A friend asked me whether I could service his Revue Thommen „Triple Date Moon Phase“. It was built in the ’90s and should a have a caliber ETA 2898-2. Can somebody in this friendly forum help me with a documentation of the dial side? I cann‘t find anything in the net (except these photos).
Edited by Kalanag
23 minutes ago, jdm said:
The "dial side" is a separate complication module not made by ETA but by Dubois Dépraz, which doesn't release any documentation or parts. You can find an article and video at https://www.thenakedwatchmaker.com/decon-dubois-depraz-full-calendar
Great info and perfect pictures! Thank you so much! That‘s more than I dared to expect!
I like to have an idea of what to find inside before I open a valuable watch.
That was a very nice website link by the way
in addition to sources like that for the chronograph module sometimes the companies that are using the module I've seen that they have servicing information. I was looking at something the other day going through a series of documents and I saw chronograph module just can't quite remember which one was in.
Then a course there is the problem of even with the documentation And pretty pictures getting spare parts Will probably be an issue
The watch arrived today. This beautyful timepiece has been serviced from time to time by a professional watchmaker who closed his business some years ago.
The case needs a new gold plating. My plan is to remove the movement and the crystals and give the case to a professional goldsmith nearby. He said he can do the cleaning, polishing and plating.
I‘m going to service the movement and will report here soon.
The journey begins!
The timegrapher shows a decent amplitude, zero beat error and a significant time loss.
I found the seconds hand loose and - as a result - circular marks on the inside of the front crystal
The obvious reason for the loose seconds hand was a minutes hand not pressed deep enough onto its pinion preventing the seconds hand tube reaching its deep sitting pivot.
When inspecting the case the first question to my fellows here came up: How to deal with these tiny pushers. Must they be pressed out before replating the case? If yes, to which side? Thanks for any help!
Edited by Kalanag
I would like to report that removing the triple-date-moon-phase module from the ETA 2892-2 was more than easy without the necessity of any disassembling on the module. It is held by the dial feet screws of the ETA’s main plate and can just be lift off (The dial is tightened to the module by two other screws).
Edited by Kalanag
I forgot to mention that the date module seems not to be made by Dubois-Depraz. The quality standard is lower and the month can only be changed with the pusher by hand. There is no manufacturer logo stamped on the plate
Edited by Kalanag
To finalize this thread I like to report that I successfully serviced the movement. I used the old pushers in the newly gold plated case. The plating was done by a goldsmith after I had removed the crystals, the crown tube and the pushers. The crown and the front crystal are new. My friend is happy wearing a good looking watch again 😀
Edited by Kalanag
  • 2 years later...
I am a newby with watch maintenance. Could you tell me if it is possible to take the movement out without dissembling the watch hands and dial? Thanks. Bill.
*****@*****.tld
always best to start a new discussion as I regard each watch as unique. Then which watch the same as in this discussion or some other watch? We always need a little more information but typically not always on wristwatches you can usually remove the stem and of course the back possibly a movement ring and the movement will come out. Typically you would never take the dial and hands off to get a watch out of the case.
*****@*****.tld
Yes that i how its usually done, once the movement is out then you can access the dial retaining screws, tabs or however it is fixed. The hands can then also be removed safely, try not to lay the movement face down until they've been taken off or you could bend them or scratch the dial if they press up against it. Most of us use hand levers and a thin plastic film cover over the dial and hands to protect it from the levers, i prefer to use paper with a slit in it slipped under the hands, this way the hands can be picked up from the paper without fear of dial damage. But as John suggests begin a new thread regarding your watch as there are a few methods for removing movements that are specific to the case style.
    • HWGIKE#57 Valex FEF 190 15 jewels Swiss lever full service and repair This one was waiting for a balance staff replacement in my cabinet parts and case cleaned up with a new balance staff and a 4th wheel as the original 4th wheel had a broken pivot for the off center second hand. I never attempted a balance staff replacement before however I received a Bergeon Molfres (i was hunting it for about 2 years) and with the help of it I managed to remove the old staff and riveted the new one in. It also received a new MS, crystal and the hole for the MS arbor was also tightened. With the new MS now it has an acceptable performance meaning that the amplitude goes up to 280 fully wound, has an acceptable beat error and I have the two nice lines but only dial up, dial down is not as nice and I could not figure out as why. I have the two lines but the amplitude is dropping to around 230 and the lines are a bit hairy. Both dial up and dial down the lines just go up and down without seemingly any pattern. I cleaned the movement two times, and then a 3rd time pegged out the main plate and train bridge holes but made no change. Both the HS collet and the roller table was too lose on the new staff... I did not count how many times I took the balance cock off to sort out the HS collet, the roller table and the beat error, somebody before me also shortened the HS by pushing it out a bit and it seems every time somebody is messing with the end of the HS the protruding bit is most of the time twisted bent etc. This one was probably one of the most challenging repair and service. I might take the new MS out and clean it lubricate it as I just pushed the new one in to the barrel from the retaining ring. Plus started to re-read the theory of the escapement and how to analyse the graph on the timing machine: Greiner Chronografic Record manual. I am also thinking to put the watch on a 24 hour long run with the eTimer SW it once helped me to figure out what was wrong with a watch. There is an interesting part of the Greiner record manual talking about the pallets and the end shake of the balance and pallet staff. Maybe this is my issue? Who could that possibly identify? After a few years now I am still without a clue how could watchmakers make parts I can only see with my microscope or how could/can they carry out complicated services impossible to do.. real magic..... .... ..... before I sent this post while the pics were uploading I had an idea, i was browsing the possible outcomes on the timing machine I had one for magnetism..... so I demagnetized the movement and it is not hairy now.... two really nice lines 0.2 ms beat error still a bit wavy, but a lot lot better..... argh....
