Back to Front Pendulum
ThamesSide
I have been given a wall clock to see if i can fix it. I have cleaned it with the correct fluid, oiled it and it is working. The problem I am having is if I put the pendulum on the right way it stops after 30 seconds or so. But if I put it on back to front it works perfectly and ticks until I stop it.
I don't know anything about clocks, clearly, but I would love to learn how to fix it and more importantly why it's happening.
Thanks Simon
The pendulum doesn't look to be in a  straight line. Make sure it is in beat it should have an even tick. Here is a picture of how the pendulum should hang through the crutch. I'm assuming the movement is fixed this way around so you can test it and sort the pendulum out as it is the wrong way when it come to casing it up.
Sorry, I don't know what beat error is. I will do some reading.
It is mounted the wrong way round. it is so I can access the pendulum.
With the pendulum mounted backwards it's been ticking all day. As soon as I turn it round, it stops. The tick seems to be right in the centre of the two pins. With no pendulum on the bar it sits on and clips onto looks slightly twisted.
I bought another pendulum which arrived yesterday. The original one has quite a ding in it and I am wondering if it's a combination of two things, the twisted bar the pendulum sits on and also the bashed pendulum BUT surely if it is either of the above the clock wouldn't work with the pendulum facing either way and yet it happily ticks all day long when on in reverse?
I adore clocks and watches, I have 2 beautiful mantle clocks and over 30 watches although I know nothing about them. I've spent 20+ years fighting cancer and I am coming out the other end so I intend on looking into this as a serious hobby to keep me busy, mentally challenged and it isn't too strenuous as I've had everything from tumours to bone marrow transplants and so I don't want a jogging hobby, something more sedate I think.
Thanks for the help, I really do appreciate it.
Thanks everyone. I have it working now. I pulled the pin out of "d" on the above pic, fed it down through the slit and turned it around. It is working OK now and the pendulum is the right way round.
Now, I need to put the hands on as they seem quite loose, the metal coil at the back the hammer strikes has a noisy clang rather than a pleasant ding , so I need to figure that out as "b" on the pic is touching the coil. Hammer is working OK but "b" needs some adjustment so it doesn't make any contact with the coil.
Thanks for the help and support folks.
Make sure you don't have the movement on those brackets too far back, it is better to bend the hammer for it to have a nice sounding strike. Also the movement doesn't want to be too forward because you might not be able to close the door. Good luck.
    • HWGIKE#57 Valex FEF 190 15 jewels Swiss lever full service and repair This one was waiting for a balance staff replacement in my cabinet parts and case cleaned up with a new balance staff and a 4th wheel as the original 4th wheel had a broken pivot for the off center second hand. I never attempted a balance staff replacement before however I received a Bergeon Molfres (i was hunting it for about 2 years) and with the help of it I managed to remove the old staff and riveted the new one in. It also received a new MS, crystal and the hole for the MS arbor was also tightened. With the new MS now it has an acceptable performance meaning that the amplitude goes up to 280 fully wound, has an acceptable beat error and I have the two nice lines but only dial up, dial down is not as nice and I could not figure out as why. I have the two lines but the amplitude is dropping to around 230 and the lines are a bit hairy. Both dial up and dial down the lines just go up and down without seemingly any pattern. I cleaned the movement two times, and then a 3rd time pegged out the main plate and train bridge holes but made no change. Both the HS collet and the roller table was too lose on the new staff... I did not count how many times I took the balance cock off to sort out the HS collet, the roller table and the beat error, somebody before me also shortened the HS by pushing it out a bit and it seems every time somebody is messing with the end of the HS the protruding bit is most of the time twisted bent etc. This one was probably one of the most challenging repair and service. I might take the new MS out and clean it lubricate it as I just pushed the new one in to the barrel from the retaining ring. Plus started to re-read the theory of the escapement and how to analyse the graph on the timing machine: Greiner Chronografic Record manual. I am also thinking to put the watch on a 24 hour long run with the eTimer SW it once helped me to figure out what was wrong with a watch. There is an interesting part of the Greiner record manual talking about the pallets and the end shake of the balance and pallet staff. Maybe this is my issue? Who could that possibly identify? After a few years now I am still without a clue how could watchmakers make parts I can only see with my microscope or how could/can they carry out complicated services impossible to do.. real magic..... .... ..... before I sent this post while the pics were uploading I had an idea, i was browsing the possible outcomes on the timing machine I had one for magnetism..... so I demagnetized the movement and it is not hairy now.... two really nice lines 0.2 ms beat error still a bit wavy, but a lot lot better..... argh....
