TAG Heuer Quartz
If they don't give enough movement individually then just bend a piece of wire or rod so you can depress them together.
I thought you were just looking for the Part No. https://www.dumonttools.com/en/products
By HectorLooi · Posted
316 steel is not hardenable. It is a high corrosion resistant steel. Usually used for marine purposes.
