4 minutes ago, ifibrin said:
Would it be correct to say I should turn the regulator stud in the direction that the inner prong of the stud (the prong on the inner radius, less distance to the pivot hole) so that the inner prong will be closer to the hairspring stud? That is the impression I get from the awci article.
Yes!
Yes!
Unfortunately, it appears the delta between CL and CR is here to stay. For some reason, when I rotate the regulator stud, the inner prong contacts the hairspring, but there is still a gap between the hairspring and the outer prong. Further rotation of the regulator stud doesn’t help. Interestingly, if I rotate the regulator stud even more so that the hairspring doesn’t bounce between the prongs of the regulator stud, the amplitude isn’t affected, but when I push the regulator arm closer to the hairspring stud, the amplitude suddenly drops from 290 to 180 suddenly at a certain point. I suspect there’s  a slight twist in the terminal curve somewhere, since this isn’t supposed to happen...
This doesn't make any sense to me, as the gap must get smaller (or larger) as you rotate the block. It cannot stay the same! The last photo you took was pretty good. Can you take a series of pictures like that one as you gradually rotate the block?
I think you have rotated the block too far at this point, and trapped the hairspring between the pins. Then, when you move the regulator arm you are pulling the hairspring out of shape.
The gap does get smaller as I rotate the regulator stud, it’s just that the inner prong touches the hairspring before the outer prong does. In other words, the two prongs of the regulator don’t close in evenly on the hairspring as you rotate it, such that the hairspring leans on the inner prong while the outer prong doesn’t touch the hairspring. I’ve tried taking pictures of the regulator stud but I can’t get it to focus on the two prongs (the depth) to show what I mean.
Edited by ifibrin
OK, I can imagine what you mean now. That suggests the hairspring wasn't quite centred between the pins in the first place. It's a very tricky process of trial and error getting it perfect. Close the gap slightly by turning the block, then very slightly turn the stud to move the hairspring a fraction away from the pin, so that is not in contact with either of them. Get the gap as small as you can without pinching the spring, then check the timing variations again.
You might have moved the regulator stud or its just the gap, thats if you are sure end curve is OK, Should fix the fault , not correct it by creating another fault.
The end curve looks fine, and follows the regulator arm, at 10x magnification. I think I will hold off any further hairspring work until I get s microscope so that I can be sure what I am doing. Thanks for all the help! I will consider it before I proceed any further.
You mean the hairspring stud right?
I am using stud to mean the (silver-coloured) part where the end of the hairspring is anchored, and block to mean the (brass-coloured) part containing the regulator pins.
I absolutely understand your decision to wait until you have better optics. It is crucial that you can see what you are doing. Even if you decide to leave the watch as it is, it is in a perfectly serviceable condition.
Edited by Klassiker
Something bothering me from your pictures? The first picture looks right but the second picture doesn't look right? So I snipped out the problem it looks to me like your regulator is up a little bit versus the original picture where it's down where it's supposed to be?
I’ve looked at the regulator stud, and it’s flush on top of the regulator arm. I think it’s due to the shadow that’s why it looks above the arm.
After repeated attempts to adjust the hairspring stud, and the regulator stud, I realized something odd.
I now think there’s a slight twist in the hairspring somewhere, for the following reasons:
in the horizontal positions (both dial up and dial down), the balance wheel shows a slight wobble. I think the slight twist causes the balance wheel to be pulled up and down against gravity as the hairspring contracts and expands, against the (necessary) endshake as the balance oscillates, causing a slight wobble. You can see in the video that the balance staff is wobbling/jumping between the horizontal positions.
https://drive.google.com/file/d/1kw_UPEEZU7Ihsq9AUfiXB1a_3JfkwdEA/view?usp=sharing
In the vertical positions, the balance wheel does not wobble, as the slight twist in the hairspring is not acting against gravity as the balance wheel oscillates.
https://drive.google.com/file/d/1AdK9uGQqLfqxIqYA-OrVvOSqcPIneJ6i/view?usp=sharing
Edited by ifibrin
I wouldn't read too much into that slight wobbling, to be honest. It doesn't have anything to do with the positional variation you are seeing, and doesn't indicate a problem with the hairspring. A flat hairspring, even If it is perfect, will always Impact radial as well as turning forces on the balance, so a slight wobble due to side-shake is common. If the movement were axial as you are proposing, then surely it would also be present in the vertical positions?
