I have a SEIKO 6S37-0010, but its aged band links always fall out, once even making it drop from my wrist.
I asked SEIKO, and they said it is $1300 for a new titanium band, barring this option, where can I get replacement linking bars, or perhaps leather bands?
Thanks!
(Picture is not my watch, it is over in Japan for repair right now. This is a generic image just for reference purposes.)
Thanks!
Thanks!
Thanks!
Cousins supply bracelet parts and some Seiko bracelets .
https://www.cousinsuk.com/search?searchTerm=20mm Seiko Bracelet SS (35J5JG)
There is a guy on YouTube “ the Nekkid watchmaker” who does some remarkable work on cases and bracelets well worth a watch to see what can be achieved with an original.
Edited by clockboy
On 6/26/2022 at 1:26 AM, Nucejoe said:
How about showing the damage for advice.
Sorry, but I do not have the watch on hand right now, since it is at SEIKO for repairs. I will update the post with those as soon as I get them back!
    • Hi watchweasol, yes that is a way of doing it I suppose, I have a pair of mainspring hole making pliers on their way off eBay, the ones with the different shaped punches. I may be able to use them to make a hook.
    • Hello everyone, Glad to be here.
    • No mate. Sorry if that offends you! Also please don’t take threads off-topic. I thank you sir.
