Need so advice on where I may find case and dial for this movement please?
Was a cheap eBay win and I reckon Asian in make but that's about all I can guess at,I know case will need push button top right but just wondering if anyone has anymore insight
Thanks
post-1079-0-52013000-1432481587_thumb.jp
I think you may well have a lot if difficulty finding a aces and dial to match that movement. You may well end up using it to hone your repair skills on.
I do hope you find what you are after.
That looks very much like a movement I pulled out of a Chinese made Breitling knock off I took apart some time back. It was one of the first watches I took apart and messed with. I remember it had an identical balance bridge. Not sure if that helps you though. :(
Well wasn't an expensive aquisition so if to only hone my skill no real big deal but why are cases and dials so hard to come by?
Are they all locked up in some mad swiss watchmakers vault lol
Could well be, because I don't think they were melted down for the gold. :)
Dear Friend,
This can be a problem, however in your case I'd suspect you've got a reasonable problem. If you take measurements on such a movement it may give away an ETA or other common movement of which it closely approximates or matches excactly. If you made me guess I'd bet it matches the dimensions of a Valjoux 7750 family; if so you're in great shape.
Once you've done that I'd take a look at the following two places:
Very nice Ebay seller with Swiss sourced parts including cases with pushbuttons: http://www.ebay.com/usr/b_line55cc
Frei, especially helpful if you call them and speak with the parts people: http://www.ofrei.com/page460.html
As for the dial, looking at where i'd guess the dial feet should sit it might not be hard to find a sterile dial that fits. Strip it in acetone and mill (or even drill...) a date window and a large semicircular cutout for the pretty portion at the bottom.  A little paint, a pad print and you might have a real beauty of a watch that's all yours. Even if you can't print there is a lot to be said for a clean dial on such a watch, especially given the horizontal symmetry between the date and movement portions.
As for hands, I'll betcha a beer they're 150/90/20. If that's the case pick whatever you like. If not take measurements and see if anything here:http://www.ofrei.com/page483.html looks good to you.
I wish you all the best, let me know how it turns out.
Welcome to the forum Mute, and thank you for a very helpful and informative first post.
It would be good to hear what your own background and interests in horology are. I look forward to more from you in the future. :)
Dear Geo,
Thank you for your kind words. It is impressive how helpful and just plain nice everyone here is.
Horologically I am a true amateur. I work on my own watches and occasionally put together a unique watch as a gift or thank-you. I owe any knowledge I have to this forum and Youtube videos. I do have some experience with precision small parts manufacturing/prototyping from prior ventures and I hope that can be useful to share with the users of this forum.
Again, thank you all for sharing your craft. It is truly appreciated.
Thank you alll for your help I will have to do a bit more research but the positive help you get here is great,if I find anything I will surely post results
That won't fit in anything chrono
Looks like u wanted to build a mulliner big date but breitling uses eta movements with dd modules or inhouse movements
    • How do the timegrapher readings look after the watch has been running for 24 hours? Are you using a phone app or a dedicated timegrapher to take your measurements? Best Regards, Mark
    • From what I see, the crystal is made of mineral glass and is secured to the bezel with a sealing ring. If you might want to replace the crystal without removing the bezel or the movement, I think it's possible, but risky. You have to suck out the old crystal without breaking it into tiny particles. I would not do that. If you remove the movement first you can press the crystal out and press a new one in without removing the bezel.
    • Hello Everyone, A short message to introduce myself. I'm Sebastiaan (50) from the Netherlands and have always been interested in watches. My two kids are at the end of their teens years and so I have more time to start a hobby.  Working on watches was something I always wanted to learn. So I recently started the watchfix repair course. Currently watching level 3. My short term goal is to be able to service the watches we (Myself, my wife and kids) own. I own a manual Omega Geneve from 1974, a small microbrand watch with a NH35 and a wittnauer bumper from 1940's. My wife owns an Oris, Seiko 5 with 7s26c and my son a seiko alpinist sarb017 and sports 5 with 4R36. So enough to learn on the short term..  Looking forward to talking to all of you and enjoying the watch hobby together. Greetings Sebastiaan
    • It works quite well. The only strange thing is that it loses 2/3 mn per day whereas the measurements indicate that it is fast by 1/2 mn. Maybe something wrong with the gear mechanism ...
    • Unfortunate…but you clearly have a Longines branded movement with a year 1936 serial consistent with the caliber. I checked the case maker of the last few Longines I worked on… …same as your watch, so certainly you have grounds to honestly describe your watch as a Longines cal 25.17 tank with unbranded dial…and given the modesty of the watch IMO the Longines authentication wouldn’t dramatically alter the value, if that’s what you are hoping…as nucejoe suggests the value will mostly be determined by how well it runs…