Oh... I always thought that the balance wheel should not have any wobble at all, assuming correct values of side shake or end shake.
Anyway, I did try your suggestion of turning the hairspring stud slightly to center the hairspring better, but it didn’t make much difference to the positional variation. Visually at 10x, it appears to me that the hairspring is making contact with the outer prong of the regulator block somewhere in the middle of the hairspring, as opposed to where it should be, at the edge of the hairspring.
Another odd thing is that the beat error also changes slightly if you rotate the hairspring stud too much, even if the hairspring is still centered over the pivot.
Did you get it centred - i.e. daylight visible between both pins and the hairspring? Did you follow up by reducing the gap between the pins (turning the regulator block)? If you did all that, and still didn't see any improvement in positional variation, then you can cross it off the list.
Sorry, I've read this through a few times, and I don't get what you mean. Maybe a photo or sketch would help?
You can only check if the hairspring is centred by removing it from the balance, and remounting it alone onto the cock. Then you can see if the collet lies concentric with the jewel hole. If you are turning the stud a lot, you are probably putting the hairspring way off-centre, but the regulator is keeping the terminal curve in place, so you are not noticing it. If you look carefully, you will see the spacing of the coils changing. I'm talking about relatively large rotations of the stud here, not the tiny adjustments you need to make when to centre the spring between the regulator pins.
To the best of what I could see at 10x, I adjusted the gap in the regulator block to the following:
I was thinking that if the hairspring was shifted off center from the pivot hole by rotating the hairspring stud, I would see bunching of the hairspring coils in one direction, and that it wouldn’t be necessary to take the hairspring off the balance wheel to see it... But I suppose that if it was off center only a tiny bit I wouldn’t notice the coils bunching up.
My understanding is this. There are two very similar versions of this system, one from ETA and one from Seiko. Looking at your photos, your regulator is the ETA version with the two pins or tapered "prongs" either side of the hairspring. It looks like this when correctly adjusted and the balance is at rest:
You've drawn the other version, which is the Seiko version, a large round pin with a slot through it. However, it is relieved in the middle section to effectively form two pins, with a similar cross-section to the ETA version in the area where the hairspring operates. That round "cap" on the end with the slot in it which you have sketched should not contact the spring. When correctly adjusted, it looks like this:
Whatever the case, with the balance at rest there should be no contact between the hairspring and the pins, and the two gaps should be as small and as equal as possible.
The regulator block I have is the eta version with the prongs; I only sketched the cross section of the regulator block where the hairspring resides.
The odd thing is even if I open the regulator block gap further, or close it, the difference between CL and CR is always about 50seconds. The absolute values will change, but the difference is always about there.
I reran the low amplitude readings, and the results are:
Dial up -40s; 155deg; 0.2ms
Dial down -63s; 150deg; 0.1ms
after adding a bit of wind to get the vertical positions to around 150deg,
Crown up -39s; 148deg; 0.2ms
Crown up-right +28s; 149deg; 0.0ms
Crown right +21s; 150deg; 0.1ms
Crown right-down -22s; 153deg; 0.1ms
Crown down -81s; 152deg; 0.0ms
Crown down-left -154s; 149deg; 0.2ms
Crown left -157s; 150deg; 0.5ms
Crown left-up -123s; 149deg; 0.6ms
The interesting thing is that the delta between CL and CR is reversed at low amplitude, compared to at high amplitude. This does suggest a dynamic poising issue. I did some reading up on dynamic poising, and it appears that hairspring shape and positioning does appear to affect the overall dynamic poise of the balance wheel, among other factors. Meaning that a hairspring not centered properly, or out of flat can give an apparent heavy spot in an otherwise statically poised balance wheel.
Thanks to @Klassiker, @nickelsilver, @JohnR725@Nucejoe  for the help.
Edited by ifibrin
I decided to try some dynamic poising, using the results I obtained at 150deg amplitude. However, while I did manage to find the heavy spot by the dynamic poising method, I did not want a permanent solution, so I added a small amount of weight opposite the heavy spot instead, using a small amount of rodico. Astoundingly, the results were impressive, again timing at low amplitude:
Crown up -122s, 149deg, 0.7ms
Crown up-right -121s, 151deg, 0.5ms
Crown right -114s, 155deg, 0.2ms
Crown right-down -127s, 158deg, 0.1ms
Crown down -126s, 152deg, 0.3ms
Crown down-left -121s, 154deg, 0.6ms
Crown left -139s, 151deg, 0.9ms
Crown left-up -130s, 149deg, 0.9ms
However, since I think the balance is out of dynamic poise because of mishandling of the hairspring, I don’t want to make permanent alterations to the balance wheel by removing weight for now.
