400 day clock observation
LittleWatchShop
I serviced a Schatz a month or more back.  It has been running ever since, but I have observed recently that time seems erratic.  It is not the verge fluttering at mid position.  I think what is happening is that as the hands turn, the minute hand loosens up and gravity may be playing with me.
Does that sound reasonable, or am I smok'n something?
Here is a picture because everybody likes them.
Edited by LittleWatchShop
Hi LWS  your oservation is entirely feasable. What I would check it its connection on the front plate, the hour wheel/minute wheel are not slipping giving th same effect. Is the min hand tight on the shaft. If the escapement is operating correctly there are seceral possibles  the clutch on the center wheel, the engagement od the hour ans min wheel and the hand fitting its self.           Have a beer ar two and it wont matter anyway😆
I think the problem is the cannon pinion.  It has zero traction on the minute wheel post--zero.  That cannot be right, no???
I noticed this when I assembled the clock but thought that when the hand nut is installed it pulls the elements together providing the friction.
The way this works is the washer sitting behind the cannon pinion provides a backstop for the cannon pinion and when the nut is tightened, it joins the cannon pinion and the minute wheel arbor.  This must be tight so that the cannon pinion, and thus the minute hand, cannot freely rotate with respect to the arbor.
The clock that keeps on giving.  It stopped after running for a month or two.  I will investigate further,
In the mean time, I am questioning my suspension spring build.  It is the correct thickness for the Schatz 49, but now it appears that I assembled it too short.
I do not have the Horolovar book that gives the proper dimensions, but I found this on Mills Clocks UK.  Can anyone with the Horolovar book validate these dimensions?
2022-04-25 10_54_21-Schatz Standards 49 (Unit 6) Horolovar Anniversary Clock 400 Day Suspension Unit.png
On 4/25/2022 at 12:56 PM, watchweasol said:
Hi LWS  this is ascan from the page in the book. the images are the correct size and are used to assemble the suspension wires   hope this is some use. I
I installed a new suspension spring using the specifications from this page and it has been running for a day now.  My previous attempt was too short.  I did not see how far off the fork was.  At any rate, now it is looking good.
I am virtually certain that I used that book back when I was repairing clocks for my dad as a kid.  He must have let that book convey with his shop when he sold it because I cannot find it in his library.
31 minutes ago, watchweasol said:
Hi LWS  looking good , That book is invaluable when dealing with the 400 days.  fingers crossed.
Next time a 400 day shows up, I will buy it.  AND, I will charge my friend to cover the cost.  Right now I am fixing clocks and watches for friends for free.  Man, on man, I have so many new friends now!
You will find the 400 day clock repair guide book by charles terwilliger is a must if you encounter these clocks. Gives you all you need to know, the correct position of the blocks and the fork is vital.  The 400 day setting in beat tool is a must have as well. Its this tool.
I have seen it and considered buying it
  • 1 year later...
