No blunt is fine I just don't know how to store the balance wheel and hairspring while cleaning the watch parts
4 minutes ago, Tiny said:
So is it ok to just place it in a tray until it's time to fit it back into the watch.
Ok. This is me with a balance . I take it out of the watch, I look at it to see if it's doin ok.  I carefully flip the cock  over onto it's back. Tbh. I don't really have to think about being careful anymore.I have it down to a fine art but I'm still gentle . As you flip the cock over make sure the balance wheel goes with it, 2 tweezers if you have to. Cock is on its back the balance staff is sitting nicely in the jewel hole. I put it in a low tub of naphtha, I leave it for 15 mins, I then agitate the naptha over it, lifting the wheel if necessary to get it into the coils. When it looks clean, I lift it out onto watch paper I use a blower on it, I lift the wheel up again while using a blower on it to help it dry. When it's dry I put a glass over it to protect it from dust. It's now ready to go back into the watch first to check the beat error, then adjusted if needed then back under the glass until start up. Job done, that's how I do it and will always do it unless i need to change it because of an issue with my method or I've bought myself a new toy to do all that for me.
Hi T  the bestway to store a balance is to lie it on its back with the balance upside down on the cock and cover with a glass. There are all manner of balance holders , some good some bad. If you are adjusting the collet , the tool shown and suitably modified aka Hector's post so the balance is held on the device and the post adjusted to support the balance and get the spring to lie in its horizontal plane at rest. I dont think the balance springs of today are as soft as those in the past. The damage is done when the balance is left hanging with no support for an extended period.  The safest and cheapest way is to put it on its back.
Thank you WW and NEW
I did write a long long reply but deleted it so I didn't look BLUNT just to keep the friends I've made on this wonderful forum
Sometimes blunt gets the job done my friend. I like people to know where they stand with me and me with them. I'm honest and genuine. I don't BS and say things as I see them. When I think I've make a mistake I will hold my hands up and apologise. Life's too short to have it surrounded  by drama , been there done that didn't like. 👍
Tiny mate here you go a simple visual. Photo 1 this was me when I started.
Photo 2 this is me now.
High tech or what.
    • HWGIKE#57 Valex FEF 190 15 jewels Swiss lever full service and repair This one was waiting for a balance staff replacement in my cabinet parts and case cleaned up with a new balance staff and a 4th wheel as the original 4th wheel had a broken pivot for the off center second hand. I never attempted a balance staff replacement before however I received a Bergeon Molfres (i was hunting it for about 2 years) and with the help of it I managed to remove the old staff and riveted the new one in. It also received a new MS, crystal and the hole for the MS arbor was also tightened. With the new MS now it has an acceptable performance meaning that the amplitude goes up to 280 fully wound, has an acceptable beat error and I have the two nice lines but only dial up, dial down is not as nice and I could not figure out as why. I have the two lines but the amplitude is dropping to around 230 and the lines are a bit hairy. Both dial up and dial down the lines just go up and down without seemingly any pattern. I cleaned the movement two times, and then a 3rd time pegged out the main plate and train bridge holes but made no change. Both the HS collet and the roller table was too lose on the new staff... I did not count how many times I took the balance cock off to sort out the HS collet, the roller table and the beat error, somebody before me also shortened the HS by pushing it out a bit and it seems every time somebody is messing with the end of the HS the protruding bit is most of the time twisted bent etc. This one was probably one of the most challenging repair and service. I might take the new MS out and clean it lubricate it as I just pushed the new one in to the barrel from the retaining ring. Plus started to re-read the theory of the escapement and how to analyse the graph on the timing machine: Greiner Chronografic Record manual. I am also thinking to put the watch on a 24 hour long run with the eTimer SW it once helped me to figure out what was wrong with a watch. There is an interesting part of the Greiner record manual talking about the pallets and the end shake of the balance and pallet staff. Maybe this is my issue? Who could that possibly identify? After a few years now I am still without a clue how could watchmakers make parts I can only see with my microscope or how could/can they carry out complicated services impossible to do.. real magic..... .... ..... before I sent this post while the pics were uploading I had an idea, i was browsing the possible outcomes on the timing machine I had one for magnetism..... so I demagnetized the movement and it is not hairy now.... two really nice lines 0.2 ms beat error still a bit wavy, but a lot lot better..... argh....
