Two-pack glue hack
Tiny
So the other week I bought a second hand stereo Microscope from facebook market and found out it didn't have the 48mm thread required to fit a barlow lens to it.
I'm a little bugger I didn't want to miss-out on this I thought long and hard about how I was going to fix this. at first I thought about just gluing the barlow the the microscope lets face it I only paid £25.00 so what was the harm of doing this, but them I realized what would happen if I needed a different barlow lens so thinking hard and looking at youtube some bloke hacked a led light adapter by placing it in a drill and while spinning the adapter grinding the inner part to fit his object lens. this looked really terrible and his thread was the wrong way around (male) so he also had to buy a another adapter too add a female thread to his microscope.
so thinking about this I came up with the idea to just glue a camera filter to the underside of the object lens SORTED works a treat and I now have a fixed 48 mm thread to my object lens happy chap and it only cost me £2.00 for a filter of the bay.
If anyone needs a filter to convert there stereo microscope like mine I have a spare skylight filter you can have I bought a spare one just incase I glued it in place by placing it under my lens and then move the scope down until it trapped the filter and barlow lens while the glue went off (I left it over night) I placed glue all the way around the inside of the filter
2 hours ago, spectre6000 said:
How does it work? Did you do anything to ensure that the Barlow lens is whatever intended distance from the next lens up the chain, or is that not a critical dimension?
It's not critical and the barlow lens is only about 2 mm from it's intended distance.
    • HWGIKE#57 Valex FEF 190 15 jewels Swiss lever full service and repair This one was waiting for a balance staff replacement in my cabinet parts and case cleaned up with a new balance staff and a 4th wheel as the original 4th wheel had a broken pivot for the off center second hand. I never attempted a balance staff replacement before however I received a Bergeon Molfres (i was hunting it for about 2 years) and with the help of it I managed to remove the old staff and riveted the new one in. It also received a new MS, crystal and the hole for the MS arbor was also tightened. With the new MS now it has an acceptable performance meaning that the amplitude goes up to 280 fully wound, has an acceptable beat error and I have the two nice lines but only dial up, dial down is not as nice and I could not figure out as why. I have the two lines but the amplitude is dropping to around 230 and the lines are a bit hairy. Both dial up and dial down the lines just go up and down without seemingly any pattern. I cleaned the movement two times, and then a 3rd time pegged out the main plate and train bridge holes but made no change. Both the HS collet and the roller table was too lose on the new staff... I did not count how many times I took the balance cock off to sort out the HS collet, the roller table and the beat error, somebody before me also shortened the HS by pushing it out a bit and it seems every time somebody is messing with the end of the HS the protruding bit is most of the time twisted bent etc. This one was probably one of the most challenging repair and service. I might take the new MS out and clean it lubricate it as I just pushed the new one in to the barrel from the retaining ring. Plus started to re-read the theory of the escapement and how to analyse the graph on the timing machine: Greiner Chronografic Record manual. I am also thinking to put the watch on a 24 hour long run with the eTimer SW it once helped me to figure out what was wrong with a watch. There is an interesting part of the Greiner record manual talking about the pallets and the end shake of the balance and pallet staff. Maybe this is my issue? Who could that possibly identify? After a few years now I am still without a clue how could watchmakers make parts I can only see with my microscope or how could/can they carry out complicated services impossible to do.. real magic..... .... ..... before I sent this post while the pics were uploading I had an idea, i was browsing the possible outcomes on the timing machine I had one for magnetism..... so I demagnetized the movement and it is not hairy now.... two really nice lines 0.2 ms beat error still a bit wavy, but a lot lot better..... argh....
