by China customs or my own country's customs.
Sometimes I put items in my cart, then find that they have disappeared, with a message in red saying that the item cannot be exported to my address. Really strange. None of the items were prohibited in my country.
I had this once with a lume kit.
There was talk about caseback openers a while ago. I already got the Bergeon copy but because I'm a sucker for old and heavy tools I also pulled the trigger on an MKS 220. The Chinese one isn't bad for the price but this Japanese is like a tank. Very heavy and robust, cast iron frame and the "locking nut" is also steel. Tight tolerances. I'm still waiting for some brand new case holders and opening bits (the tool is still made as model 22020) but I'm already very impressed. I paid like 40€ for the frame and the rest will cost about 80€. Plus import fees and shipping. There's also quite a big difference in size.
Edited by Malocchio
It looks like that Japanese one could open a tank 🤣
I have a cheap Chinese one. With some tweaking (e.g. shimming the hole in the frame with brass sheet) I've reduced the play to minimal.
But I find the problem is holding the case absolutely flat and centred. Even with a £££ Bergeon etc, this must still this problem(?). In fact, I find a touch of play at the opening bits, actually helps when not exactly centred.
I find it weird that there's nothing to support the case from below like in this Seiko S-210 with screwable base.
22 hours ago, gpraceman said:
Has anyone tried one of these screwdriver sharpeners?
https://www.aliexpress.us/item/3256806811524218.html
I was quite interested in this tool as well.  What I find interesting is, it seems this tool holds the screwdriver by the blade itself.  As far as I can see, the Horotec  version (which is a lot more expensive) holds the screwdriver by the handle.  I would imagine that with smaller blades this would be better as it would prevent the blade from flexing.  However, this might not be as big a problem as I may think.
But of course the quality of the tool will also impact the result.
Edited by ClaudioCavalli
It’s a copy of the horotec screwdriver sharpener., I use the horotec and its excellent. As always with Chinese tools it’s the build quality and materials used define if they are good.. The only way to find out is to purchase.IMG_0939.jpeg.8f888cfa2cd672602f67d76fbcaa0434.jpeg
Edited by clockboy
Build quality, yep that’t the trick.  I may hive it a try and report back.  It will have to wait ‘till after xmas as I will not be home for the holidays.
While looking at the item,  the last picture has a link for “Find Similar” and if you click on it you will see what seems like the same item for wildly varying prices.  I wonder if that relates to quality or not?
The issue I have with hollow ground screwdrivers are that they are great when you’re working on one model range with all the same slots on the screw heads. They can be a frustrating embuggerance when jumping between several manufacturers machines. I find it much easier and less frustrating to dress screwdrivers the traditional way, usually only takes a few seconds. Where the do excel is where you have something that requires regular strip down maintenance and you can dedicate a toolset for it i.e. a very expensive and unique firearm.
Tom
one grumpy old gits opinion
I am greedy I have two sets of screwdrivers. One set are traditional and one set hollow ground. I agree the traditional screwdrivers are easy to keep dressed.The hollow ground shape when shaped correctly I find do not slip because of the snug fit on the screw head.
ps you can never have enough screwdrivers. 😊
I agree completely, I tried the hollow ground ones and when they worked they were great, with no slip or screw slot deformation, but I found that they only worked on specific screw slot sizes, so I (being lazy) often used the next size down which either chipped the screwdriver blade and/or deformed the screw slot 😱. I switched back to regular chisel type screwdrivers after a week or two of fighting with the hollow ground ones (actually I reshaped the hollow ground blades to chisel shapes). Nice to see that there is a reasonably priced tool available now for sharpening them, as the Horotec one is a crazy price.
So if I understand this correctly, the problem arises with screws with different widths of the slot?  In other words since the sides of the driver are almost parallel, it will not fit if the slot is too narrow, is this right?  On the other hand, a V shaped blade would be a little more forgiving?
Although I only have one good set of screwdrivers, it did come with three set of blades for each size.  Maybe I could dress each blade for a different width?
In any case, I will have to think a little more if I wand to spend the money!
