Below, proposing an "In Search of..." Section:
Good morning all.  After having read about a new (Beginners) section being proposed and discussed, I began to consider other such things which a new section might accomplish.  I arrived at the idea of addressing an obstacle which all who work on vintage watch must inevitably face: that of locating hard-to-find parts.  For this reason, I would like to discuss with all of you the pros, cons, & improvements of putting forth an "In Search Of" section.
The way I initially conceived it, the section would be for expressing that the person making a post is searching for a very hard-to-find part.  The section would have a pinned header which stipulated that anyone posting in it should at least have tried such other sources first  - Ebay, Ofrei, Cousins, Esslinger, Dave's, and any others that are open to all (not just licensed or registered watchmakers).  The header should also reiterate the No-Sales policy and specify that if one of us has the part being sought, but it is valuable enough to require compensation, that matter should be handled by private message from that point onward.  Anyone posting should make every effort to post all the details of the watch to which the necessary part belongs: make, model or calibre, year, any known variation thereof, and define the sought-after part in as much detail as possible, if the name for such a part is not widely known.
In this way, a frustrated member having exhausted all his best leads and reaching many dead ends, might post in this section that he is "In Search Of" a dial for an Omega Seamaster cal. 470, or perhaps a two-piece split stem for a Longines 345, or maybe a helical mainspring for a Grasset pocket watch, who knows.  And those on the forum who read that section from time-to-time would see it, and one among them might recall that "I have such a dial in my parts bin!"  You get the idea.  And then the person with the part could send a message to the person who is seeking it, and in private messages they could reach an arrangement.  I know such matters are already being handled this way in this forum, but we have not yet had a *dedicated* section for it.  What I am proposing is a sort of focal point for rare-parts searches.  A place in the forum for exactly this.
As you might imagine, my search for the Seamaster dial was part of what brought this idea to the forefront.  I've located the stem, however.  The Grasset mainspring is an attempt at a humorous analogy.  But I do believe that having an "In Search Of" section will benefit a great many of us, from seasoned veteran watchmakers who have sought a part high and low, to the beginners who don't even know what a particular or unusual part is called, let alone how to search for it.  And it would be aimed at connecting them with any other member who might know where to locate the part in question, might possess the part in question, or even be able to repair or re-create the part in question with the tools they have.
So, tell me your thoughts.  I am eager to hear.  I would like to see such a section exist, but I would like it to be easy for all to use, so suggestions for improvements are extremely important.  How can we make this work as well as possible?  How many of the rest of you desire this?
Edited by KarlvonKoln
edited for clarity
It doesn't matter - WRT isn't a democracy.
Your idea would have best been addressed directly (in private) to Mark.
  • Mark locked this topic
This topic is now closed to further replies.
    • HWGIKE#57 Valex FEF 190 15 jewels Swiss lever full service and repair This one was waiting for a balance staff replacement in my cabinet parts and case cleaned up with a new balance staff and a 4th wheel as the original 4th wheel had a broken pivot for the off center second hand. I never attempted a balance staff replacement before however I received a Bergeon Molfres (i was hunting it for about 2 years) and with the help of it I managed to remove the old staff and riveted the new one in. It also received a new MS, crystal and the hole for the MS arbor was also tightened. With the new MS now it has an acceptable performance meaning that the amplitude goes up to 280 fully wound, has an acceptable beat error and I have the two nice lines but only dial up, dial down is not as nice and I could not figure out as why. I have the two lines but the amplitude is dropping to around 230 and the lines are a bit hairy. Both dial up and dial down the lines just go up and down without seemingly any pattern. I cleaned the movement two times, and then a 3rd time pegged out the main plate and train bridge holes but made no change. Both the HS collet and the roller table was too lose on the new staff... I did not count how many times I took the balance cock off to sort out the HS collet, the roller table and the beat error, somebody before me also shortened the HS by pushing it out a bit and it seems every time somebody is messing with the end of the HS the protruding bit is most of the time twisted bent etc. This one was probably one of the most challenging repair and service. I might take the new MS out and clean it lubricate it as I just pushed the new one in to the barrel from the retaining ring. Plus started to re-read the theory of the escapement and how to analyse the graph on the timing machine: Greiner Chronografic Record manual. I am also thinking to put the watch on a 24 hour long run with the eTimer SW it once helped me to figure out what was wrong with a watch. There is an interesting part of the Greiner record manual talking about the pallets and the end shake of the balance and pallet staff. Maybe this is my issue? Who could that possibly identify? After a few years now I am still without a clue how could watchmakers make parts I can only see with my microscope or how could/can they carry out complicated services impossible to do.. real magic..... .... ..... before I sent this post while the pics were uploading I had an idea, i was browsing the possible outcomes on the timing machine I had one for magnetism..... so I demagnetized the movement and it is not hairy now.... two really nice lines 0.2 ms beat error still a bit wavy, but a lot lot better..... argh....
