So, I'm doing Mark's watch courses and got an ST36(00) from Ebay to work on.  I picked the fancy looking one with Côte de Genève on all the bridges.  What I didn't see at the time (lack of experience) was that it also has a swan neck regulator.  That's great and all, but the problem is that the way it's been implemented means that it's non-functional.
The spring puts no tension at all on the regulator for most of its travel, and the screw is too far from the regulator to do much as well.  I don't know how much more I can turn it, but I already moved it in a little.
My question is, would it be possible to adjust the spring so it actually puts tension on the regulator?  I've never tried to adjust this type of spring before, so I don't know how forgiving it is likely to be.  I think applying heat will probably destroy the temper, but I'm not sure it can be adjusted much without breaking it.  It might also require a longer spring.
Worst case I guess I can just remove it.
I'm interested to know people think I should do in this case and if there's any chance of making it work.
For what it's worth, I have the same movement and I haven't yet done anything with it. As shown in your photo, mine also has a gap between the screw and the regulator index as well as between the spring and the regulator index.
It's not clear to me why you think the spring needs to be engaged here.
Presumably the balance was set at the factory in a working state. In the event that the watch is running fast or slow you would want to adjust the index left or right to move the index pins along the terminal curve of the hairspring.
The spring needs to be pushing the regulator, and the screw needs to be pushing back.  Regulation is done by adjusting the screw to move the regulator in very fine increments.  Much finer than you can do by pushing the regulator around with a piece of pegwood.
As it's been done here, it's just a bit of silly bling with no actual use, and in fact only serves to limit how much the regulator can be moved.
It wouldn't have been too hard to make it actually functional, but it's like it's been done by someone who doesn't know what it's supposed to do.
What makes you think your watch needs regulation? Did you put it on a Timegrapher?
Some regulators have no spring or screw. How do they work?
This essentially positions the regulator in a fixed place. The regulator works by positioning the index pins around the terminal curve. They are already in a position determined by the manufacturer to be OK.
So, asking again, why do you think they need to be adjusted?
Or have you just decided that because there is a spring and a screw something needs to be done?
I try turning the screw all the way in ( to confirm what you suspect )   who knows the regulator may then  reach the spring. As you know the spring is only to keep the regulator from moving in the event of a shock.
Most of what I quoted above is true except?
Typically on modern watches The fine adjustment which is what this is if it was working is just a fine adjustment. I'm attaching an image you can see that the stud is held by a separate piece regulator pins are separate peace and whatever you have on the other end like this is a separate piece. This means the watch can be regulated without even moving the regulator arm because they're all separate independent of each other.
So basically for your watch you can just keep it the way it is as a visual decoration if it bothers you take it off if you really want to try to make it functional I would remove it before you try to bend the spring. Remove it run the regulating screw all the way out so it's not in the way and then try to bend the spring without breaking. But it really isn't necessary as to regulate just fine the way it is.
Am I looking at an imitation of the old "whip spring" variant of a micrometric regulator?  I have to agree with Chris here, in that this appears to be a decorative tack-on, by which the maker can presumably hope to charge more money.
On old railroad grade pocket watches, a regulator like this would have that spring pressing against the regulator arm throughout its entire range, with the screw pressing against the other side, and thus no sudden jerk or impact could throw the regulator out of adjustment.  If this regulator isn't doing that, then its either for looks, or needs adjustment itself.
If you have no gooseneck, you just move the regulator.  If the gooseneck is working correctly you use the screw - it's a fine adjustment and the regulator can't move out of position any other way than by moving that screw.  The point is that this is just decoration that limits how far you can move that regulator against the spring.
Yes I check and regulate the watch each time it is stripped down and rebuilt.  It's a practice piece but will finish up in a Panerai style case once I'm done with it.  I was hoping someone might have experience adjusting this type of spring as I'm not sure they've even got the geometry right, and I expect the spring is more likely to break than change shape.
I guess I'll just have to try it and see what happens.
Edited by ChrisRobinson
I suspect that it may only be decoration as Karl says here:
This is after all a $24 Chinese copy of an Unitas 6498 which does not have the swan neck adjust. So, it was added by somebody in China. After looking at mine, I don't think that the adjustment as implemented is doing anything as you rightly noticed in the first place. I only purchased the one I have to practice on.
    • HWGIKE#57 Valex FEF 190 15 jewels Swiss lever full service and repair This one was waiting for a balance staff replacement in my cabinet parts and case cleaned up with a new balance staff and a 4th wheel as the original 4th wheel had a broken pivot for the off center second hand. I never attempted a balance staff replacement before however I received a Bergeon Molfres (i was hunting it for about 2 years) and with the help of it I managed to remove the old staff and riveted the new one in. It also received a new MS, crystal and the hole for the MS arbor was also tightened. With the new MS now it has an acceptable performance meaning that the amplitude goes up to 280 fully wound, has an acceptable beat error and I have the two nice lines but only dial up, dial down is not as nice and I could not figure out as why. I have the two lines but the amplitude is dropping to around 230 and the lines are a bit hairy. Both dial up and dial down the lines just go up and down without seemingly any pattern. I cleaned the movement two times, and then a 3rd time pegged out the main plate and train bridge holes but made no change. Both the HS collet and the roller table was too lose on the new staff... I did not count how many times I took the balance cock off to sort out the HS collet, the roller table and the beat error, somebody before me also shortened the HS by pushing it out a bit and it seems every time somebody is messing with the end of the HS the protruding bit is most of the time twisted bent etc. This one was probably one of the most challenging repair and service. I might take the new MS out and clean it lubricate it as I just pushed the new one in to the barrel from the retaining ring. Plus started to re-read the theory of the escapement and how to analyse the graph on the timing machine: Greiner Chronografic Record manual. I am also thinking to put the watch on a 24 hour long run with the eTimer SW it once helped me to figure out what was wrong with a watch. There is an interesting part of the Greiner record manual talking about the pallets and the end shake of the balance and pallet staff. Maybe this is my issue? Who could that possibly identify? After a few years now I am still without a clue how could watchmakers make parts I can only see with my microscope or how could/can they carry out complicated services impossible to do.. real magic..... .... ..... before I sent this post while the pics were uploading I had an idea, i was browsing the possible outcomes on the timing machine I had one for magnetism..... so I demagnetized the movement and it is not hairy now.... two really nice lines 0.2 ms beat error still a bit wavy, but a lot lot better..... argh....
