I have several Dremel multitools and one of them is mounted on the dremel drill press for drilling holes.  Not exactly a watchmaking tool, but I have needed to drill fine holes in my little world of horology and it really sucks.  Vibration and runout are quite poor.
I am investigating getting a Proxxon FBS multitool.  Anybody here with some experience using this tool?
I don't know the exact model but I have a Proxxon I got 15-16 years ago, switched from collets to "drill chuck", runs true and problem free. Last 5 years or so it was used by multiple people each day, hours each day. Amazing quality for the money, even at 3x the price. I had a Dremel as a kid, Dremel is a toy compared to Proxxon. Don't know how they do it and make money.
I have a high dollar hand piece "micomotor" too, it's fixed at 3/32" for normal burrs and stuff, gets way less use.
If it is precise, one off holes, the really watchmaking way to drill is with the lathe. You will need a clasping faceplate to hold most parts however, and that is expensive.
Also precision, small drill presseae are expensive and hard to find. I have a couple of cheap Chinese presses on my wish list, but didn't gi on with the purchase so far. You typically buy the motor separately for these.
I have that, in the long neck version. It's arguably better than a Dremel, but won't solve precise drilling. The quality is OK, I have abused it for years including cylinder head porting before the power board finally gave up and is currently waiting for replacent or repair. In the meanwhile I got a cheap Chinese rotary tool, a full set of collets and accessories for one the price. And it does its job just fine as well.
I do some drilling with the lathe, but I do not have the faceplate you describe...just did it by hand...very very crude.
I have ordered one and will report on my findings!
Just now, jdm said:
Probably you have bought a vintage real deal but for the casual reader here a link to the Chinese version https://www.ebay.com/itm/3-Jaw-Face-Plate-Disk-Chuck-for-8mm-Watchmaker-Lathe/403407905491
Oh!  I have two of those.  One I bought on ebay for about $75 as I recall, and the other came with that watch bench full of stuff I posted about several weeks ago.  Neither came with the centering pin, however.
Proxxon is good gear for the price, a mate has one for making dolls house furniture it will drill down to 1mm he paid under 200 quid for it. Its accurate for his use , wasn't sure about watch repair though. If so I know they also do a drill and milling machine, I might price one up.
That sounds like a dental micromotor.
I had a Dremel tool many years ago for drilling pcbs. It does the job but I didn't like the vibration and noise.
I have several dental micromotors now. Some for clinical use and some for lab use. Dental micromotors are different from "multitools" in that they have "torque feedback". With normal multitools, there isn't much torque when running at low rpm. But dental micromotors have a feedback circuit that increases power to the motor when the load increases, thus maintaining a constant rpm.
I have a few vintage ones from the '80s and things back then were really made to last. These are coming home with me when I retire.
i  have a Proxxon IBS and would prefer it instead of the FBS
the Neck with 20mm allows easy mounting for whatever (i use it on my Lathe, not Watchmaker Lathe...)
Disadvantage is no Chuck, only the Proxxon Collets....
regards,
Ernst
So what's the chuck you've bought now?
10 hours ago, LittleWatchShop said:
To be clear, my plan is not to use it directly on watches or clocks.  I use it when I am making things that are used in the watch shop...tools...jigs, etc.
For that I recommend that you buy a smallish bench drill press, preferably quality, and that can accomodate a cross table.
Yes, that's a nice plus.
In a pinch, us a small chuck with a 3.25mm straight shank that you can fit to a collet.
I think I have created some confusion...here I am referring to the two faceplates that I acquired.  When you first mentioned "faceplate" I said I did not have one, but I misspoke (the name threw me off).
But if you are referring to which Proxxon I bought...I bought the FBS/115.
I have a larger benchtop drill press.  It is a Harbor Freight brand (i.e., Chinese).  I use it for coarse work.
I think the neck on the FBS is the same, but I will know for sure when it arrives next week.
Then you have all what is needed. A big machine, adjusted and used correctly works just fine on small parts. Check if there is any play in the quill, on mine there was and it rattled at any speed, I shimmed it sliding a feeler gauge between the two cylinders and now is silent and smooth. There are better chucks that you can replaces like the below, the description doesn't say but are the precision line from a major maker.
https://www.aliexpress.com/item/1005002061403983.html
Or even better, a quality a keyless chuck. Then you can easily check the runout with a magnetic base and indicator.
The cross table could be like the below. https://aliexpress.com/item/4000241471577.html
Invest in a full set of quality drills and other accessories, orientable lighted lens etc, there will be very little work that you won't be able to undertake.
Edited by jdm
Hmmm...I must investigate this!!!
Ordered!
Maybe you could direct me to where you did the shimming??
It's hard to explain without seeing it taken to parts. But if your doesn't do strange noises or vibrations you don't have to worry.
Sorry if I sound repetitive but the drill press is one of the most useful tools ever. The stepped pulley are a blessing to get the right speed and torque, use them. If you need to cut a slot or big hole, drill close holes, then finish with a fret saw and file. If an hole on whatever object is a bit off or holes overlaps (could be the case above), grind a drill bit to a flat tip, sharpen the cutting edges imitating and end mill and you will be able to drill on rounded or irregular urfaces. Leave a brass wire wheel in the chuck all the time to clean up whatever around. Place a tap guide to thread straight and easy. I'm sure there are other bazillion uses. Just don't try to do milling with it, because drill chucks aren't made to take side forces. But if the machines is beefy enough, you are able to fit a collet chuck, and have a cross table, you could even do light cuts on soft materials.
Edited by jdm
Proxxon arrived today.  Right out of the box, I can tell it has much less vibration.  I am printing a mount just now on my 3D printer so that I can use my Dremel drill press stand.  I will post when it is done...and working.
