Best Bodge Ever!!!!
clockboy
I was asked to looks at a small carriage clock that was not working. The customer said that her husbands friend (who fixes clocks!!!) had tried to fix it but said it was too worn to be repaired. I noticed before the strip down that the minute hand was not turning as it should. Then I found this, the minute hand hole was slightly too large & had been secured with Rodico.
See pics.
This a tool I use sometimes to close clock hands. It now fits correctly without any need for Rodico
I will show other pics of the strip & assembly as I suspect other gremlins are waiting for me but just could not wait to show this.
I have a similar gadget but on a smaller scale that had me puzzled for a while. It came in a job lot of bits and bobs from an old watchmakers estate and I couldn't figure out what it was for. However, in the same job lot I found a copy of the "wide awake catalogue", a supply house catalogue from the mid 1920's (I think). Browsing through it one evening there it was, my mystery tool, and it turned out to be for tightening hair spring collets. It's nice to see your larger scale version in use CB.
Incidentally, the "Wide Awake Catalogue" has since come in incredibly handy for identifying old tooling. If anyone has any mystery items that need a little light shed on them just post a picture, I'll see if I can find it.
There is a certain satisfaction to finding a clock or watch that has been cowboy'd, and being able to reverse the poor work and make a part (more or less) how it should be through good workmanship.
Edited by Ishima
Found another fault (bodge) will post when time.
I like little tools :D
PS The tool I purchased with a job lot of vintage watch makers tools a few years ago. It is very handy for giving hairspring collets a bit of a squeeze.
I posted a separate post (another senior moment) with the finished job. Some of the pics are poor though. The point being I could not have fixed this clock without the aid of a lathe.
Also very often my Jacot tool is to small for clock pivots so have to use my lathe for polishing/burnishing.
    • HWGIKE#57 Valex FEF 190 15 jewels Swiss lever full service and repair This one was waiting for a balance staff replacement in my cabinet parts and case cleaned up with a new balance staff and a 4th wheel as the original 4th wheel had a broken pivot for the off center second hand. I never attempted a balance staff replacement before however I received a Bergeon Molfres (i was hunting it for about 2 years) and with the help of it I managed to remove the old staff and riveted the new one in. It also received a new MS, crystal and the hole for the MS arbor was also tightened. With the new MS now it has an acceptable performance meaning that the amplitude goes up to 280 fully wound, has an acceptable beat error and I have the two nice lines but only dial up, dial down is not as nice and I could not figure out as why. I have the two lines but the amplitude is dropping to around 230 and the lines are a bit hairy. Both dial up and dial down the lines just go up and down without seemingly any pattern. I cleaned the movement two times, and then a 3rd time pegged out the main plate and train bridge holes but made no change. Both the HS collet and the roller table was too lose on the new staff... I did not count how many times I took the balance cock off to sort out the HS collet, the roller table and the beat error, somebody before me also shortened the HS by pushing it out a bit and it seems every time somebody is messing with the end of the HS the protruding bit is most of the time twisted bent etc. This one was probably one of the most challenging repair and service. I might take the new MS out and clean it lubricate it as I just pushed the new one in to the barrel from the retaining ring. Plus started to re-read the theory of the escapement and how to analyse the graph on the timing machine: Greiner Chronografic Record manual. I am also thinking to put the watch on a 24 hour long run with the eTimer SW it once helped me to figure out what was wrong with a watch. There is an interesting part of the Greiner record manual talking about the pallets and the end shake of the balance and pallet staff. Maybe this is my issue? Who could that possibly identify? After a few years now I am still without a clue how could watchmakers make parts I can only see with my microscope or how could/can they carry out complicated services impossible to do.. real magic..... .... ..... before I sent this post while the pics were uploading I had an idea, i was browsing the possible outcomes on the timing machine I had one for magnetism..... so I demagnetized the movement and it is not hairy now.... two really nice lines 0.2 ms beat error still a bit wavy, but a lot lot better..... argh....
