American barrel arbor
Willow
Just stripped down a William and Gilbert 1886 mantle clock, my first American clock for cleaning and by gosh does it need cleaning not come across one this dirty before ,though i dare say a lot of you have and worse.
Anyway my question is how to get the arbor out, the count wheel is riveted to the barrel, on both arbors the rachet wheel won't budge don't want to force anything in case i damage something and just hope the barrels will go on my springwinder ok. Thanks everyone
Yes the ratchet looks like its on a square but won't pull off and i don't want to force it in case i damage something, and the count wheel is riveted on will give it a good clean and have another look.
I am going to give it a clean and try the brute strength method🤣
54 minutes ago, oldhippy said:
I'm sure if you put a couple of good man enough screwdrivers under the ratchet wheel it will come off. What a crazy design.
Yippee😂 finally got the arbor out and ratchet off after someone surgested supporting ratchet and giving the arbor a few taps, well after a few whacks rachet popped off and arbor came out job done seems like alot haven't seen this type before even are friends across the pond thanks everyone for your input
37 minutes ago, oldhippy said:
That is good news. What are you going to clean it with?
I have gave a first wash in warm water and liquid to get some of the oil off yesterday and now i have the mainspring out i will do the same with the barrel etc accept the spring then everything in parrafin then final wash.
Hi just some advice not about this clock but one i am thinking of buying. Didn't want to start a new thread for this,i am told it's German but that's all they know about the clock except their father had it for 38 years. Any Thoughts.
With out seeing the movement I can't really say. Its a strike, that top doesn't look right it looks more like the sort of thing you see on those German wall clocks which many confuse them with the proper Vienna wall clocks. Take that off and the case looks right.
Here is an example of the type of German wall clock.
Thanks for that oldhippy did ask them if she knew the makers name or if there was a trade mark on the movement all she knew was her father had it for 38 years and it's been stored away for a few years so she is having a clear out, thanks anyway Hi watchweasol that's it no photo of the movement she only wants £20 for it but then i have to pick it up from Leyland so i will probably give it amiss, thanks anyway
    • HWGIKE#57 Valex FEF 190 15 jewels Swiss lever full service and repair This one was waiting for a balance staff replacement in my cabinet parts and case cleaned up with a new balance staff and a 4th wheel as the original 4th wheel had a broken pivot for the off center second hand. I never attempted a balance staff replacement before however I received a Bergeon Molfres (i was hunting it for about 2 years) and with the help of it I managed to remove the old staff and riveted the new one in. It also received a new MS, crystal and the hole for the MS arbor was also tightened. With the new MS now it has an acceptable performance meaning that the amplitude goes up to 280 fully wound, has an acceptable beat error and I have the two nice lines but only dial up, dial down is not as nice and I could not figure out as why. I have the two lines but the amplitude is dropping to around 230 and the lines are a bit hairy. Both dial up and dial down the lines just go up and down without seemingly any pattern. I cleaned the movement two times, and then a 3rd time pegged out the main plate and train bridge holes but made no change. Both the HS collet and the roller table was too lose on the new staff... I did not count how many times I took the balance cock off to sort out the HS collet, the roller table and the beat error, somebody before me also shortened the HS by pushing it out a bit and it seems every time somebody is messing with the end of the HS the protruding bit is most of the time twisted bent etc. This one was probably one of the most challenging repair and service. I might take the new MS out and clean it lubricate it as I just pushed the new one in to the barrel from the retaining ring. Plus started to re-read the theory of the escapement and how to analyse the graph on the timing machine: Greiner Chronografic Record manual. I am also thinking to put the watch on a 24 hour long run with the eTimer SW it once helped me to figure out what was wrong with a watch. There is an interesting part of the Greiner record manual talking about the pallets and the end shake of the balance and pallet staff. Maybe this is my issue? Who could that possibly identify? After a few years now I am still without a clue how could watchmakers make parts I can only see with my microscope or how could/can they carry out complicated services impossible to do.. real magic..... .... ..... before I sent this post while the pics were uploading I had an idea, i was browsing the possible outcomes on the timing machine I had one for magnetism..... so I demagnetized the movement and it is not hairy now.... two really nice lines 0.2 ms beat error still a bit wavy, but a lot lot better..... argh....
