tea strainer lesson learnt
Tiny
Lesson of the day
Tea strainer for finding lost parts in toxic sonic cleaner.
Yes I had  a bit of a day
so now I've mastered the tweezers on small screw. the trials & tribulations of a watch maker or even small part handler, today throw me a curve ball. After finding or the lack of finding a very small date spring on my Seiko 7019a I had to replace it from my extra movement. After striping the movement date side, I needed to clean it.
So off to the sonic cleaner with the part in a small press fit basket (1mm mesh) I continued to procced to go through the three stages of cleaning fluid all was going really well until the last jar at the end of the cleaning cycle the press fit basket had opened (I do have to say it's the first one) with the very small date spring no longer in the jar I looked and looked for the spring but no spring. so cutting a long story short the spring was found in the first jar, the real problem was picking it out of the glass jar finding the spring was easier if you are looking from the outside of the glass jar because every time I placed the jar on the bench too open the glass jar it had moved that cleaner Elma WP Pro cleaning fluid  is not to good for you.
so lesson of today is really small parts I'm going to put in a screw mesh container I have but the spring being found in the first jar means the 1mm mesh is not holding the really small items so I will have to see if I can find something with a smaller mesh and strain all cleaning jars is a tea strainer and filter paper.
Many more painful lessons to go 🙂
Super-small springs are not worth washing in mesh baskets anyway. I just use rodico if they are dirty at all. With cheap mesh baskets you still have to be careful with tiny parts finding a way into the rims of the basket. I've had to take a jeweler's saw to them to free items. Now I only put slightly larger items in the cheap baskets, and tiny parts go in a Bergeon ($$) basket. Even larger parts can go directly in the cleaning machine's partitioned baskets.
53 minutes ago, oldhippy said:
Put parts such as tiny springs in a pot with a screw lid containing Ronsonol, clean them with a watchmakers glass fiber brush.
Great cheap multipurpose tool. i also use mine as a very fine sander for acrylic watch glass, prior to polishing
    • HWGIKE#57 Valex FEF 190 15 jewels Swiss lever full service and repair This one was waiting for a balance staff replacement in my cabinet parts and case cleaned up with a new balance staff and a 4th wheel as the original 4th wheel had a broken pivot for the off center second hand. I never attempted a balance staff replacement before however I received a Bergeon Molfres (i was hunting it for about 2 years) and with the help of it I managed to remove the old staff and riveted the new one in. It also received a new MS, crystal and the hole for the MS arbor was also tightened. With the new MS now it has an acceptable performance meaning that the amplitude goes up to 280 fully wound, has an acceptable beat error and I have the two nice lines but only dial up, dial down is not as nice and I could not figure out as why. I have the two lines but the amplitude is dropping to around 230 and the lines are a bit hairy. Both dial up and dial down the lines just go up and down without seemingly any pattern. I cleaned the movement two times, and then a 3rd time pegged out the main plate and train bridge holes but made no change. Both the HS collet and the roller table was too lose on the new staff... I did not count how many times I took the balance cock off to sort out the HS collet, the roller table and the beat error, somebody before me also shortened the HS by pushing it out a bit and it seems every time somebody is messing with the end of the HS the protruding bit is most of the time twisted bent etc. This one was probably one of the most challenging repair and service. I might take the new MS out and clean it lubricate it as I just pushed the new one in to the barrel from the retaining ring. Plus started to re-read the theory of the escapement and how to analyse the graph on the timing machine: Greiner Chronografic Record manual. I am also thinking to put the watch on a 24 hour long run with the eTimer SW it once helped me to figure out what was wrong with a watch. There is an interesting part of the Greiner record manual talking about the pallets and the end shake of the balance and pallet staff. Maybe this is my issue? Who could that possibly identify? After a few years now I am still without a clue how could watchmakers make parts I can only see with my microscope or how could/can they carry out complicated services impossible to do.. real magic..... .... ..... before I sent this post while the pics were uploading I had an idea, i was browsing the possible outcomes on the timing machine I had one for magnetism..... so I demagnetized the movement and it is not hairy now.... two really nice lines 0.2 ms beat error still a bit wavy, but a lot lot better..... argh....
