I found this the red and I have the same march with a black face. Mine two lines up and works too but I cannot figure out how to change the date and time for the life of me. It does not change my simple be pulling the stem out to any position that I found. Any tips?
Hello and welcome to the forum,  can you post some pictures of the watch in question to enable members to help you.  and it is considered polite to introduce youself before posting, thank you.
Many Timex watches do not have a date quick set feature. The date is set by winding the time past midnight till the date jumps to the next day, then wind it backwards to 7-8 o'clock position and repeat till you reach the correct date.
Do I understand that you can't set the time at all? If that is the case, you have a mechanical fault inside your watch.
Pictures will help us diagnose the problem better.
