Looks like a 15 sided tool needed but they are 36/38/40mm.
Can't find any list that shows what size fits what watch though.
How about the rubber ball? Lots have had good results on newer watches.
If it's 38 - it's very good. I have 38mm opener.
I should have added be careful when removing the dial hands they are b!!gers to remove without damage. They are coated with some sort of plastic & when I removed the main chrono hand the centre arbour detached itself & I had to purchase a new one.
When re-fitting I found the best method was to use a flat headed holed punch & covered with clear plastic to protect from marking
    • Agreed. There are many different automatic winding mechanisms, each with their own quirks wrt. lubrication. Access to the specific service instructions is the ideal. Otherwise, ask here for advice on the movement you are working on.
    • I put the original broken glass (whats left of it) behind the acrylic. This is how it originally looked like. A cheap clock but I like it. Very noisy when the alarm comes wake up guaranteed! 🙂