It’s a lot easier to dress as you go rather that change bits on screwdrivers before they wear down. It’s far too easy in watchmaking to fall into the trap of overthinking things. If you regularly work on one type of movement it’s easier, if predominantly one with an additional mix it would be easier to have a set dedicated to the main movement and a set as “jobbers” to be reshaped for anything. Of course both sets will need dressing pretty constantly.
you understand the problem perfectly, it’s a real chore to try and resize hollow ground blades and they won’t last long either as you remove so much material to alter the width and need specialist tooling. The traditional way you only need an India and Arkansas stone, India for rapid shaping, Arkansas for polishing and maintaining.
Tom
Tom
That is it then.  Thank you for helping me make up my mind.  More money for other tools! 🤣
A small grinding wheel will produce almost the same hollow cut. Try it on the few spare blades that you have to see how you feel about the shape. The traditional wedge has other advantages, you generally want a steep wedge that doesn't quite reach the bottom of the slot, for a better grip. This way will often lift the screw out as well, so that can negate the need to pick up tweezers.
The hollow cut touches all of the side of the slot rather than just the top edge , so has less overall chance of chewing the screw head .
Yep,  seen almost all of Kalle's videos.  I have been dressing screwdrivers with an Arkansas stone since I started but I was always curious about the Horotec tool but put off by the price.  I thought perhaps it would make it quicker to dress screwdrivers and maybe more repeatable.  I thought that with the low price of the Ali item, I might give it a go.  But the replies in this thread persuaded me to give it  pass.
A while ago I realized it's sometimes better to ditch gadgets and learn to use your hands. I always thought using a jacot tool must be really hard and I got a rollifit clone. There was a problem and I returned it and got a refund. I forced myself to burnish the old fashioned way and it wasn't that hard after all. I did get some upper back pain from the several days of intense training though. I should work on my ergonomics.
    • HWGIKE#57 Valex FEF 190 15 jewels Swiss lever full service and repair This one was waiting for a balance staff replacement in my cabinet parts and case cleaned up with a new balance staff and a 4th wheel as the original 4th wheel had a broken pivot for the off center second hand. I never attempted a balance staff replacement before however I received a Bergeon Molfres (i was hunting it for about 2 years) and with the help of it I managed to remove the old staff and riveted the new one in. It also received a new MS, crystal and the hole for the MS arbor was also tightened. With the new MS now it has an acceptable performance meaning that the amplitude goes up to 280 fully wound, has an acceptable beat error and I have the two nice lines but only dial up, dial down is not as nice and I could not figure out as why. I have the two lines but the amplitude is dropping to around 230 and the lines are a bit hairy. Both dial up and dial down the lines just go up and down without seemingly any pattern. I cleaned the movement two times, and then a 3rd time pegged out the main plate and train bridge holes but made no change. Both the HS collet and the roller table was too lose on the new staff... I did not count how many times I took the balance cock off to sort out the HS collet, the roller table and the beat error, somebody before me also shortened the HS by pushing it out a bit and it seems every time somebody is messing with the end of the HS the protruding bit is most of the time twisted bent etc. This one was probably one of the most challenging repair and service. I might take the new MS out and clean it lubricate it as I just pushed the new one in to the barrel from the retaining ring. Plus started to re-read the theory of the escapement and how to analyse the graph on the timing machine: Greiner Chronografic Record manual. I am also thinking to put the watch on a 24 hour long run with the eTimer SW it once helped me to figure out what was wrong with a watch. There is an interesting part of the Greiner record manual talking about the pallets and the end shake of the balance and pallet staff. Maybe this is my issue? Who could that possibly identify? After a few years now I am still without a clue how could watchmakers make parts I can only see with my microscope or how could/can they carry out complicated services impossible to do.. real magic..... .... ..... before I sent this post while the pics were uploading I had an idea, i was browsing the possible outcomes on the timing machine I had one for magnetism..... so I demagnetized the movement and it is not hairy now.... two really nice lines 0.2 ms beat error still a bit wavy, but a lot lot better..... argh....
