TAG Heuer Movement Identification help needed
By CARBONLACE · Posted
Good morning. I have a Caliber 11DO 17 Jewel that I utterly destroyed practicing on. My question is this. Are the 17j and 7j compatible in relation to swapping out parts such as the Wheel Train and Balance? Thank you in advance. -
Ah ok thanks , i see thing differently now. Won't that catch the wheel rim though ? -
No Mark it does not offend me. I think I have already started another thread on the matter before you replied. But since you are unwilling to discuss it with us, I will discontinue posting there. Thank you for considering it though. That's a good policy to have H , you should always safeguard yourself. Knowing who you can trust and who you can't is not a permanent thing. People's values change, people change and adapt to their situations,thats just nature stepping in and running the show. Not everyone is as genuine as you are H. The new no advertising looks much better, it never bothered me much, but it still feels cleaner. I'm pleased that your thread regarding the missing images was also returned, so thats good news as well. It appears a lot of mine have also been removed ...oh well...🤷♂️ -
Welcome to the forum. My guess would be to press or lift here.
