Hi  Threr is a logo and a number on the plates, you can check th logo via Mikrolisk to find the maker and pocketwatchdatabase.com with the serial number. If you are lucky it will give you all you require if not we shall have to have a look round. can you post a clear picture of both the logo and the number thanks        cheers
Yes please, a better photo of the embossed logo. Or at least a reading of the letters. I couldn't read the beginning but it looks as if the last letters are: M A L. I didn't see anything in BestFit® with a large X in the center.
I'd say most likely 1870s to almost 1890s.  I have a Swiss key-wind/set dating to 1867.  I have lever-sets as early as 1887.  Most pin-set watches evolved after key-sets, but levers came after the pin-sets and gained popularity.  Considering a degree of overlap, that's how I arrived at my rough guess.
Source - https://www.mikrolisk.de/show.php?site=280&suchwort=Decimal&searchWhere=all#sucheMarker
Search term (my best guess) Decimal.
As to "How much is it worth?" - the answer as always, whatever anybody will pay for it.
Its not in great condition, the hands don't match for starters, but with a little work, it could look quite nice.
Look on ebay for similar items and you will get a rough indication of what people *might* pay.
Edited by AndyHull
Further to that, mark "completed listings" box in advanced search, and you will know how much people had actually paid.
    • Books, or some sort of voucher to a material house if they do them. You can never read and learn enough and if you find a material house that could do a gift card then the person could pick things they really need.   Tom
    • I don’t know what a pivot locating tool is? I am not a clock guy though but everything else you mentioned cousinsuk should be able to supply without issue. you might get more results if posting in the clock section of the forum.   Tom
    • I came up with a topic that might be helpful for partners, friends, or family members of watch enthusiasts: gift ideas for people who are passionate about watches. Of course, more watches are always appreciated, but what are some other gift options related to this hobby or collection? What related gifts would you love to receive?
    • Thanks to everyone for the welcome.  Can I ask for some advice?  I have a French Drum clock which I am hoping to dismantle, clean and mend a bit for a friend (it is a long time since I did this, but I would like to restart). I used to go to M & P for supplies but it seems they are out of action at the moment.  Is Cousins a good place for supplies?  I think I will need: 1. Some small watchmaker type screwdrivers 2. Cleaning fluid to put in a bath and agitate the parts in (I don't have an ultrasonic bath and was not proposing to get one) 3. Clock oil 4. Some thin nosed pliers for removing pins 5. A basic magnifying eyeglass 6. A pivot locating tool 7. An assembly support for the movement 8. Some assorted pins .. but probably nothing more than that for the moment.  I don't think I will need to rebush any holes although I do have the tools for this.  The hour wheel is broken but I hope I have sourced a replacement. Final queries:  a. the wooden case has split a bit.  To glue it together, would standard strong PVA glue e.g. Evostik interior wood glue be OK?  b. to polish the exterior brasswork of the face and rear, is Duraglit OK, and should they be lacquered after polishing?  I am not proposing to polish and lacquer the movement itself, unless that is vital, but only to clean it in the cleaning fluid. Thanks in advance and I hope this is clear.
    • Thanks Mark. I think I’ll leave the beat error for now - it’s a fixed stud so I’d have to adjust the collet position.    The watch has bigger problems. On reassembly I’ve found that the hour counter reset hammer is broken - I didn’t do it, the main hammer part was just not there. Can’t easily identify a replacement part. And the subdial hands. The running seconds hand needs an extended pivot tube as the pivot is below dial level. Can’t find one of them either. I’ve found a central seconds hand that might fit it - going to have a go at cutting, filing and polishing it to make it work.
