Case Press And Case Opener
matabog
Normal daily uses is lever press for me. I use nylon dies on the front case and aluminium dies on the case back. If the watch case is too tight to close then I'll use aluminium/brass dies on the front too. Nylon dies is softer therefore it absorb the pressing pressure.
If the case still cannot close by the lever press then I'll switch to screw down using aluminium/brass dies. Never have a case too tight to close with the screw down in my work.
Like Bob said lever press is faster and convenient to use, and I prefer it as I replace dozen of watch batteries daily.
I'd like to very much advocate the horotec screw down press, I've used dozen of case back presses and the horotec one is definitely the all around best. I've been using one multiple times every (work) day for the last 3 years, really no wear or tear, or bowing to speak of.
It simply works better than anything else I've so far even among other screw down case presses, it could be argued that the lever is 'quicker' but I disagree, there's nothing quick about having to make failed attempts at securing a case back before switching to the case press you could have started with. (though that is slightly unfair as I'm comparing a well engineered swiss screw press with the cheap chinese lever press that I happen to have at work)
My only real criticism is you can't seem to get replacement dies for the horotec presses. (please correct me if I'm wrong I'd love to get some)
Edited by Ishima
I have a more bog standard case back press but it has not as yet let me down.
I put felt on the bottom as it weighs quite heavy and I did not fancy screwing it down on my desk using the corner holes.  It accepts the standard dies metal as well but I generally use nylon.
Currently £19.99 with free postage on one part of the Bay and £40.00 on another part.  The overhead bracing stops the "Bowing or bending".  Bearing in mind that I only repair and build for fun, if I was a professional in business I would probably get better but it suits my purposed for now.
Cheers,
Vic
That's a good one because it's stable by design with two pillars aligned to the center, unlike the supercheap one I got before the heavy one I posted above
  • 6 years later...
Anyone know where to get the convex domed dies so that these types of presses can be used to fit acrylic crystals. The press uses dome so that when you screw down on the crystal arches and the OD is reduced slightly and then the case can be slipped/snapped over the crystal from below. I have seen this die on Robur presses, but not supplied with the generic presses, or available as a separate purchase.
Edited by Waggy
Grammar
Cousinsuk, search for “Bakelite “ you can order them individually
Tom
Just now, Waggy said:
Any recommendations for size(s), mainly do men's watches
Sorry, pretty much a beginner. I have only done minor things so far like building watches from parts and fixing keyless works, bracelets etc.
Tom
    • HWGIKE#57 Valex FEF 190 15 jewels Swiss lever full service and repair This one was waiting for a balance staff replacement in my cabinet parts and case cleaned up with a new balance staff and a 4th wheel as the original 4th wheel had a broken pivot for the off center second hand. I never attempted a balance staff replacement before however I received a Bergeon Molfres (i was hunting it for about 2 years) and with the help of it I managed to remove the old staff and riveted the new one in. It also received a new MS, crystal and the hole for the MS arbor was also tightened. With the new MS now it has an acceptable performance meaning that the amplitude goes up to 280 fully wound, has an acceptable beat error and I have the two nice lines but only dial up, dial down is not as nice and I could not figure out as why. I have the two lines but the amplitude is dropping to around 230 and the lines are a bit hairy. Both dial up and dial down the lines just go up and down without seemingly any pattern. I cleaned the movement two times, and then a 3rd time pegged out the main plate and train bridge holes but made no change. Both the HS collet and the roller table was too lose on the new staff... I did not count how many times I took the balance cock off to sort out the HS collet, the roller table and the beat error, somebody before me also shortened the HS by pushing it out a bit and it seems every time somebody is messing with the end of the HS the protruding bit is most of the time twisted bent etc. This one was probably one of the most challenging repair and service. I might take the new MS out and clean it lubricate it as I just pushed the new one in to the barrel from the retaining ring. Plus started to re-read the theory of the escapement and how to analyse the graph on the timing machine: Greiner Chronografic Record manual. I am also thinking to put the watch on a 24 hour long run with the eTimer SW it once helped me to figure out what was wrong with a watch. There is an interesting part of the Greiner record manual talking about the pallets and the end shake of the balance and pallet staff. Maybe this is my issue? Who could that possibly identify? After a few years now I am still without a clue how could watchmakers make parts I can only see with my microscope or how could/can they carry out complicated services impossible to do.. real magic..... .... ..... before I sent this post while the pics were uploading I had an idea, i was browsing the possible outcomes on the timing machine I had one for magnetism..... so I demagnetized the movement and it is not hairy now.... two really nice lines 0.2 ms beat error still a bit wavy, but a lot lot better..... argh....
