Jaeger-LeCoultre 889 successfully serviced
My JLC Heraion with caliber 889/1 needed a service. Having gained experience with several other (cheaper) watches I decided to try it myself. Being totally aware that I wouldn‘t get any spareparts if something might go wrong I was willing to let it serviced by JLC (about €800,-) if an accident should happen.
Preparing my work I found a technical guide for the partially identical 928/2 at cousinsuk and a workthroug by the WatchGuy (AP Royal Oak with JLC 889/1). I designed a movement holder with a free CAD program and 3D printed it with my Ender 3. This holder supports the movement much better than my vice type holders.
I didn‘t put me under time pressure in any way and just worked on the movement when I felt totally relaxed. A week later I had successfully disassembled the movement. Some screw hads unfortunately showed that I was not the first being inside this watch. The jewels of the fast reving wheels were totally dry and clean (!) showing that modern oils don‘t gum up but do eventually evaporate.
I successfully cleaned the parts in pharmaceutical petroleum ether 40/60 and One Dip. The escape wheel and the pallet fork got epilamed.
What happened to be the most challenging task was handling and oiling the super tiny capstones (0,9x0,12mm). One of them slipped out of my tweecers. My heart stood still for a moment. After hours of searching I gave up. I suspect the tiny particle landed on my clothes, skin or hair where it couldn‘t be seen. After some research I found that it is a standard KIF 508 which I could order with Boley. This time I was lucky 😀
For oiling the combined stones (fixed cap) of the escape wheel I found help in this forum.
Meanwhile the watch is ticking healthy again and shows good results on the time grapher.
Edited by Kalanag
  • Like 7
  • 2 years later...
Hi @Kalanag
I wonder if you still remember how you lubricated the ball bearings of the rotor? Strangely, the 928 service guide (still available at WatchGuy) doesn't indicate any lubrication.
Cheers
PS: just clicked on your profile @Kalanag and saw that you're located in Stuttgart. I studied in Tübingen 🙂 . Servus!
Edited by Knebo
Hi @Knebo
The same with the service guide for the JLC889!
I followed the recommendation for the ETA2892 with a similar bearing. Interestingly Dr. Roland Rannft proposed not to oil these bearings at all. He argued that the oil compromises the function by catching dirt particles and a ball bearing could live without lubrication.
I grew up in Konstanz at the Swiss border 🙂
Edited by Kalanag
I was also leaning towards a tiny bit of 9010.
But interestingly, the guide for cal 916 (which I'm working on) is suggesting Moebius 941 !!
And the guide for cal 918 recommends an immersion in a mix of benzine and D5. image.thumb.png.0e930d43ac96faa7278d5f7ba4bc3f18.png.3791eb8419b56a536e8cd38e60d40241.png
I started a thread about the latter because I suspect it could be something like Lubeta V106 (which is the alternative to 9010 that I'm considering for the ball bearing).
PS: Konstanz! Nice. I went there several times, too. Lovely place.
    • HWGIKE#57 Valex FEF 190 15 jewels Swiss lever full service and repair This one was waiting for a balance staff replacement in my cabinet parts and case cleaned up with a new balance staff and a 4th wheel as the original 4th wheel had a broken pivot for the off center second hand. I never attempted a balance staff replacement before however I received a Bergeon Molfres (i was hunting it for about 2 years) and with the help of it I managed to remove the old staff and riveted the new one in. It also received a new MS, crystal and the hole for the MS arbor was also tightened. With the new MS now it has an acceptable performance meaning that the amplitude goes up to 280 fully wound, has an acceptable beat error and I have the two nice lines but only dial up, dial down is not as nice and I could not figure out as why. I have the two lines but the amplitude is dropping to around 230 and the lines are a bit hairy. Both dial up and dial down the lines just go up and down without seemingly any pattern. I cleaned the movement two times, and then a 3rd time pegged out the main plate and train bridge holes but made no change. Both the HS collet and the roller table was too lose on the new staff... I did not count how many times I took the balance cock off to sort out the HS collet, the roller table and the beat error, somebody before me also shortened the HS by pushing it out a bit and it seems every time somebody is messing with the end of the HS the protruding bit is most of the time twisted bent etc. This one was probably one of the most challenging repair and service. I might take the new MS out and clean it lubricate it as I just pushed the new one in to the barrel from the retaining ring. Plus started to re-read the theory of the escapement and how to analyse the graph on the timing machine: Greiner Chronografic Record manual. I am also thinking to put the watch on a 24 hour long run with the eTimer SW it once helped me to figure out what was wrong with a watch. There is an interesting part of the Greiner record manual talking about the pallets and the end shake of the balance and pallet staff. Maybe this is my issue? Who could that possibly identify? After a few years now I am still without a clue how could watchmakers make parts I can only see with my microscope or how could/can they carry out complicated services impossible to do.. real magic..... .... ..... before I sent this post while the pics were uploading I had an idea, i was browsing the possible outcomes on the timing machine I had one for magnetism..... so I demagnetized the movement and it is not hairy now.... two really nice lines 0.2 ms beat error still a bit wavy, but a lot lot better..... argh....
