Hamilton Electric help please
Hello, and thank you for accepting me into the fold.
I have recently acquired a Hamilton Savitar II with a 505 movement. It was a non-runner though it would "power up" with the stem pulled and pushed in. The problem was it would run for about 10 seconds (+/-) and then stop. A new battery was installed and it still has this behavior of powering on, running for about 10 seconds and stopping. The mechanical side was checked for dirt in the gears, etc, but it doesn't appear to be mechanical in nature.
I'm making an assumption that the battery is delivering power and the electrical input is ok but somewhere between receiving the electrical power and running the watch there's a 'failure to communicate'
If anyone has an idea or can point me somewhere where I can dig into other ideas I would be hugely grateful
Thanks in advance
Maybe like any mechanical watch it's not that simple to just look at the gears. In other words what is the actual condition of a watch like the pivots and the oil used has it gone bad with time? Then for watch like this you really should have a service manual?
YES for sure.  It's likely the gold pallet contacts.
Edited by GomBoo
I didn't check for dirt, etc. My watchmaker examined the mechanicals, he's just not that familiar with these electrics to really get deep in the weeds with it. I do have a service manual that I found online but reading it I think it assumes some knowledge of the "flow chart" of these movements
Electric watches have unique problems.
First there is the electrical or electronic components. With a mechanical watch you look at things and see if they look good that doesn't necessarily mean they are good. But the electrical stuff you can't tell the condition that things are in.  This basically ideally means you have to have test equipment. There's specific tests on quartz watches and I know that the Hamilton watches have tests that should be made to make sure things are right.
Then all of the electric watches with gear trains have another problem. All of the gear trains have to be super free to rotate. Mechanical watch can plow right through a lot of dirt poor lubrication sticky lubrication at least up to a point. But a quartz watch for instance the wrong  oil can action cause the watch to stop and definitely give you problems. The balance wheel electric watch that balance wheel doesn't have a lot of power if this watch is never been serviced the old sticky lubricant would be enough to cause you issues.
More than likely your watch needs to be serviced. At least it runs for 10 seconds it's better than not running at all slats a good sign that's what's pointing at it probably just needs to serviced.
YES!!!  The fact that it runs & stops is a good sign...BUT, you do NOT want to keep trying to run it. The gold contacts will quickly burn thru. Best that a qualified Hamilton specialist do the service.
Where are you located?
Thanks, I'm in Denver, CO
    • HWGIKE#57 Valex FEF 190 15 jewels Swiss lever full service and repair This one was waiting for a balance staff replacement in my cabinet parts and case cleaned up with a new balance staff and a 4th wheel as the original 4th wheel had a broken pivot for the off center second hand. I never attempted a balance staff replacement before however I received a Bergeon Molfres (i was hunting it for about 2 years) and with the help of it I managed to remove the old staff and riveted the new one in. It also received a new MS, crystal and the hole for the MS arbor was also tightened. With the new MS now it has an acceptable performance meaning that the amplitude goes up to 280 fully wound, has an acceptable beat error and I have the two nice lines but only dial up, dial down is not as nice and I could not figure out as why. I have the two lines but the amplitude is dropping to around 230 and the lines are a bit hairy. Both dial up and dial down the lines just go up and down without seemingly any pattern. I cleaned the movement two times, and then a 3rd time pegged out the main plate and train bridge holes but made no change. Both the HS collet and the roller table was too lose on the new staff... I did not count how many times I took the balance cock off to sort out the HS collet, the roller table and the beat error, somebody before me also shortened the HS by pushing it out a bit and it seems every time somebody is messing with the end of the HS the protruding bit is most of the time twisted bent etc. This one was probably one of the most challenging repair and service. I might take the new MS out and clean it lubricate it as I just pushed the new one in to the barrel from the retaining ring. Plus started to re-read the theory of the escapement and how to analyse the graph on the timing machine: Greiner Chronografic Record manual. I am also thinking to put the watch on a 24 hour long run with the eTimer SW it once helped me to figure out what was wrong with a watch. There is an interesting part of the Greiner record manual talking about the pallets and the end shake of the balance and pallet staff. Maybe this is my issue? Who could that possibly identify? After a few years now I am still without a clue how could watchmakers make parts I can only see with my microscope or how could/can they carry out complicated services impossible to do.. real magic..... .... ..... before I sent this post while the pics were uploading I had an idea, i was browsing the possible outcomes on the timing machine I had one for magnetism..... so I demagnetized the movement and it is not hairy now.... two really nice lines 0.2 ms beat error still a bit wavy, but a lot lot better..... argh....
    • Wie ging die Sache weiter?   please use English for your posts    Tom
