Hi
Quick question. Picked up an old 1970s Tissot Seastar Quartz. Needs a clean and TLC... just wondering how I go about removing the stem?
I need to do a bit of digging as to what cal this movement is...but see photos.
Any advice received gratefully. Thanks.
Jim
Just had a look through and found a discussion on this topic from 2015... so the answer is probably in that thread.
I am aware... because of the rather esoteric hand setting technique of these movements.... care is required to only pull the stem out from "fully in".
Seems there's a teeny tiny screw to loosen.....
