Longcase clock repairs
antonyh
This a picture of the back plate of a longcased clock movement I'm working on, just to show the lengths that the bad repairer will use to botch a job up.
I've had to replace a good few of the bushes, realign the pallets, as they weren't even in line with the escape wheel.
They had used a piece of Mainspring to reface the pallets , forgetting that that they are supposed to be at the same angle as the originals otherwise they really aren't a lot of good.
That's just for starters.
It's just one of those jobs I really wish I hadn't taken on.
This is the joys of being a horologist. I am working on a non working smiths 8 day clock. The screws that hold the plate together were loose. So far a baldly torn mainspring, gathering pin missing + gathering plate loose, click spring broken + many bushes including  barrel bushing to be replaced.
Explained to customer repairs will cost far more than the clock is worth but still given the go ahead..
Edited by clockboy
Hi clock boy are you and OH the best folk to ask about this sort of repair. I have a Smiths napoleon Westminster chime clock i would like to have a go at repairing, I'm hoping it just needs a service. I doesnt seem to have enough power to run with the pendulum on, and the chimes seem out of sync. No. On the movement is K6A 549. Any advice would be appreciated, im not quite ready to start yet as i have some wristwatches to finish off, but i wouldnt mind a hint beforehand  as where to start. Thanks
That longcase clock has been well and truly botched up it's going to take a lot of careful work to put that back into a good working order. The style of the pillars tells me its a late one around the 1800's.
Now onto the chime. Have you ever repaired a striking clock? I advise you to undertake a strike first so you understand the workings. I admit there are many videos on Youtube showing chiming clock repairs. The Smiths one you have is very common so yes we can help you with it. I suggest you take plenty of photos, You are going to need a clock mainspring winder, do you have one? You will need clock cutting broaches.  I need to know this before we go into what to do.
Agree 100% with OH. If this is your first clock a Westminster is not a good one to start with. All the chimes have to be aligned and assembly can be tricky as well. A mainspring winder is a must for these movements as the springs are strong and can cause a lot of damage to yourself and the movement if they unwind without control.
One can anly concur with the advise given, startwith a strike only before moving on to the westminster as there are many complications, the auro correction , the timing of th warnings,  and the cams and levers.  You need to do a bit of research and reading before attempting the westminster.
Hi  There is a site by Barrie Smith (no relation) on siths clocks you might find usefull reading. Attached a couple of picks explainging the fromt plate levers.  They differ from clock to clock but do the same job.  De Carles book on clock repairing and Mike Watters book worth a read also Laurie Pennman and Brian Loomes.
@watchweasol, these are great diagrams!  I am still trying to get all of the terms straight in my head.
This morning I finished this Westminster.  Put about four hours into it yesterday and another two this morning.  This is my third one of this movement type.  All three were slightly different...mainly in the going train and motor.  The strike and chime were pretty much the same except that one of them used  Lenz's Law instead of a conventional fly.
I picked this one up on ebay for a total of $86 (including tax and shipping).  Not as good as my $6 thrift store find!!
Once testing is complete, I will give it to my son.
The motor on this clock is different than the others.  It looked more modern.  Indeed, there is a note inside the door...the motor was replaced in 1979.
    • @Leonid, the only way forward is to service and repair your watch. Either take it to someone you trust or do it yourself. However, you should not try to do it yourself until you have successfully serviced and repaired, let's say, 20 or so less expensive watches (Vostok 24xx movements are amazing for practice). Rolex spare parts can be very expensive and difficult to get by should you lose or accidentally damage or destroy a part. There is, unfortunately, no quick fix!
    • Thanks all. We'll definitely do the castle and a cruise on the Danube.
    • I lived there for more than a decade but not sure what to recommend. I would probably recommend the Szechenyi spa but i never visited it while I lived there I just know that most ppl love it. Or you could go up to the castle and look down on the river and parliament, the pics which Oldhippy sent are from the castle. You still can see some of the buildings have bullet holes from WWII or from the Hungarian revolution against the soviets'. There are some nice museums as well if thats your thing. I cannot stand paintings... I have a headache after the first 3. 🙂 There are many old and nice buildings still standing even though Bp had one of the most brutal siege of the WWII so just walking on some of the streets is nice. You also might find protesters on the streets, but you should not worry about your safety, not as of yet at least.
    • Thank you for your introduction and welcome to this friendly forum. We all look forward to your contributions and continued involvement.  If there is anything we can help you with don’t be afraid to ask. Nice clear photos can help a lot.
    • Wow have a great time. This might help. Click on visit.  https://www.google.com/imgres?q=things to see in budapest&imgurl=https%3A%2F%2Fmedia.timeout.com%2Fimages%2F106231583%2F750%2F562%2Fimage.jpg&imgrefurl=https%3A%2F%2Fwww.timeout.com%2Fbudapest%2Fthings-to-do%2Fbest-things-to-do-in-budapest&docid=j8s3GsQ5yz621M&tbnid=x8GSpoc4vKpv9M&vet=12ahUKEwjTofPT-7iMAxVVQUEAHVt0F3gQM3oECBwQAA..i&w=750&h=562&hcb=2&ved=2ahUKEwjTofPT-7iMAxVVQUEAHVt0F3gQM3oECBwQAA