Edited by ifibrin
Excellent detective work! Do you want to show us the hairspring, or are you going to leave it alone now? (Only for a while, obviously, until that itching in your fingers becomes unbearable).
I’m not confident of removing such a tiny hairspring from a tiny balance wheel without distorting the inner coils of the hairspring currently. The etachron system of attaching the hairspring to the balance cock also makes me a bit nervous, since the only way to check the hairspring is flat and true is to attach the naked hairspring to the balance cock.
As a hypothetical exercise, what is the best way to dynamically poise a balance wheel? Do you remove weight from the balance wheel with the hairspring and balance cock still attached? I imagine taking the balance wheel or hairspring off the balance cock can introduce new dynamic poise issues if you take it on and off, especially in the etachron system. But how else can you safely remove weight from a smooth balance wheel?
On a solid rim balance like this, you would lay the balance with cock on the bench upside down, grab the rim with sturdy tweezers and bring the balance edge where you want to remove weight over to sit on a low bench block, then with a fine drill, remove a but from the underside. Having a bench block that is only 5 or 6 millimeters thick helps. Remove less than you think you should- you can't put it back, haha!
Where did you find such a thin bench block? Did you make it yourself?
  • 1 year later...
I hope you all don't mind a noob jumping in to ask questions.  I have a Seiko 4R36A I am replacing the balance whee and hairspring on and I was looking at the manual, which discusses turning the regulator pins.  I'm curious since I'll barely be able to see it when in, how can I actually tell the correct setting? Is this something easy to tell with a timer? Like, from pins parallel to hairspring, to just touching.  WHat happens?
    • Why now Mark ?  And which contact has brought you here ? People have been trying for bloody months to get hold of you for reassurance. Shite way to run a forum tbh. Seven months since you last visited. I think we all need to have a long discussion with you about what happens if anything happens to you. Please look forward to lots of questions.
    • HWGIKE#57 Valex FEF 190 15 jewels Swiss lever full service and repair This one was waiting for a balance staff replacement in my cabinet parts and case cleaned up with a new balance staff and a 4th wheel as the original 4th wheel had a broken pivot for the off center second hand. I never attempted a balance staff replacement before however I received a Bergeon Molfres (i was hunting it for about 2 years) and with the help of it I managed to remove the old staff and riveted the new one in. It also received a new MS, crystal and the hole for the MS arbor was also tightened. With the new MS now it has an acceptable performance meaning that the amplitude goes up to 280 fully wound, has an acceptable beat error and I have the two nice lines but only dial up, dial down is not as nice and I could not figure out as why. I have the two lines but the amplitude is dropping to around 230 and the lines are a bit hairy. Both dial up and dial down the lines just go up and down without seemingly any pattern. I cleaned the movement two times, and then a 3rd time pegged out the main plate and train bridge holes but made no change. Both the HS collet and the roller table was too lose on the new staff... I did not count how many times I took the balance cock off to sort out the HS collet, the roller table and the beat error, somebody before me also shortened the HS by pushing it out a bit and it seems every time somebody is messing with the end of the HS the protruding bit is most of the time twisted bent etc. This one was probably one of the most challenging repair and service. I might take the new MS out and clean it lubricate it as I just pushed the new one in to the barrel from the retaining ring. Plus started to re-read the theory of the escapement and how to analyse the graph on the timing machine: Greiner Chronografic Record manual. I am also thinking to put the watch on a 24 hour long run with the eTimer SW it once helped me to figure out what was wrong with a watch. There is an interesting part of the Greiner record manual talking about the pallets and the end shake of the balance and pallet staff. Maybe this is my issue? Who could that possibly identify? After a few years now I am still without a clue how could watchmakers make parts I can only see with my microscope or how could/can they carry out complicated services impossible to do.. real magic..... .... ..... before I sent this post while the pics were uploading I had an idea, i was browsing the possible outcomes on the timing machine I had one for magnetism..... so I demagnetized the movement and it is not hairy now.... two really nice lines 0.2 ms beat error still a bit wavy, but a lot lot better..... argh....
