Jaeger Le Coulter Atmos Clock
Mark
A family member brought this for me to have a look at today.
He wants to know more about but as you know, I'm not a big clockie.
Can anybody offer any information about this beauty?
Ta!
That's exactly the same one that I have Mark. They are magnificent things and must be treated very carefully indeed. Do not try to adjust the time unless the escapement is all the way to one side of another, it won't like and damage cold occur. Also please don't try to remove the minute hand woyhout the correct puller. If you intend servicing it, send me a PM first as there are few things I would like to say about it.
We have not decided yet. We may just remove the movement to clean the case and glass, but ultimately it does need to be cleaned and lubricated.
Personally I have never worked on one so I may have to refer him to a pro.
The clock you have in the photos is a Atmos 5 calibre 526 these have the locking lever just under the dial they are a slightly more compact model with a hinged opening front. production ran from 1955 to 1984
Very expensive to work on the expanding bellows of gas. Barometric changes causes mainspring to wind. Not unusual to spend a few hundred dollars just on the bellows
I have not worked on one.
Here is a website of someone who does
http://www.atmos-man.com/
He is also one of the moderators on the ClockSmiths Message Board
Al
I like the inscription... looks like Mr F.S. Phillips joined Mars Limited just as the war was breaking in 1939.
Googling Mars limited brings up mainly foods (Mars bars) but I bet if this was the company he joined, the product line would shortly become vastly different.!
Love the clock.. quality always looks good! I can imagine this clock slowly ticking away a few hundred years after the human race has died out!
Anil
Found this Mark
http://www.jaeger-lecoultre.com/GB/en/content/setting-your-atmos-clock
I did notice the escape set up looks very similar to a 400 day clock.The same as the Jaeger they need very little energy to run.But if they are tiniest bit out of beat or bit grubby they just do not run. I would of thought it just need s clean.
Hi,
I have a pdf file of the service and repair manual for  Atmos clocks issued by Jaeger it covers models up to 1952 the calibre 526 as far as the movement goes is slightly simplified but essentialy the same, I can send you a copy of the file if you wish.
Also if your family member wishes to know more about the Atmos clocks in general then he should seek out a copy of a book by Jean Lebet called "LIVING ON AIR HISTORY OF THE ATMOS CLOCK" it is long out of print but can be found sometimes on ebay, it was published in a limited print run by Jaeger in 1997. I do have a copy of the book it only runs to 88 pages but is a fascinating read.
Wayne
Thanks for the replies. Still not sure if we are going to service this.
Would really love to see that pdf Wayne.
Will contact you shortly geo.
You guys are the best :)
  • 2 years later...
    • HWGIKE#57 Valex FEF 190 15 jewels Swiss lever full service and repair This one was waiting for a balance staff replacement in my cabinet parts and case cleaned up with a new balance staff and a 4th wheel as the original 4th wheel had a broken pivot for the off center second hand. I never attempted a balance staff replacement before however I received a Bergeon Molfres (i was hunting it for about 2 years) and with the help of it I managed to remove the old staff and riveted the new one in. It also received a new MS, crystal and the hole for the MS arbor was also tightened. With the new MS now it has an acceptable performance meaning that the amplitude goes up to 280 fully wound, has an acceptable beat error and I have the two nice lines but only dial up, dial down is not as nice and I could not figure out as why. I have the two lines but the amplitude is dropping to around 230 and the lines are a bit hairy. Both dial up and dial down the lines just go up and down without seemingly any pattern. I cleaned the movement two times, and then a 3rd time pegged out the main plate and train bridge holes but made no change. Both the HS collet and the roller table was too lose on the new staff... I did not count how many times I took the balance cock off to sort out the HS collet, the roller table and the beat error, somebody before me also shortened the HS by pushing it out a bit and it seems every time somebody is messing with the end of the HS the protruding bit is most of the time twisted bent etc. This one was probably one of the most challenging repair and service. I might take the new MS out and clean it lubricate it as I just pushed the new one in to the barrel from the retaining ring. Plus started to re-read the theory of the escapement and how to analyse the graph on the timing machine: Greiner Chronografic Record manual. I am also thinking to put the watch on a 24 hour long run with the eTimer SW it once helped me to figure out what was wrong with a watch. There is an interesting part of the Greiner record manual talking about the pallets and the end shake of the balance and pallet staff. Maybe this is my issue? Who could that possibly identify? After a few years now I am still without a clue how could watchmakers make parts I can only see with my microscope or how could/can they carry out complicated services impossible to do.. real magic..... .... ..... before I sent this post while the pics were uploading I had an idea, i was browsing the possible outcomes on the timing machine I had one for magnetism..... so I demagnetized the movement and it is not hairy now.... two really nice lines 0.2 ms beat error still a bit wavy, but a lot lot better..... argh....
