Advice on servicing an Atmos clock
HectorLooi
I have been watching videos on the repair and servicing of Atmos clocks and I'm intrigued.
I have so far serviced three 400 day clocks, which look very similar. I think I'm ready for an Atmos clock. So before I blow $1000 on a low end Atmos clock, I have some questions.
I'm just wondering how much more difficult is it to service an Atmos clock?
Are there any special tools and jigs required?
Can the ethyl chloride that we see being used to treat football injuries on the field be used to refill the bellows?
Any advice and words of wisdom are desperately appreciated. Thanks in advance.
Hi Hector  from what I have read about them they are a bit specialist, but that does not mean you cant repair them the working clock parts are conventional but its the atmospheric bellows and the setting up of the same that seem to pose the problem. $1,000 is a fair price to pay for a working one .
There's an Atmos specialist at the base of the canyon I live in. I paid him a visit a while back while he was in the middle of one, and the issue with that one (and he said it's a frequent issue) was the drive chain had broken. Super fiddly. How much do the broken ones go for? I imagine you wouldn't need more than two to have a complete runner.
If you take a look at eBay at the moment, a working clock is around $800. Will probably end around $1000. There are "buy it now" ones asking for $1500 too.
Non runners are around half the price. But with non runners, it could be a simple problem or a total mess.
I'll probably watch the action from the sidelines for awhile.
I don't have a list of the tools but yes there are a lot of or some special tools you  need. Ideally need a holder for the movement itself and there's a variety of other tools.
Then in addition to the tools yes you need to know how to use the tools and why the tools even exist. So these are not the kind o'clock you can just rip apart run into the cleaning machine put them back together and you're off and running. Basically the movement itself is like a really big watch and has to be treated as such. They even do things like put epilam on the plates to keep the oil from spreading over time. Then there's things like the pallet fork it has to be poised which ideally means you have a poising tool for the pallet fork.
Then you also have to be careful with the running clocks in that if somebody winds up the mainspring manually because the tank is shot I can't quite remember but ill run a long time if that mainspring is welded up. This means you to buy a running clock perceiving that it's running and working fine in several months from now find out that it's not running fine and that can be an issue.
They look simple but this is really a very very specialized item
If the bellows is leaking its a specialist job.
I know something that services these clocks every now and then and if the bellows is leaking he sends it off to a specialist in the USA for fixing.
The pivots must be perfect on these clocks for them to run.
Actually I'm not really worried about a leaking bellow. I'm familiar with soldering sealed systems from constructing heat tubes for my computers.
I'm also very familiar with ethyl chloride as I used a fair bit of it as a dentist.
Now I wait for my manuals to arrive and for a suitable bargain on eBay.
On 4/26/2022 at 5:41 PM, oldhippy said:
Ethyl chloride that's the stuff that knocks people out.
No. That's nitrous oxide. You often see the medics at football matches spraying it on the knees of injured players. It's a cold spray, it just temporarily numbs the pain.
We use it to test the nerves in a tooth and also to numb a wiggly milk tooth for extraction.
You could knock somebody out with ethyl chloride,  but there is a good chance that person is not going to wake up.
There have been cases in US schools where kids inhale the stuff for a buzz. And some didn't wake up. So now it's really hard the get the pure stuff. The stuff used by footballers has an additive in it that smells like "pig's fart".
Some suppliers didn't know this and tried to sell this ethyl chloride to dentists. GOOD LORD! We use the stuff in the mouth! 🤪
Edited by HectorLooi
Typo
Sorry I overlooked this thread!  15 years ago I got my father‘s Atmos which was not running anymore. With the help of a repair video from an experienced american clock maker (Anthony Montefusco, passed away 2011) it was not to difficult to replace the broken balance wire. Here ist the only (self made) special tool I needed to poise the balance shaft.
The documentary I gathered at that time is still available if it‘s needed.
Edited by Kalanag
  • 2 years later...
Finally got my hands on a non-working Atmos clock. Paid about $600.
I have a few stalled projects on my bench at the moment, a Schatz Elexacta clock and a Citizen 8110A. Both projects need some repivoting work but the belt on my lathe keeps breaking.
Have any of you guys experienced problem polyurethane belts? The polyurethane just doesn't weld properly. It welded fine when it was new but now the welded part just becomes brittle. Even the spare stock I have in my cupboard seems to have deteriorated. This is my second lot with this problem. They just last about 2 years.
I've ordered an old fashioned sewing machine leather belt and nitrile rubber belts. China seems to be on some kind of national holiday week and nobody seems to be working. So my Aliexpress orders are all backed up.
I'll probably leave the Atmos until I've cleared my bench of all my half completed projects. Too much on my plate at the moment.
  • Similar Content
    • HWGIKE#57 Valex FEF 190 15 jewels Swiss lever full service and repair This one was waiting for a balance staff replacement in my cabinet parts and case cleaned up with a new balance staff and a 4th wheel as the original 4th wheel had a broken pivot for the off center second hand. I never attempted a balance staff replacement before however I received a Bergeon Molfres (i was hunting it for about 2 years) and with the help of it I managed to remove the old staff and riveted the new one in. It also received a new MS, crystal and the hole for the MS arbor was also tightened. With the new MS now it has an acceptable performance meaning that the amplitude goes up to 280 fully wound, has an acceptable beat error and I have the two nice lines but only dial up, dial down is not as nice and I could not figure out as why. I have the two lines but the amplitude is dropping to around 230 and the lines are a bit hairy. Both dial up and dial down the lines just go up and down without seemingly any pattern. I cleaned the movement two times, and then a 3rd time pegged out the main plate and train bridge holes but made no change. Both the HS collet and the roller table was too lose on the new staff... I did not count how many times I took the balance cock off to sort out the HS collet, the roller table and the beat error, somebody before me also shortened the HS by pushing it out a bit and it seems every time somebody is messing with the end of the HS the protruding bit is most of the time twisted bent etc. This one was probably one of the most challenging repair and service. I might take the new MS out and clean it lubricate it as I just pushed the new one in to the barrel from the retaining ring. Plus started to re-read the theory of the escapement and how to analyse the graph on the timing machine: Greiner Chronografic Record manual. I am also thinking to put the watch on a 24 hour long run with the eTimer SW it once helped me to figure out what was wrong with a watch. There is an interesting part of the Greiner record manual talking about the pallets and the end shake of the balance and pallet staff. Maybe this is my issue? Who could that possibly identify? After a few years now I am still without a clue how could watchmakers make parts I can only see with my microscope or how could/can they carry out complicated services impossible to do.. real magic..... .... ..... before I sent this post while the pics were uploading I had an idea, i was browsing the possible outcomes on the timing machine I had one for magnetism..... so I demagnetized the movement and it is not hairy now.... two really nice lines 0.2 ms beat error still a bit wavy, but a lot lot better..... argh....
