Recently acquired a watchmakers lathe, what should my first steps be?
On 7/8/2022 at 4:39 PM, Neverenoughwatches said:
As regards to tools and equipment cost. I posted a litlle while back about my total set up cost, I've all but finished now with my last piece arriving today in the post, a jewelling tool with the accessories.
Complete cost now for maybe 95% of all repairs, totals give or take a few quid £1000 (this was my aimed at budget )
Sorry, just couldn't help myself! 😉
Haha no problem watchie, i blew that out of the watch not long after i posted it. 3 more jewelling tools, another jacot, another staking set, a hairspring vibrator, a 6 x4 shed load of hand tools and now another lathe later.   🤔 at least double maybe even triple that figure 🤣
  • 1 year later...
On 8/2/2022 at 3:43 AM, HectorLooi said:
I finally got the mounting screw and pedestal off the lathe bed. It was no easy task.
I had to rethread the screw to a 8 x 1.25 thread, then jammed on 4 nuts and really doused it in WD40 overnight to loosen it.
I really have to thank @nickelsilver for his help.
Old thread but hey you're all still active.
In your case @HectorLooi were you able to get an M8 bolt into the lathe bed? I've got a Webster Whitcomb bed that had been mounted to a Borel base which I don't want to use. I'm trying to get it mounted to a standard pedestal instead, and can't get a screw that matches the bed's thread.
The existing screw mounting to the Borel base measures 19/64" which is like 7.54mm and about 25 threads per inch, which is close enough to 1mm. US hardware stores carry 5/16"x24 which is almost right in that the antique screw can thread into a modern 5/16x24 nut but a modern 5/16x24 bolt is slightly too big to fit the antique threads in the WW lathe bed. I can attempt to re-tap the bed to M8, but I'm curious what your eventual resolution was. It sounds like you modified your screw rather than your lathe bed.
Haha. I really don't remember. I have 2 lathes mounted on Borel bases. So I think I didn't have problems getting the screws.
Anyway, there was this screw specialty shop that I used to go to. All I had to do was show them the screw that I needed and they'll go their store and reappear moments later with the correct screw. They had been in business for as long as I can remember but closed after Covid. I guess they were another casualty of the pandemic.
Heh oh well. I think I am going to tap my lathe bed for a 5/16 screw because I won't even need to drill it out. I doubt I will ever find a 19/64" screw and a metric M7.5 does not exist either.
Edited by mbwatch
7 hours ago, caseback said:
Possibly M8x1. That is what mine has.
That sounds right - I measure the threads around 1mm and total diameter of the screw is 7.54mm. Fractionally on my digital caliper, it says 19/64. I thought M8x1 were not easy to get (local stores only have 1.25 threads) but it does look like hardware suppliers have options. I will order some and see how they fit before I go rethreading anything. Thanks @caseback
    • HWGIKE#57 Valex FEF 190 15 jewels Swiss lever full service and repair This one was waiting for a balance staff replacement in my cabinet parts and case cleaned up with a new balance staff and a 4th wheel as the original 4th wheel had a broken pivot for the off center second hand. I never attempted a balance staff replacement before however I received a Bergeon Molfres (i was hunting it for about 2 years) and with the help of it I managed to remove the old staff and riveted the new one in. It also received a new MS, crystal and the hole for the MS arbor was also tightened. With the new MS now it has an acceptable performance meaning that the amplitude goes up to 280 fully wound, has an acceptable beat error and I have the two nice lines but only dial up, dial down is not as nice and I could not figure out as why. I have the two lines but the amplitude is dropping to around 230 and the lines are a bit hairy. Both dial up and dial down the lines just go up and down without seemingly any pattern. I cleaned the movement two times, and then a 3rd time pegged out the main plate and train bridge holes but made no change. Both the HS collet and the roller table was too lose on the new staff... I did not count how many times I took the balance cock off to sort out the HS collet, the roller table and the beat error, somebody before me also shortened the HS by pushing it out a bit and it seems every time somebody is messing with the end of the HS the protruding bit is most of the time twisted bent etc. This one was probably one of the most challenging repair and service. I might take the new MS out and clean it lubricate it as I just pushed the new one in to the barrel from the retaining ring. Plus started to re-read the theory of the escapement and how to analyse the graph on the timing machine: Greiner Chronografic Record manual. I am also thinking to put the watch on a 24 hour long run with the eTimer SW it once helped me to figure out what was wrong with a watch. There is an interesting part of the Greiner record manual talking about the pallets and the end shake of the balance and pallet staff. Maybe this is my issue? Who could that possibly identify? After a few years now I am still without a clue how could watchmakers make parts I can only see with my microscope or how could/can they carry out complicated services impossible to do.. real magic..... .... ..... before I sent this post while the pics were uploading I had an idea, i was browsing the possible outcomes on the timing machine I had one for magnetism..... so I demagnetized the movement and it is not hairy now.... two really nice lines 0.2 ms beat error still a bit wavy, but a lot lot better..... argh....
